New Builder from Stevenage
Hi, my name is Sorin and, after years of watching the robot fights from around the world, I decided to start building an ant robot and start competing. I have watched many tutorials on what you need and how to build, but I would also like to connect with other builders, especially if they are from Stevenage or surrounding areas. If anyone from Stevenage or nearby wants to meet up for a coffee or a pint, please reply in this thread. I look forward hearing back from you roboteers!!!
Proceed to the train station on the first Sunday of the month. Take the southbound from platform 1 (I think) to Finsbury Park. Then take the 106 to Manor road. Seek out the building with a snooker club poster on the front, then go up the stairs. Provided it’s around 6pm, that is where Rock and Robots resides.
If you haven’t gone to an event yet I highly reccomend it. You can gather a lot of advice, and check out a lot of real life examples of what your robot could look like. I made the mistake of not going to any event before and ended up bringing a crappy flipper that was way to big, to heavy and couldn’t self right. I learned a lot at my first event though and came back with a vastly improved robot.
If you are after a nearby event to spectate, CAT 7 is on the 14th of Nov, and is free to spectators, compared to Rock and robots, which does require spectators to buy a ticket. CAT is located in Leighton buzzard. The most recent info about CAT 7 is here
And Rock and Robots is tomorrow, near-ish stoke newington train station, with more info here
Although, both Rock and Robots and CAT are sportsman, so if your aim is to enter into full combat, it would also be good to potentially spectate at ORCS, in Oxford on the 28th of Nov.
ORCS is quite a big event, and is free for spectators, so I would highly recommend attending if you are able. Here is a link to the event page on facebook
Yes just to add to this map / calendar of all UK events here
Thank you all, I was yesterday at the Rock&Robots event, super cool one. My only conclusion is that just one robot is not enough, I need more and different!
Joe, by any chance, do you know when you’ll have the Malenki nano boards please?
Malenkis are not recommended for people with less experience with soldering, but @IrregularJoe has a thread on how to solder robot parts, including Malenki-Nanos (Through-Hole pads).
Soldering is something that I do since I was 12 yesrs old, I am pretty sure I can manage this, but thank you for the heads up! :blush:
We should have more HVs this week. The rest will be a bit longer, had some issues with chip shortage then manufacture, it’s been a bit of a mare!
I’m a great fan of malenkis, (I’ve recommended them to pretty much everyone).
The FlySky compatible Rx chip it uses is currently a bit tricky to get hold of so I’m hoping a good supply of them is found and we’re back to the “good times” of malenki abundance soon..
Which reminds me I should get a spare HV..
(back to sales pitch)
The malenki is a great integrated solution for 99% of the roboteer’s needs.
it’s voltage telemetry alone is worth is, but the ESCs are good and the ICs chosen are particularly robust to abuse, and for the size/weight there’s little that comes close and it’s price is really rather good when compared to doing all the bits individually.
but be careful to insulate it once soldered up. it’s still a bare pcb and a stray battery or motor wire on something low voltage can still kill it, and it’s as ESD sensitive as anything else, and a dead malenki is a very sad day.. :frowning:
