# High Torque Motors for Lifters
**URL:** <https://forum.bristolbotbuilders.com/t/high-torque-motors-for-lifters/258>\
**Category:** Questions & Help\
**Tags:** parts-recommendation, beetleweight-1-5kg\
**Created:** [27 April 2024 06:50 UTC](https://forum.bristolbotbuilders.com/t/high-torque-motors-for-lifters/258 "2024-04-27T06:50:01Z")\
**Posts on this page:** 1\
**Showing post:** 7
<div class="post-metadata">
**Author:** ![moop](https://forum.bristolbotbuilders.com/user_avatar/forum.bristolbotbuilders.com/moop/32/121_2.png) [@moop](https://forum.bristolbotbuilders.com/u/moop)\
**Post date:** [27 April 2024 17:35 UTC](https://forum.bristolbotbuilders.com/t/high-torque-motors-for-lifters/258/7 "2024-04-27T17:35:23Z")
</div>
If you’re able to make a suitable 3mm thick spacer you can add an extra reduction stage to a 22mm brushed gearmotor for 64:1 reduction, or you can steal the ring gear from another 22mm gearmotor and thin it down to 6mm to stuff in two extra reduction stages for 256:1 (probably a bit slow).
> [@ForkHead - Beetleweight Lifter/Grabber](https://forum.bristolbotbuilders.com/t/forkhead-beetleweight-lifter-grabber/124/25):
> I dragged Forkhead into the Hackspace today with a plan to cut one of the ring gears from a 22mm motor in half to make a 22mm brushed motor with 3 reduction stages (64:1 reduction) instead of the 4 stage (256:1) reduction thought I had from cobbling two of the ring gears together and stuffing extra reduction stages in. Taking apart the modified gearbox I almost immediately realised I’d actually stuffed 4 intermediate stages plus the output stage in for a whopping 5 st…
I’m still experimenting with this in my beetle, and the advice above is probably better, but it seems promising so far - I’m running two motors modified like this in parallel and they come in at about 140g combined.
I’ve got some of the 37D motors, but I’ve been avoiding using them because it’s my drive pods rather than the lifter that are actuated, so I want to keep the ability to control them separately if possible to get them back in sync if (when) the belts slip.
_[View the full topic](https://forum.bristolbotbuilders.com/t/high-torque-motors-for-lifters/258)._
