Hi All! ive recently been using some Tegris and SRPP (self reinforced polypropylene) in allot of my builds and found it very useful for when I want something a little stiffer than HDPE but less stiff and lighter than carbon fibre (plus allot less splinters!)
so if you have any files you would like laser cutting from some SRPP feel free to PM on Facebook/discord or at mls_srpp_laser-selling@yahoo.com
Ive got stocks of
0.9mm (grey)
1.5mm (grey)
1.75mm
2.02mm (limited stock)
3mm
4.8mm (available end of july)
6.4mm (available end of july)
the 0.9mm and 1.5mm and a lighter grey (as seen below) the thicker parts range from black to a dark grey depending on the thickness, enquire for more details
max size of parts I can cut is 300x400mm (depending on available stock)
I can also engrave
(some very tasteful ant lids)
other laser cut plastics are available upon request such as thin hdpe up to 4mm, however this does not cut as clean as the tegris so is ideal for parts that will get munched (like huge style wheels) as well as acrylic
pricing depends on the thickness as well as the size and shape of parts, I can work with DXF STEP and drawings
I hope to hear from you soon!
