Hi, I’m starting to build some new machines and need to clear out some space in the garage so I’m going to sell a few bits. Let me know on here or on Instagram if your interested in anything. All prices are negotiable and don’t include postage.
32mm Bore 100mm stroke low pressure pneumatic cylinder - £15
Comes with both top and bottom clevis mounts as it was used in my previous feather
40mm Bore 40mm Stroke Low Pressure cylinder - £10
Never used, the bolt in the top of the piston has sheared off but can be used anyway
1/4BSP 3/2 Low Pressure Valve - £5
Used as the fire valve in my old feather, the solenoid has been epoxied onto the valve body as the thumb screw broke
2x BBB 100mm Featherweight wheels £10 for both
Used in my old feather but still have loads of life left,
Complete featerweight brushed wiring loom: £40
This was a BBB breakout cable and the main loom on my old feather before I changed over to using brushless:
2x BBB Brushed feather ESC’s with xt60 connectors (one red servo wire cut for the BEC), power LED, xt60 battery connector and link, (also has unused power wires that could run to a weapon circuit etc)
