Belt drive on 150g antweight weapons?
Howdy peeps!
Currently working on recadding Wipeout (again) for various upgrades after throwing it in the test box… inside, it managed to walk and spin pretty well (though very slowly) BUT i think it mustve hit something uneven on the floor because it sent itself flying twice… the energy from these two impacts are already showing the brushless motor some ware…
(picture shows that the weapon motor is already leaning at a slight angle, with a noticable click between this angle and sitting flush like it usually should)
I’m already solving the weapon hitting the floor issue, but it more concerns me about how much i’ll be able to hit other robots before the weapon motor decides not to live anymore…
I was thinking about going forna different setup as opposed to direct drive for a weapon of this, but i’m unsure what setup is best or what the best way to go about this may be. I’m leaning more towards belt drive currently, as i’m assuming a single hit is going to have enough energy to shatter any gears i put into this robot that arent metal, does anyone have any experience with this who could show their setup or give me some pointers on achieving something like this? Thanks in advance :slight_smile:
Reactor does belt drive, it’s not reliable though.
I’ve seen ants use belt drive before but it tends to be unreliable and heavy
If you are using an 1806 might I suggest a different motor with a thicker shaft?
Belt system weight- (sometimes new) motor, pulleys, belt, weapon motor shaft, shaft mounting
Different motor- motor, mounting screws,
With a different motor you can also increase the spin up time
What are you actually breaking? Bearings?
Without redesigning/recutting that bar I’d probably just see if I could whack a bearing around the top of the motor can to stop it flexing.
If you’re up for the challenge design a hub motor with a fat dead shaft and you’ll likely be grand too.
Without going the custom motor route you could do it with fat helical tpu gears, a rigid mount and a redesign of the bar and chassis.
I know theres a couple that use belt drive, off the top of my head i was reading through the Ultimate Ninja thread on here and saw it, which was helpful.
I’m using a tmotor f2004 for the weapon, might change to a repeat robotics one though even if it is lower KV, we will see. I don’t mind swapping to a belt drive system since the bot only weighs 208g atm (with more weight saving on the way to put it in the size limit), so i have the spare weight to try and invest in it at the very least, as this robot has the power and spin up speed, but i’m unsure how long the motor is going to last
Yeah, the t motor has a 1.5mm shaft, no wonder it’s bending like crazy, 3mm is the standard for a vertical here. I’d love to see a belt drive but a motor with a thicker shaft would probably be one of easiest ways to solve your problem
I’m not 100% sure what is actually breaking, I can see and feel a noticable bend when i press on the rotor(?), and i wouldn’t want that to worsen incase it somehow bends even more or the magnets get damaged…
I would love to do a hub motor for it, but i’m not sure i really have the facilities to be able to do one, mainly just trying to weigh up a different drive method for the weapon instead as its something i could do with what limited space and tools i have.
I have a surplus of these motors available since i knew a weapon like this would take a toll on them, so if one breaks i can just swap it, but it would be good to minimise it if possible. Just trying to make sure something like this works as consistently as possible…
yeahhh its quite a tiny shaft… Ive done a design for a belt setup using orings that i’ll have to order to be printed, just unsure how it will compare to direct drive (or if it’ll even work at all at such a large size)
Right now all the forces exerted by the blade run through four M2 screws threaded into aluminium, through the motor bell into the tiny (probably 2 or 3mm ID) bearings on the motor shaft, down the 2-3mm wide shaft (which is retained only by a snap ring), and into the mounting ears on the motor. This gives you a good 20mm of lever arm length between the centreline of the blade and the motor base, which is why the whole assembly flexes. Just like putting a breaker bar on a ratchet, the longer the lever arm the more the force is multiplied. Right now I can 100% see the blade leaving the chat on the first hit from a spicy vert, or even hitting a kickplate a bit too hard, as either the screws pull through, the bearings disintegrate, or the snap ring turns to glitter.
I agree with Harry here, the easy option here is to find a bearing that slides (or better, presses) around the outside of the motor bell and then drops into a matching recess inside the top of the bot. That’ll give you a nice chunky bearing right underneath the blade that will fully support the blade and take the majority of the load and transfer it into a big wide area of chassis. I’d also look into either increasing the size of the screws holding it to the motor faceplate (if there’s enough meat to drill and re-tap at M2.5 or M3) or just accepting that the blade and the motor are one now and epoxying it on.
If you want it to be even better supported then indirect drive is the way to go, as you can use a shaft or shoulder bolt that goes through the entire chassis to get as much support as possible, then put bearings in a weapon hub. Belts will slip and decouple the motor during big hits, but also that’s an enormous weapon with a heap of inertia, so they’ll likely slip on spin up too. 3D printed gears are probably a better option, especially if you make one of them out of TPU so that if they do skip they don’t throw teeth everywhere. Either will let you run some amount of gear reduction for less heat, faster spinup times, and a more controllable bot. You really don’t need much tip speed with a big weapon, tip speed on The Room-ba when translating is about 40-50mph!
Also, if you haven’t got your own printer yet, now might be the time to invest. Doing really weird stuff is so much easier when you can iterate through three or four revisions of a chassis or component in an evening. I wouldn’t be building robots half as ambitious as I am if I couldn’t go from dumb idea to prototype in a few hours. There’s a reason my A1 Mini has almost 2000 hours on it!
+1 for the lower tip speed. Your engagement goes way up so you actually hit harder than if you were to spin at 8000mph. FlintKnock is 125mm sweep and only on a 1550kv motor on 2s, with throttle at most half. Very often shatters chassis like glass and is far more stable, frequently splitting top from bottom along the layer lines. Plus the safety stuff with spinning crazy fast but that’s already been discussed.
So if i’m understanding right, the main issue is that all the energy from every collision is that its all going into the weapon motor, and ideally i just need a way to either strengthen the motor or disperse it into other areas of the bot so that 100% of the energy isn’t going into the motor.
I’ll definitely have a look and see if i can find a bearing that fits, but failing that the TPU gears would be a good shout. I was wondering if this big of a weapon would even spin with belt drive, so its nice to know theres an alternative i can look into, was thinking of mounting it to an m5 screw that screws into the body (with some eppxy/super glue), and having the weapon slide and mount into that, at least that way all the material is going into something a little sturdier than the motor itself.
Also i’d love to buy my own printer, i’m just a bit worried about the fumes from printing ABS since i do all my robots in my bedroom and don’t really have anywhere else to put it… I feel i’m better being safe than sorry even with an enclosure and an extraction on it, always debating it in my head but just want to be safe about it haha
Was thinking of going for a repeat robotics 1400kv motor since its probably a lot better suited for this than the motor i’m using is… plus it has a thicker shaft on it too. Only issue is having to get this weapon recut for the 3rd time which is quite costly…
Quite frankly I doubt you’ll ever find a direct drive solution that will be bulletproof with a weapon like that. Between your own energy stored and such a large lever acting when a vert hits the underside it will fail, I frequently bend the 5mm titanium shafts in the motors of Vanquish and that’s on a weapon less than half the size and potentialy storing a tenth of the energy. I think indirect drive is the only way forward, and a high reduction TPU geartrain might be the thing your looking for, and that’s if you somehow make it so the assembly cant be pulled directly out of the chassis from said big lever arm. It’s quite the challenge, but with a hell of alot of refinement and some clever design I believe you can get it done
I’ll have a look into it when i get home, I have an idea in mind on how to assemble it, just a question on if i can find the right kind of bolt and bearing to mount the weapon to… I think its definitely the best way to go about it, even if it is going to take more design work than just slapping it directly on the weapon motor.
Would be nice to make a weapon like this reliable, and i’m sure i’ll be able to figure something before november, will open CAD when i get home and see what i can do, since i’m not super concerned about weight atm (given that its already 17 grams underweight and ive now just shrank the chassis by 3mm to fit the square), so as long as i can get it all to fit inside and spin reliably, i will be happy haha. At least then it can be scary without exploding itself
Still plan to take it as a main competitor to midlands? Might need to stock up on motors if so, imagine my steel kickplates wont be particularly kind to this current version
Was thinking of swapping it for Elephant Wheels, since ive only got it competing at AWS at the minute whereas Wipeout is also competing at ORCS and AWS, would rather give all my bots a fair shot if i can help it (plus gives me a couple more weeks to prep up since AWS and ORCS are at the end of the month)
With the likes of x-ray, hysteria and caustic being up and out of the way on big wheels might not be a bad shout… hope I can get [BIG SHOT] v3 done for midlands, if not itll be ORCS
Yeahhhh, i think it’d be a fun one to bring, definitely less intensive on your arena power-wise too i hope… Would be good aswell to dee how it fares before AWS later in the month. Hope to see Big Shot there too! how big are the wheels on it?
Current gen [BIG SHOT] is quite stout for a bigwheel, sitting on 110mm wheels to 150 wide. Makes it very nice and controllable, the reach of the blade still keeps it safe from the majority of verts. [BIG SHOT] v3 is far larger at 140mm wheels to 220 wide, its keeps similar ratios of height to width to remain stable, but also means its fit with a monsterous 125mm blade ripped straight off of FlintKnock. The goal is to essentially miniaturize Cabraken at beetle scale, as its probably the most dominant UK beetle made at this point in time, and served as inspiration for v3 of [BIG SHOT]
Ahhh okay, i’m running 145mm wheels on Elephant Wheels since all my bots are built to fit within the square… Would be interesting to see more big wheels for sure since they are a rare breed (i can name 3 off the top of my head in this weight class including our two bots)
Quite excited to try compete with it though, will definitely require a bit of trial and error to get a good shot lined up for myself but eh, would be good fun :slight_smile:
