This is what I did on a ~130mm bar because I was worried about the leverage on the m2 screws (and that was an 1806 with a 3mm shaft!)
it’s just a large bore thin wall ball bearing that has a little printed top hat cap that bolts on top of the motor. Not combat tested but you could try it for sub £5 and a chassis redesign.
I’ve been running belt drives and 8mm tubular shafts on gevious for a long time..
I’ve never even bent a shaft, (I started with 8mm od 6mm id Ti, and have swapped to Aluminium for weight, I’m also experimenting with carbon fibre)
I use 2mm section o-rings as belts, and as long as the pully groove is deep enough they seem reliable. (not 100% but pretty good)
latest itteration only lost a belt in the FC rumble this weekend.
I’m driving the grevious weapon with 1x 2750kv 1404 motor.. on 2S, with a reduciton on the belt.
the weapon hub (centre) is strong but with the size and low weight I have previously been pushing the arms were particularly vulnerable.
You could always print PLA for prototyping (and maybe TPU also) and order final parts in a different material? When I buy filament I usually add a couple of the absolute cheapest spools of PLA just for printing quick prototypes.
Yeah it definitely looks quite snug there, i imagine it’d make it a lot better for the motor since the energy isn’t all going straight to the motor, and is being distributed into the bearing and chassis too i imagine… I guess in theory if i can’t find a bearing to fit the motor i can design the 3d printed cap to fit any bearing i see fit, which would make it easier. Definitely a cheaper solution even if not a 100% problem solver, would definitely improve the shelf life of each motor i use… Chassis is already being redesigned anyways so wouldn’t be the biggest inconvenience to add that tbf.
I might give both ideas a try and see how they work, definitely want to try the gears most since it would eliminate the issue completely (in theory), even if it potentially creates other problems as a result…
just need to wait for some Malenkis to get back in stock as mine has conked out!
Yeahhh ive seen them work really well in other bots which is why i was tempted to give it a go adwell, just hard to find a lot of information about them unfortunately, other than the Ultimate Ninja thread on here there is not much for me to go off of, my main worry is whether there will be enough grip from the o rings to spin the weapon reliably… might head towards TPU gears even if it means the pain in the ass of designing my own gears to fit on both the motor and weapon bar…
Thats actually a good shout! Would still be a good save of money for sure even if im just doing PLA prototyping… might look into it just for that actually
I’ve got a selection of o-rings in different sizes so I can tweak the tension, re-printing with a slightly different pully diameter is another lever to adjust the tension.
I like having a ballence so that there’s enough slip for the motor to spin up (and the ESC to commutate quickly) and also slip on impacts (protecting my contra-rotating gears) and enough grip to transfer power.
TBH the tolerance isn’t too bad for this.. and micron (or even mm) errors in chassis and part tolerances is soaked up in the belt.
gears (if small) need a bit more precision.
Getting teeth meshing cleanly is doable, but at higher RPMs you may find the losses start to mount up and they get warm, or “self clearance”
The teeth are also susceptible to shock loads on impact where as a belt will slip.
The biggest advantage in my mind is the ability to use smaller (lighter) motors, gear them down, and remove impact loads from the motor.
Yeahhh thats the main advantage for sure with belts is that you don’t have to be as precise… Ive been having a look around on amazon for o ring sets and found some i could use, i just worry that it may struggle to spin the weapon up to a decent speed… do you have any pics of the setup you have? I think i can fit the set up in, just worried on the reliability when it comes to the weapon… I do quite like the idea of the belt slipping as it does minimise damage a lot.
this is grievous v3.4 and v2 both have fans integrated on the motor pulley for active cooling.
for G2 the belt is longer, moving the CoM further back over the wheels, for G3.4 there’s a pair of gears to provide the contra-rotation for the 2nd weapon (belt underneath mirroring the top when it’s not smashed!).
Thank you very much! I had a design for a belt system cobbled together, but definitely looks like i didn’t design it to scratch, will defo go with something more compact like Grevious 3. Will have to get something put together and see how it works, might do both and see which one ends up better… got plenty of options
This is what i’ve gone with for a temporary solution, redesigned my chassis to fit, i printed two different hubs… One is out of TPU and the other is ABS. I’m not sure what material is better given that both react quite differently to impacts, can anyone advise?
I know that TPU won’t break or shatter like the ABS one will, but would the TPU one be able to absorb the energy the same way or would it actually end up being worse…
Will be working on a non-direct setup in the meantime, this is just incase i can’t get it ready for AWS and ORCS in time
The indirect drive system has been ordered! I’m going with a belt drive system for the moment to see how it works out.
The plan is to go for a 6mm m5 shoulder bolt that screws into the chassis, which a bearing mounts onto. Then the pulley for the weapon mounts onto that bearing, stopping the bearing from just shooting down into the chassis during hits.
Weapon bar screws onto the pulley with 4 screws, and both holds down the bearing to stop ot shooting up during impacts, and is held down itself by the head of the shoulder bolt.
I’m hoping that on top of the 17g i already had saved, that i can save a little more weight with the other chassis changes ive made in order to make it all fit. If this works, i think it may be a real beast in the arena!
Will have to find out how well the o rings spin up the weapon, if it can’t or there is difficulty then i shall simply switch to gears… But hey, if they can drive a 150g robot, surely it’ll spin a 93g bar right? right???
Will update when everything arrives in a week or two, thank you everyone for your help
For orings getting the right ballence between tension and grip is important, but having 2 slightly different sized pulleys or belts gives you a way to tweak it..
I also use them as a reduction ratio with huge tolerances (compared to gears) and deliberate slip to absorb impact loads
I do get some heating in the belts, they’re definately not 100% efficient, but the slip in impacts saves damage elsewhere for me..
I also don’t need to run as a big a motor (which can also be a higher KV due to the reduction ratio), and my weapon is spinning on an 8mm shaft, which at ant-weight may be considered indestructible..
So there’s a weight/strength benefit there.
I don’t rely on weapon torque for self righting though, so on a small vert, it may not work as well.
Ah shoot, i didn’t even think about gear reductions or anything like that… the pulley on the brushless motor is smaller than the one on the weapon bar, unsure by how much tbh, does that mean the weapon is going to spin much faster? I was hoping that would only really be an issue if i was using a timing belt, which in hindsight i’m not sure why i thought that…
If it does mean a change in the weapon speed i will definitely redesign it to have both the same size, as this thing is already pushing the limits in terms of weapon speed…
Hoping a 6mm shaft will still fare quite well then if 8mm is virtually indestructible for this weightclass, quite happy with the overall setup… shame i can’t get more than a 9mm thread into the chassis though, christ knows how that’ll hold…
So the nominal diameter of the pulley (measure from the centre of the o-ring) for each will give you the ratio.
so on Grievous (3.4) its a 30mm pulley (28mm+1mm each side to get to the middle of the belt) on the weapon, and 11 on the motor, giving a 30:11 ratio (or 0.366), (gearing the weapon down from the motor)
As you can see the motor may spin at 23k RPM, but the weapon is only 8.4k RPM.
That reduction is entirely on the belt drive..
The reduction is actually what I want as the bigger diameter weapon then increases the tip speed, and I want more torque to spin it up (this is how I run such a big weapon on such a tiny motor)..
This tip speed is actually lower than I thought it was (just just updated the calcs) so I may pop a smaller o-ring on and make the weapon pulley a little smaller to bring it back up.
However it’s doing good damage right now, and it’s spinning up nicely, so maybe this is fine.
I’ve just printed a prototype asymmetric flail hub to try, which should double the bite and get more of that KE delivered to target.
It sounds like you’ve accidentally geared it the right way to make it spin up well.
I’d strongly recommend using a spreadsheet like the above to do the maths for you as it’ll both give you tip speed (to ensure you don’t break the limit, 600mph at ants right now) and help you calculate the optimum ratios.
I find weapon RPMs above 10k-15k don’t really engage well personally, so I’ve kinda given up chasing 400mph+ tips for now, but bigger diameter weapons will get the highest tip speed for a given RPM.
ahhhh okay, so because ive gone for the same kind of setup as you (unsure on the ratios, i’m gonna have to check this when my brain is functioning properly), i’m actually making the weapon SLOWER not faster, interesting…
definitely feels like im entering some veeery complicated territory that i don’t fully understand… which for a robot as big as it is for this weight class does worry me as it does put me in a gray area as to whether or not my robot is still going to be tournament legal… but its nice to know this current setup im using isn’t making the weapon faster, and is instead slowing it… I might tinker around with both the pulleys being an identical diameter, as i assume that would put the bot back to a 1:1 ratio, i’d just have to check if it would still spin…
Thank you for all this information, i’m not 100% on understanding since this is all quite a new area for me, but you are right… a spreadsheet would definitely make it a whole lot easier, will tinker around with everything when it arrives, prints should arrive tomorrow, but i will get an identical pulley sorted to keep it at a 1:1 ratio to play it safe on the tip speed as its closer to what i know for the moment, since the last thing i want to do is make this thing any scarier than it already is…
The main issue i have is that the oring i am using is way too tight, so tight in fact that it is pulling the weapon and motor into each other (the current chassis is a little flexable at the front).
Will revise this after Midland Mayhem in time for its debut event at AWS, will post all the details in a final post as soon as its ready
I’m not a fan of sliding mounts, as big hits can tweak it and you lose belt tension. It’s not such a big deal with o-ring belts as they’re stretchy and you get lots of leeway, but for toothed belt setups you can give yourself a little cutout section in the chassis that takes a printed/polycarbonate/composite plate that the motor attaches to, then just make a new mounting plate to tweak the belt tension. This is also a good way to decouple the heat of the motor from a chassis that might otherwise get gummy when it’s hot.
