Finish your degree! (Or rush build a shell spinner instead)
Ok so as the title implies I am procrastinating my degree by rush building a shell spinner over the easter holidays. The reason why it is not anywhere near easter at time of posting is because I am no longer procrastinating by designing a robot, I am instead writing about it.
So since for new bloods this year you need to bring a new weapon type, I had to abandon my 30cm wide drum thing I was working on and pivot to something else. So logical decision for someone with finals approaching in a couple of weeks and still taking place literally through when the event is going to be, I thought lets make a shell spinner how hard can it be?
I gave myself 1 week over easter to do all of the design for the robot – without access to my printer. This is because my printer is located at my manufacturing and production facility (student accom) and I was staying at my second residence/holiday home (my parents house). This was also because I had only this week to get on the lasered order before it was sent off. I found cadding a whole robot without printing a single prototype or looking at a physical part to be quite scary at first but ultimately fine (I wont know it doesn’t work until I actually try and make the thing and ive not done that yet lol). Basically fingers crossed that CAD = Real life with 100% accuracy and zero discrepancies which I think is a totally valid and fair assessment to make. Given that it has been known to work that way precisely 0 times in the past for me, I reckon that means I’m “due” it to work this time or whatever that gamblers fallacy is.
Anyway heres the robot. Its like hella small and hub motor and 6s and stuff v cool. Some wajoo inspo except not too much otherwise then it would be good. Going under the working name of Trafik. Thought it would be a bit more traffic cone-y originally. Top of shell is 5mm carbon hopefully it won’t explode.
Here it is from the bottom. Idea is everything is bottom access because lol obviously. That stuff will all be covered up tho.
Current interesting bits and stats and whatnot
Compacts on 6s – hope and pray they don’t burn via current limiting because programming escs always goes so so well for me
Wep motor needs to be custom really but I absolutely cba so we’re under volting at 6s and hoping it doesn’t burn (theme starting)
No room for any electronics because the entire chassis is just battery so we will put them underneath the wep motor where it will totally be nice and cool
Everything is a massive heatsink to hopefully stop the burning
The bearings for the weapon stackup weigh more than the entire drive system lmao.
This space satellite lookin thing will hopefully keep it cool otherwise ill cry.
Anyway look I made some of it and so far cad = reality. Tune in next time im feeling like a big procrastinate for more updates!
Rhys as a university administrator who has to deal with students and assessments, this is incredibly irresponsible.
As someone who loves robots I say crack on. Love the drive setup in particular here.
this is so hecking cool i love the aesthetic
Wagwan nerds. Metal bits have come courtesy of the amazing Andy Russell and Lasered.
These can be seen below in figure 1.
Figure 1. everything is a heatsink
Still got to make the bloomin thing though mind. Some post processing still required on these also featuring my favourite activity countersinking hardox :heart_eyes::heart_eyes:
Yep, definetly writing the documentation for a degree assignment… seen below in figure 1.!
First exam of finals complete! 6 days to the next one and then 2 days to new bloods. Better get building!
Since today was an exam day I decided to treat myself afterwards to some more work of the robot variety…
Finished the weird satellite lookin thing which is the main shaft (50mm shaft letsgo) and also houses the motor and also also is a heatsink. It’s a turned piece on my baby lathe and 2 plates bolted on.
Also did a bit of work on the shell:
looks epic dunnit.
Had tons of fun countersinking hardox it’s my fave.
Current question on shell is what do I make that yellow bit out of? originally wanted to be high infill tpu but I built this off vibes and in a rush and well the hardox ring is too heavy for that. I think I can get away with 3 walls and 10% infill but I’m worried that when you spin that up the tpu will expand silly amounts from the centrifuge and eject itself.
That leaves me with Pla ST which it is in this picture. too shattery?? same goes for PC
Don’t really want to do nylon because I want it to be yellow and I’m not dying white nylon because faff
Also not got the time to mill from yellow HDPE.
Idk give me your thoughts people. hoping someone will just say yes send it to one of those and it’ll be fine lol.
Anyway that’s it for now off for more revision yay.
Sidenote: I thought rotavator was overkill with it’s weapon weight. This thing is looking like the north side of a kilo spinning mass…
I’d go for ASA If you are truly stuck, it’s light, doesn’t shatter and comes in various colours.
At that size you might have some issues with warping on the bed, but use a brim and either glue stick or painters tape and you should be fine.
this is so sick, i love a shell spinner
in regards to the material, id just send it with tpu. i think any other printed plastic means it explodes which is a worse failure option than it warping at top speed
yeah I think the same. because it’s such a big diameter I think the rpm should be low enough to stop it being a big enough factor to detach at top speed. Im also thinking that it shouldn’t matter how flimsy I make the print because thinner = lighter which means less expansion force anyway. all vibes and guesswork though hopefully it works at the weekend
If the vibes are bad and you feel like it’s going to creep and expand, something I (and others) do to stiffen my TPU parts is embed stiffer material inside them. Fatal Deviation’s lifter has a bunch of 2.5mm piano wire rods jammed through it, and I’ve also been playing with carbon fibre rods and composite plates inside TPU and PEBA parts to keep it stiff in one direction but compliant in others.
ooh that’s neat I like the idea of adding a ring of piano wire inside the print. deffo won’t have time to do that before Saturday considering I have the majority of the robot still to make but a cool idea for future!
Exam yesterday went well so I’m giving myself today to work on the robot. event is tomorrow so I reckon I should probably start building the thing lol.
Top and bottom plates looking cleannnn
Just replaced the pla standing for the Carbon on the shell too. You’re looking at 12mm hardox and 5mm CF. The Tpu is purely decorative/ armour since there are aluminium blocks inside which keep everything squared up and rigid. And before anyone says anything about bolts in shear the bolts do not carry the shear load there are dowel pins for that, the bolts just keep everything sandwiched together.
I’ve got the parts for a backup shell too so hopefully if all goes smoothly I can speedrun making another one
That logo looks awesome! Are they stickers by any chance?
Yes they’re stickers! wanted them to be bigger but that’s the largest you’ll be able to see through the shell lol. Since I had to get a whole sheet I’ll bring the rest in case anyone wants one
Wiring is now done!!!
One of the least enjoyable experiences of my robot career.
You’re looking at wep ESC plus 2 drive esc plus receiver all squeezed into a 7mm deep cutout the size of the wep motor. I think this is about as compact as it can get!
With the inner robot assembled it looks like this:
everything in this picture weighs under 600g!
then there’s 150g of wep bearings and a full 750g of shell specs getting close to the 900 spinning I have on rotavator!
More updates still to come…
Did you get a company to do them? I’ve seriously been considering getting stickers to put on my bot too.
Also the compactness of that wiring is making my eyes water. One day I hope to have as much confidence to cram the guts of my robots into such a tiny space as you do… :smiling_face_with_tear:
Only gone and done it haven’t I
Since I finished this almost 12 hours before the event even starts I’ve had time to make a fun lil locking bar and cradle modelled after a roll of electrical tape I found was perfect
Ok little epilogue now. Apologies it’s even more word vomit then usual and barely any fun pictures.
I took this thing to new bloods where it performed mostly on the lower end of “basically fine” with some ok bits. I also threw it into the last dojo of the year (or season or whatever) where it performed fairly poorly as expected.
in short this is where we’re at:
What I liked about it: looked pretty cool, feels quite engineeringy
what I didn’t like about it: most of it - including how it wasn’t that good and how it was impossible to drive
what’s next for it: Paperweight/ wall decoration probs lol
So the big one is the why - (this was not the original plan)
Why spend all the time effort and money on something you’re going to run at 2 events and then bin off? Love of the game lol. let’s dive into the events.
New bloods:
basically it was ok. robot seemed pretty tanky (not surprising seeing that it’s like 50% hardox ring). the spinup wasn’t terrible at all AND what’s more it took aaaaages to spin down after each fight (ig I’m certified epic at bearings). Electronics did not instantly catch fire as I expected I think due to my awesome everything is a heatsink stackup and it actually looked really reliable. It also looked really cool did I mention that? Not many issues, but big ones:
big issue 1) Impossible to drive/ you can’t see where the front is - When the robot spins up it torques underneath the shell and the front changes position slightly. When the shell hits anything the robot torques underneath and faces a complete random direction. this makes chaining hits basically impossible. I couldn’t have a self right bar stick out the top like on a traditional shell because due to the hubmotor thing I basically had a live shaft so nothing to mount it to. I tried to fix this in 2 ways firstly with an indicator LED which would shine under the shell like a headlight/ ground light. this didn’t work as the shell sits like 2mm off the floor and literally no light could get out. other thing I tried was a big red arrow on the top plate but it wasn’t really enough. I found myself just kind of guessing most of the time and jamming the stick in random directions to work out where the front was in order to drive it around. drive was pretty whippy though what with it being compacts on 6s and all
big issue 2) it really didn’t hit that hard at all - I think because the motor was so undervolted it was hitting just a fraction of theoretical speeds and therefore my rpm : tooth ratio was just way off. I think I was effectively hitting people with the smooth bit of the shell and bouncing them off slightly only for the tooth to come round and only just clip them. idk though. when I hit the wall all of a sudden it seemed to transfer tons of energy and did violent pinball things. This issue is pretty big though. We want ideally to increase the real speed of the shell and increase the tooth size. keeping the hubmotor design this is not very easy. basically skipping all the nerd stuff the verdict is custom EXTREMELY low kv wep motor on insane number of battery cells and a separate lower voltage set for the drive. as you can see now this is moving towards electronics nerd shit in the same way rotavator is and in the same way I do not want to deal with. So I think I’m gonna call it a day and build something simpler like a punching vert instead. (current plan after the 12lber)
After new bloods my thinking was:
Issue 1 is solvable with some iteration etc. Issue 2 needs ground up redesign and I cba so let’s whack it into another event and trash the thing.
And trash the thing we did!
In my 3rd fight of the day against Adam’s new and really nice looking horizontal driven by his brother. the bot was called glorp or gloop or something either way it was spinning at the perfect height to completely miss my hardox ring and instead hit my 1 wall tpu and juicy shell hardware stuff :frowning:
we had a couple of good engages and moments where if I’d been able to see which direction was the front of the bot I reckon I could’ve found some openings. This was before glorp(?) tore straight through the weak part of the shell bending the alu and hardened dowels in towards the chassis. because the shell was at top speed this caused the munched parts to tear through the inner robot as the shell span, tearing a nice horizontal cut around most of the chassis, through a repeat compact and then the battery leads (sadly no fire). picture shows the chunk missing from the compact but not the extent to which it was truly split open and busted. sadly I can’t include any others as I gave it away
Anyway that’s basically it. I can confirm that shell spinners are hard and good shell spinners are more effort than they’re worth which is why I’m not making one and definitely not for any other reason.
if it has magnets, you can use it to hang your diploma, would be in the theme haha.
i love shells, tough that it didnt work out as planned. It kinda hit like the old like 2005 shrederator, like more nibbles than big hits. i do hope it at some point returns, maybe as an ant it could be funny?
DRG Eindhoven in september??? #Spon #ad
deffo won’t be built for this time but will 100% consider for next
