BBB Shop Antweight Parts CAD Files
Will update this post and the stores page as we go! If anyone can help with any CADs, greatly appreciated! :heart:
ESCs
Motors/Mounts/Wheels
Other Electronics
Weapon Stuff
Chassis
No longer stocked
  • BBB Dual ESC v2.2 - stl (thanks Jed)
  • Malenki Nano pre '23 - f3d (thanks Felix)
FS2A CAD can be found online - https://grabcad.com/library/receptor-fs2a-4ch-mini-1
I have a rough and ready CAD of the switch: switch.stl - Google Drive
Slightly better switch part.
Hi, I’ve made a reasonably accurate of the 44mm wheel:
Just noticed that the N20 model from the shop is a teeny bit off - the various gearbox plates weren’t quite lined up, so you can end up with things being 0.0033mm out and whatnot. Everything is parallel but seems they’re just shifted up/down relative to the motor body.
Probably doesn’t matter for most people but I’m a bit obsessive about things like that, but it could cause issues if you’re referencing off it in a model.
Corrected version here, plus I’ve tweaked a few of the dimensions based on the N20 currently on the desk in front of me (of course YMMV in terms of the exact sizes).
Thanks so much! Will update
I’ve made a rough cad of the v2.2 dual esc here
Modelling heatshrink is unpleasant, so I kind of gave up
Just added N10 CAD :slight_smile: - from Jack / Shakey
Hello
Would it be possible to get the Brushless motor file in a STEP. I can’t open the current one because I don’t have SOLIDWORKS.
Thanks
No probs have added that now :slight_smile:
Added High speed servo CAD from Tom :slight_smile:
Some of the geometry on the N10 CAD was broken and/or wrong. I’ve made a fixed version: N10_Motor v1.step - Google Drive
I’ve done a STEP for the blheli weapon ESC: https://drive.google.com/file/d/18_BVJXiDqOrnxgf1PQ083gkbOlTkD2fB/view?usp=drive_link
Just added CADs to the list at the top:
Added since last update:
