Soooo, if you’ve attended Rapture for a while, you’ve probably seen me pull up with Yomi and pretty much bomb event after event with a barely functioning robot most of the time.
Needless to say, it got tiring, so i’m working on something else for a bit in hope of having something that actually functions for a change.
And if something that wins is your goal, it’s pretty obvious since a few years by now, 4WD verts are the default option.
So this is where this thing comes into play, technically this is the second time i build this robot, but the first version was built in such a disorganised rush it only ever got completed for a whiteboard at the end of the event it was attending, not to mention having a number of flaws in it’s design.
The hopes is more to rely on reach than sheer ground game, the forks being mostly there as outriggers/stabilizers, the discs are optimised to have a shitload of bite depth too to assist with that, and with 4WD powered by 2 repeat maxes, it should have plenty of drive to get bite from approach speed as well.
As for as construction goes, it’s mostly made of TPU, the uprights are 8mm HDPE, and the top and bottom are 2mm CF (which totally may not be an issue when a hammersaw will come my way…), the forks are 6mm Hardox so hopefully they won’t get trivially bent to hell and back on hit one.
Also obligatory anti-HS config.
If everything goes well, this should show up at BBB champs and hopefully actually put up some semblance of a fight, which is more than my usual showings to events.
