Looks like you can bend a piece of threaded rod to fit between the weapon bar and the chassis. A little 3D printed block with two holes through and a couple of wing nuts can secure the open end - if you make one end of the rod longer than the other you can put a locknut on the long end so the little bar doesn’t get lost - just undo the wing nut on the short side and slide the block up and out of the way to unlock it.
I don’t really have the materials to bend a threaded rod, but a similar idea with a printed U could work.
You don’t need any tools or materials, if it’s M3 or M4 you can do it by hand! 3D printed is fine too though - threaded rod just lets you use off the shelf bits like wing nuts.
people go to such great lengths to offer legal ideas, suggestions and help and the response is a wedged in silicone tyre. very cool.
I was talking about this with someone and we both agreed it was not a good idea for the Modulant vert lid to exist with no provision for a weapon lock, so I modified it to add a hole for a weapon lock. I also added some bracing to the support side, because it needed to be there anyway for the lock, and there’s no way that weird snail eyeball stalk thing will hold up to combat. You can find it here: https://www.printables.com/model/1914889-modulant-vertical-spinner-lid-with-weapon-lock
https://www.printables.com/model/1914900-2mm-allen-key-weapon-lock-modulant-vert-module
I also made a version of this top plate. This is set to up to use a 2mm allen key! Hopefully you have one lying around. Someone at any event you go to should have a key you can borrow.
You will probably have to wrap the end not going into the lock with tape to show its a weapon lock!
Hi I’d much rather have something that’s easily inserted and can’t be removed till it’s unlocked..
the tyre isn’t positively retained.. so isn’t legal.
Joe’s suggest of a U bolt is, however something that goes through the spokes or locks to the bar in a way it can’t be removed would be legal, ideally something that goes through the weapon and the chassis is the best thing.
like a bar/bolt going through the motor upright. in this picture.
This is the setup i have for Elephant Wheels, might want to use two nuts instead of one on the spinner side but other than that it does stop the spinner from rotating and does lock in and stay in, i really wouldn’t recommend the tyre aproach considering you would have to jam your fingers into the line of fire for your weapon
As for adding something like this to your design, its as easy was adding a hole to the side of your upright and then applying a fillet/chamfer to make it look nice and strengthen it to prevent a breakage… easy fix to add, if you like i have some 40mm m2 bolts and nuts i can bring with me to AWS for you to lock up with as these are quite long so you can slide them through a good distance
having it go through both uprights is better of course, so if you can design it that way it would be a big improvement to the safety of it, but one can also work under certain circumstances ![]()
Thanks, will borrow some at the event, unless your planning on going to the retro gaming festival thing the day before.
edit: Ordered them.
Just a note, M2 will work, but it’s a little on the small side, making the nuts more fiddly to put on..
personally I’d go M3 or bigger.. but that’s my preference, and I appreciate you may not have the space for the bigger hole on this tiny arm.
yeahhh that is true i know larger is better for the sake of the ease of putting the bar in, i just wanted to share my solution to help give ideas on what to do for the locking mechanism. I haven’t had too big of a pain unlocking and locking it thankfully, most of the pain is making sure i don’t lose it when its unlocked ![]()
M2 nuts are a pain though to initially fit onto the bolt… that i do agree on. Could definitely make something the nut fits into to make it larger and easier to fit on
I’ve printed chunky handles for M3 and larger nuts before to make them easier to screw on..
I slightly melted the hex hole once I fitted the nut so they don’t fall out too.
By the way, you accidentally made the allen key go directly into the weapon motor’s wires. Whoops.
