BBB Shop: New Products
It’s shameless plug BBB shop time! New products, check them out :slight_smile:
We’ve had a very exciting week as now we stock new shiny Repeat Drive Max brushless motors that are super popular in the US at the moment!
And our very own Gareth has made dual versions of the BBB beetle ESCs with all the great features of the singles (current limiting, 4S, BEC) but with built in mixing!
The shop’s back and delivering orders after our break!
With that we have a new product from the legendary Robson Robotics - Malenki-HV - all the great specs of the Malenki-Nano triple ESC & Receiver but with 4S lipo support and 3A per channel! very spicy.
Check it out: http://shop.bristolbotbuilders.com/malenki-hv/
More exciting new products coming soon :eyes:
An exciting day in UK antweights! We’ve teamed up with our pals at Nuts And Bots to offer N10 gearmotors - these are smaller and lighter than our N20s but with extra power and a little more toughness! Check them out: shop.bristolbotbuilders.com/n10/
New product! Repeat Robotics AM32 35A 6S Brushless Drive ESCs - for those who want that extra control over their beetle brushless drive particularly at low rpms, or even the option to go up to 6S, these are the thing for you: shop.bristolbotbuilders.com/am32/
New product! BBB Dual Ant ESC v3 - 40% smaller than v2, but still all the great specs and price - 4S support, 4A peak per side, center breaking, built in mixing, BEC and the only soldering required is the motor terminals! shop.bristolbotbuilders.com/bbbv3
Final few v2s are reduced to clear too ! :slight_smile:
New products gold bling time from Repeat Robotics! Eco hubs for foam wheels and screw hubs for custom wheels/weapon arms :slight_smile:
shop.bristolbotbuilders.com/eco
shop.bristolbotbuilders.com/screw
Both have two M4 grubs for securely attaching to shafts and we have them in both 4mm and 6mm bore options.
Having made our 22mm face mounts for the last 4 years now :open_mouth: thought it was time for a little update, v2 come in very stealthy black nylon 6 and are now 26x26mm (down from 30x30mm) so you can make slightly smaller chassis with it… Toyed around with different shapes but decided a square mount is the friendliest for mounting with hand built bots :slight_smile:
shop.bristolbotbuilders.com/mounts
We now stock the FS2A 4CH Flysky receivers both unsoldered (as before) and now pre-heat shrunk and soldered - this is mainly reducing the amount of soldering on the ant kit for new builders or reducing the fiddly soldering for people building larger bots :slight_smile:
shop.bristolbotbuilders.com/flysky
image image
New product! BBB AM32 Brushless Drive ESCs - awesome control for brushless beetle drive at a great price. We ran these in Lob-ster at the weekend and they ran great :slight_smile:
Two new beetle products in stock from Repeat Robotics!
Repeat compact - tiny & lightweight but powerful brushless drive:
shop.bristolbotbuilders.com/compact
Repeat AM32 dual - two brushless drive ESCs and a BEC in a tiny package perfect for beetle drive:
shop.bristolbotbuilders.com/am32dual
Example bot - Thomas’ Baby Dead Bod ran an AM32 dual at Rapture last weekend with Repeat Max on drive and it worked great!
Gah, just when I didn’t want to spend any more money. Picked up an AM32 dual as it is honestly going to solve a bunch of headaches and dip me back some precious grams as I fly to close to the sun with a new build. Nice expensive high end bit of kit I am going to make drive £2 aliexpress motors. Hype.
We’ve got the new Repeat Max v2s in stock!
New things:
  • all black look ooo
  • 3g lighter
  • stronger M3 face mounting
  • squared off faceplate for clamp mounting
  • Motor directly integrated to gearbox (more robust)
  • more powerful 2006 motor
    which is happier on 6S (pairs well with AM32 Dual for mad 6S machines)
Some new products on the shop since I’ve last updated here!
Durahubs & BBB 22mm Antweight wheels
image image
Scarab - dual beetle brushed ESC & receiver
BBB beetle 43mm wheels
Vortex - 80A AM32 beetle weapon ESC
But yes the reason I’m posting:
Forgot about this thread, worthy of revive because @Gareth’s been cooking again!
Brand new: BBB beetle single brushed ESCs v4: bbb.gd/v4 Tiny tiny at 50% smaller than v3s, now with configurable current limiting! Both a great option for standard 3-4S brushed drive set up, but also an exciting option for overvolting to 6S or even 8S with our 22mm motors!
v4_2 v4
Could be a cool option for overvolting 37mm motors for lifters/axes etc too! More info on the store page, but feel free to drop any questions here if you have any.
Recent restocks: 22mm motors, all things repeat & fingertech, malenkis, FS-i6S, DuraHubs.
New products since our last post:
Adjustable 2-8S mountable LEDs
FingerTech Carbon Fibre facemounts for 22mm & 24mm motors
Carbon Fibre Mounts for Repeat Max v2
Repeat 2004 Antweight Spinner Brushless Motor
SkyRC B6neo Lipo Charger
Lipo Safety Bag
New products!
Lynx Anti-Spark Power Switch
UK event legal, 8S support, reduces sparking recommended for high voltage bots.
BBB Beetleweight Dual Brushed ESC v2
50% smaller than v1 - with 8S support, configurable current limiting, gyro stabilisation and more.
Happy new year, new products time!
High Power N20s in 1500, 1000 & 100rpm
Over double the power of our N10s and nearly triple our N20s!
N10s now come in more speeds: 1500, 1000, 600, 300 & 100rpm.
Aluminium Servo Arm Horn - compatible with both ant servos we stock!
Repeat Gold Clamp Hub - in 4 & 6mm bore, if you want a hub to never ever slip!
Catalyst ESCs - Dual AM32 Brushless + FS2A receiver
catalyst1
Repeat 2836 - Beetle brushless spinner motor
2836
Repeat Pro 2006 - think repeat max with a shorter toughter gearbox
Repeat Beetle Servo - 40kg, steel gears, aluminium horn.
Repeat Inline BEC - 7.4V 5A with current & thermal protection
TVS Spike Absorber - for running catalysts etc at 5-6S
