ForkHead - Beetleweight Lifter/Grabber
ForkHead drew a brutal lineup at SCEETLES 2, but it will be back.
The first fight was against Qry About It, a wide 2WD vertical spinner. The first engagement seemed to go well with the prongs finding their way under QAI, until the disc made contact with (I think) the left prong. This ripped both TPU fork mounts off of the prongs leaving me with the damaged bare prongs for the rest of the fight.
forkheowd
The bot kept going but unfortunately I was too slow in self righting, resulting in taking another hit while trying to get away. This second hit left the drive pods out of phase with each other for a while. As the fight continued it weathered a bunch more hits but didn’t managed to get under Qry About It again.
Later on and missing the end of one prong and the belt that actuated one drive pod I was able to hit the pit button. In the last 30 seconds I attempted to get Qry About It between the drive pods and push it towards the pit, but the combination of Qry About It’s sticky tires and the rounded rear armour on ForkHead meant this didn’t happen.
The fight went to a judge’s decision which deservedly went to Qry About It.
Full Fight
Apart from the prongs, one of which was torn off and one of which was mangled, and some bent screws, most of the damage was cosmetic and I’m pleased with ForkHead’s ability to take a hit. Unfortunately the drive mechanism that rotates the drive pods is quite exposed, and the countershaft that keeps both sides in sync took a hit and became bent.
I spent the next hour or stripping the bot down to replace this shaft before finding that my spare countershaft was the wrong length. Having pushed my next fight back twice due to the amount of work needed to get at this component I had to settle for putting ForkHead into its next fight against BadFutherMucker with the countershaft removed and the drive pods spinning loose. I added some TPU armour to try and protect the remaining pod drive bits, but this ended up doing basically nothing.
Thanks to the way the drive pods behave in reaction to my 4WD system this went badly. This is obvious to see before the fight while I’m trying to get into a ‘both drive pods pointing backwards’ situation.
Full Fight
I managed to avoid taking a hit from BFM for the first 15 seconds or so of the fight, before getting thrown around quite a bit (and taking out a light).
I had to tap at 50 seconds because I had line of sight to ForkHead’s battery, and I suspect I also had no drive at that point.
ForkHead was looking very unhappy after this fight. Hits to the drive pod had broken the aluminium standoffs between the sides of the drive pod (or the screws holding them) which had released the captive front axle. Having these act as shaft support for the drive motors was I think a bad idea, as the remaining standoffs just acted as a force multiplier sending further impacts on the outer drive pods straight into the motor shafts.
The core of the bot was still pretty much intact (after replacing/tightening screws) but with two MegaSpark motor shafts sheared and both 22mm drive pod rotation motor shafts bent I decided to forfeit the third fight (which would have been against another vertical spinner, Ultra Violence) as it would have taken a long time to strip down and rebuild the robot to replace the drive motors, and I didn’t want to sacrifice another pair of MegaSparks without making some improvements.
Despite coming home in pieces ForkHead took home a banana for scale tropy for Best Design and on balance it performed well enough that I’m intending to continue developing it.
Obviously I’ve got a long list of improvements to make for the next event, including:
  • Armour
    • Replace front armour panel with a wider piece that interlocks with the side armour
      • This should transfer impact forces straight to the side panels instead bending screws and ripping off the top/bottom armour
      • Wider panel keeps attacks from the front out of the pod drive system
    • Separate the prongs from the side panels
      • More modularity and weapon options
      • Avoids integrating something that’s likely to take damage (prongs) with something that’s hard to replace (side panels that everything screws to)
    • Think properly about forks and setups
  • Drive Pod Control
    • HTD5 belts worked well
    • Additional gear reduction for the pod drive motors (I already knew this was an issue)
    • Remove the ‘through body’ countershaft - it was awkward to replace and clunky
    • Come up with an electrical rather than mechanical system to resynchronise the drive pods (as loathe as I am to bring custom electronics into it)
      • Hopefully just an endstop switch for each side, with an RC switch in series to enable/disable them
  • Drive System
    • Replace outer drive pod with a thinner, non-structural armour panel
    • Run the front wheels on dead shafts so the outer panel is non-critical
    • Slightly shorten motor shafts and remove end support
    • Machine some custom hubs
      • The current version is running FingerTech Hubs and 3D printed GT2 toothed pulleys press fit onto the shafts due to a lack of time. I considered adding some drive pins in holes in the hubs/gears, but I think it’s time for a custom solution.
That is some brutal damage! Glad you’re continuing this robot, it’s super cool. Interlocking panels for the win :slight_smile:
You deserve major credit not only for doing a tricky and unusual design, but also competing in such a spinner-heavy event and keeping the bot running. You learn so much about your bots from the tough matches, and your summary at the end makes it clear you have a great eye of what works and what needs to change. Very well done, can’t wait to see what you bring to your next event!
I took Forkhead version 2.5 along to North Down Havok where we ran it as a mini-bot alongside Perillelogram. Perillelogram gained a 360 lifter to meet the active weapon rule, and Fourkhead gained a U in its name. Together they formed Squadrilateral with a coherent 360 lifter and number four theme.
This version of Forkhead had the drive pod armour modifications from my list above, but was still running the old drive pods and lifter mechanism.
To work around the lack of grunt in the lifter mechanism (and lack of time to do anything different) I ended up bodging two gearbox housings and 3 intermediate drive stages onto a single 22mm brushed motor. This has serious torque, but is unsurprisingly glacially slow.
Having picked up some more motors at the event, and because I’m drowing in dead gearboxes now, I’m going to try cutting one of the housings in half to give an in between version with 3 reduction stages rather than 4. I’ll also try running independent motors on each side rather than both driving a countershaft. Assuming this gives a decent result I plan to make an interposer PCB that combined with a couple of switches to detect that the drive pods are in the neutral position will make syncing the drive pods back up after a hard hit quick and easy.
During the event Fourkhead took some fairly hard hits, and several hard slams between a fast moving featherweight and the arena walls but came off basically unscathed.
The only damage was to the already messed up tires that I hadn’t changed since SCEETLES - the chunks that were hanging by a thread finally came off - and one of the motor side drive pulleys which got wallowed out was locking up the front wheel. I just removed the drive belt and ran it 3 wheel drive for the last fight.
Despite the size disadvantage and some control issues with the messed up wheels it had a few moments where it was able to be an effective nuisance, getting under the competition and causing trouble. At one point it looked like I managed to pull Barrog away from Perillelogram and prevent it from being flipped into the OOTA zone, though on rewatch the footage I suspect Barrog actually just backed up. On the other side of the coin I felt like I lost us that fight by driving under Perillelogram and getting us both immobilised, though again after rewatching the footage it seems like Barrog pushed Perilellogram onto my so I’m maybe less responsible for that than expected.
All in all it was fun and maintenance free way to test out the first stage of changes to the robot, and the armour changes and DIY barrel nuts holding the rear armour together it seemed to hold up to punishment nicely.
I’m looking forward to the BBB Pub Beetles event which feels like something Forkhead could do well at, especially once I get the lifter working better and follow through with the drive system changes to save a bunch of dead weight.
I dragged Forkhead into the Hackspace today with a plan to cut one of the ring gears from a 22mm motor in half to make a 22mm brushed motor with 3 reduction stages (64:1 reduction) instead of the 4 stage (256:1) reduction thought I had from cobbling two of the ring gears together and stuffing extra reduction stages in.
Taking apart the modified gearbox I almost immediately realised I’d actually stuffed 4 intermediate stages plus the output stage in for a whopping 5 stages, giving 1024:1 reduction. Suddenly the glacially slow lifter action at North Down Havok made perfect sense!
After I’d gotten over this surprise I was left me a choice between cutting one of the 10mm ring gears in half and making two 3mm sections (for two 3 stage gearboxes), or milling two of them down to 6mm (for two 4 stage gearboxes). If the version I went for worked then great, otherwise I’d wasted at least 1 ring gear either way.
After staring at the parts for a few minutes and wondering how make the workholding for the ring gear happen I realised that the output stage had at least 3mm of thickness in front of the sun gears. This meant I could just make a 3mm spacer with no teeth on it, with no need to sacrifice any motor parts to try out the 3 stage gearbox. Conveniently while clearing out my storage box at the Hackspace I happened to find some 22mm aluminium bar which was perfect for the job.
After a little bit of cursing at random lathe issues (stalling when the drill broke through and blowing a fuse…twice, and the annoying size gap between my largest drill and the clearance needed for my smallest boring bar) I had a couple of 22mm OD, 13.8mm ID, 3mm thick spacers with some holes in roughly the right places and I took them home to try out.
After installing two of these in Forkhead these had enough grunt that I couldn’t backdrive them by hand and decent speed. Annoyingly but unsurprisingly the HTD5 belts were the weakspot again, slipping just on the verge of lifting the chassis of Forkhead v1 (about 1kg with the guts removed).
forkhead_just_lift_320
Time to make some larger pulleys, see if I can get them to fit the belts better, and then maybe add some tensioners.
Operation Deadshaft is proving tricky.
I was hoping to modify some Fingertech hubs to sit on a 6mm ID 9MM OD roller cage (since I couldn’t find 6mm ID ball bearings with a small enough OD), but this doesn’t give any sort of axial support so I suspect it would be a disaster. I could add some bearings outside of the hubs, but I’m not sure I want to accept the extra width (and extra vulnerability to them getting caught by a spinner).
For Pub Beetles I’m going to stick with a captive live shaft for the front wheels and have a go at custom hubs with integrated pulleys. Unless it turns into a disaster I’ll be switching back to round belts for the drive since I don’t want to remake the drive pods for this version and the spacing’s not really right for GT2 timing belts. If I do decide to go back to timing belts I’ll be enlarging the 3D printed pulleys I’m using and shortening the drive pods significantly with the spacing on the redesigned pods setup correctly for the pods I have instead of working around past decisions.
I had a go last night at machining some Fingertech compatible hubs on the Hackspace’s Denford CNC lathe and I’m calling it a moderate success.
This is the first pass, before drilling the through hole or parting off, with pass 2 (currently untested) being to mount the machined hub blank on a collet block and mill the locking tabs.
I’ve left off the fins that lock the wheel in place for this version, but I think I’ll leave the material for those in on the next one and see if I can mount it in a way that gives me access to mill out the material in between with a 2mm ball endmill.
Annoyingly I discovered the travel limit on this lathe stops the parting tool way too far from the chuck, and weirdly on the first attempt it just decided to silently stop moving on that axis upon hitting the limit, so the first part I made lost the integrated pulley. It might come in handy later though.
Having proved it out I made a couple more. The one on the left parted off correctly. The one on the right hit the same travel limit issue, but I stopped the program before it caused a disaster and will part it off later. I think the 6mm through hole is a bit conical because dialling the drill stations on the lathe’s turret to be on centre is tricky, and because the approach I took to peck drilling was less than ideal. Hopefully I can sort that out on the next attempt.
I’ll make some tweaks and add the fins then try again at the weekend, and hopefully see how the milling part of the process goes. :slight_smile:
I’ve been really impressed by how this bot has developed, really cool to see all of the gearbox and milling shenanigans. It’s definitely not an easy design, but it’s cool to see you making progress with each post.
P.S. Me and my Dad are once again sorry for the late slam at BEV’s!
Haha, definitely don’t worry about that. I threw it in at BEVs as stress test and it came out basically unscathed apart from the already chewed up tyres getting more chewed up. :slight_smile:
I made some hub progress on Tuesday. I’ve got the front pair mostly done (just need to lop off an extension I added for workholding and tap the hole for the set screw).
First step was turning a blank for them. Of course I realised the moment I finished the second one that I could have saved a bunch of time material if I’d flipped them end for end and done this in two setups.
Next up I used the 10mm extension on the back to hold them in a collet block so I could manually index them for milling. The first operation is milling the locking tab, adding an octagonal feature on the back.
I also added a little circular notch to make it easier to find the set screw when the tyres are on - this is a minor thing that always annoyed me with the Fingertech hubs.
locking_tab_smsh
After that there were four setups with the collet block on its side to cut the fins. I ended up doing this twice since I was using two tools (a 4mm and 2mm endmill) and there was some misalignment because the block of plastic I used to align the collect block on each pass wasn’t very repeatable.
If I make more of these I’ll make a better registration fixture or hold the collect block in a vice, and also cut out the 4mm endmill and do the whole thing with the 2mm. Running a 2 minute machining operation 8 times with 5 mins of setup in between wasn’t how I would have preferred to spend my evening. :stuck_out_tongue:
With these finished I’m pretty pleased with the results and they’re definitely usable. I did wish I’d added a few more stepovers on the final milling operation for a smoother surface, and the misalignment was obvious but not problematic.
These fitted nicely on the tyres, and as an accidental bonus the fins that lock into the tyre are a bit more aggressive, meaning that a tyre that was wallowed out and just span freely on Fingertech hubs was a nice tight fit and would definitely be usable on these hubs.
These are the front hubs and I’m calling them a moderate success so I’m going to go ahead and make a set for the rear (with a larger pulley to match the surface speed of the wheels), and I’ll test out the improvements I came up with on the second set.
It’s probably a coincidence, but I’m suddenly seeing a lot of adverts for CNC lathes with live tooling and a Y axis for mill-turn operations all of a sudden. Feels a little like I’m being taunted with an unobtainable but much easier way of making these parts. :joy:
In between prep for a Bodgebots workshop I’m running on Wednesday I’ve just about found time to get Forkhead ready for Pub Beetles.
I’ve got the new hubs installed with the old drive pod setup, and slightly wider spacers. The hub that was missing it’s fins got some threaded holes through the pulley so I could screw in some long grub screws as a fin replacement. It’ll do for now until I find time to make a replacement.
I’m looking forward to everything not being covered in a fine dust of foam wheels mixed with a small amount of the toothed belt that used to rub on them.
Boards for the limit switch interposer arrived but I’ve not found time to assemble them, do any programming, or figure out how to fit limit switches on the bot.
The independent prong drive is in though, with some little aluminium dead shafts that screw on where the countershaft bearings used to fit. The pulleys have some pockets for bearings.
It’s nice not having a rotating shaft running through the electronics bay, but a minor concern is the two motors (running from a BBB dual ESC) don’t seem very well matched.
I’m hoping this is just because I used one older and one new motor when messing with the gearboxes. I should find time to swap the struggling motor out and hopefully that issue will go away. If not it’s still better than the prongs getting permanently out of sync after taking a bit hit.
Looking forward to seeing how it works out at the weekend!
Pub Beetles was a great way out and I finally managed to win a Beetleweight fight, then my second and third. :open_mouth:
Forkhead seems to be mostly performing. I still need to look at improving the lifter drive mechanism as it doesn’t quite do the job before the belts slip, but outside of that the only issue I had was a cursed wheel hub. More on that later.
EMP vs Antithesis vs Forkhead
The first fight was against EMP and Antithesis. I mostly stayed out of it, fearing Antithesis’ crusher, until Antithesis ran out of juice. Things seemed pretty even vs EMP, but I threw away the win by reversing into the pit almost exactly as the fight ended. It went to the judges (crowd) but EMP quite rightly took the win.
Carbonite vs Forkhead
The second fight was against Carbonite, which was unfortunately missing a prong after an encounter with a spinner earlier on. I had a very slow start. I got distracted by the match countdown immediately running into an admonishment for the spectators to stay back from the arena. It took a moment before I remembered I could just look at the very nice match start buttons and see if the countdown was running. :slight_smile:
Once the match got started there was some extended grappling. I was hoping I could get the prongs under Carbonite as it’s very wide and shallow making it a perfect candidate to get right up on the prongs where the lifter has a bit more mechanical advantage. Although that never happened I was able to get the prongs under them enough that I could push them towards the pit for my first ever Beetleweight win!
Forkhead vs Fatal Deviation
My third fight was against pitmate Fatal Deviation which was improving with every fight. Unfortunately for it it was the perfect width to run up Forkhead’s prongs allowing for a very early suplex from Forkhead.
I made some attempts to get them back over and continue the fight, but unfortunately the lifter belts were slipping and none of Forkhead’s fancy moves were able to pick them up leading to a second win for Forkhead.
In the middle of the fight you can really see that Forkhead is crabwalking. This was down to one of the custom hubs slipping. The one that came out nicely performed great throughout the day with zero issues. The one that lost its fins (I set the tool offset wrong) didn’t quite have enough meat around the set screw and I’d had to tighten it after every match,
Fortunately I did a shakedown run a few days earlier and stripped the setscrew on the same hub then, so I’d noticed the issue and I added a new M4 hole and an additional M3 hole for emergencies. I was using the second M4 hole for the first 3 fights and it finally gave up against Fatal Deviation.
I’d also put some threaded holes through the pulley on this hub, to provide some sort of fin-like protusion for the wheels to key into, and 3 of those decided to come loose during this fight too stripping out the inside of the tyre.
I swapped out the tyre and switched to using the emergency M3 set screw hole and had no issues with that hub for the rest of the day.
Round of 8: Forkhead vs Delta V
To my surprise I found myself in the round of 8 and matched up with Delta V. This fight started really well, I managed to get Delta V up on the prongs a couple of times, but due to belt slippage couldn’t quite turn it into a suplex into the OOTA zone.
The match ended abruptly when Delta V slammed Forkhead into the OOTA zone wall and my link popped out inside the robot from the impact.
Despite the defeat I’m really pleased to have made the round of 8, and quite happy to have lost due to something fairly unavoidable as opposed to bad design decisions (though I might think about ways to secure the link better without making it difficult for the marshal to remove).
Whiteboard: Forkhead vs Flick! vs AOB vs Art Attack
I signed up for a non-spinner whiteboard and ended up in a really fun fight against a lifter, a spring flipper, and a paintbrush waggler.
Forkhead managed a few good pins, and an extended wrestling match with Flick! before pitting Art Attack, dodging AOB which pitted itself, and then pitting Flick! (and nearly itself) when Flick! unfortunately landed on my prongs after self-righting.
After this event I’m really happy with the bot, but I’ll be making a less cursed replacement for the dodgy hub (and at least one set of spares) and looking into ways to get the lifter working better. I may succumb to the chonky HDPE gear meta!
Another outing for ForkHead yesterday at Summer Showdown. Unfortunately not as successful as Pub Beetles, but some great fights and no short fights. This event report is from memory before the video goes up - so we’ll see if my recollection matches reality. :slight_smile:
First up was ForkHead vs Huhnerfleisch vs Lawnmower. Huhnerfleisch is a croissant and/or alien spaceship shaped robot with a pair of waggly lifters, and Lawnmower is a terrifying metal box with a beater bar on the front.
Early on in the fight ForkHead and Lawnmower made contact and the beater bar ripped one of my lifting forks right off. Also early in the fight Huhnerfleisch got delinked leaving me to fight Lawnmower on my own.
After a few more encounters with Lawnmower I lost the other fork which had me worried it was game over.
I decided to flip ForkHead’s drive pods backwards to keep the front wheels away from the beater bar, and this turned ForkHead (just Head?) into a surprisingly good rambot. I managed to pin Lawnmower several times in this configuration and almost got underneath it at one point. Sadly Lawnmower’s driver did a good job of stopping me pushing it into the pit and the match went to a split judge’s decision in Lawnmower’s favour.
The only major damage from this fight was the missing forks, and a damaged belt that needed replacing. The missing prongs were a big concern - I’d switched to modular versions after SCEETLES, but the m3 screws holding the prongs on had held tight and ripped the front of the side panels off instead, including the material the locking bar goes through.
Since I didn’t have spares for the chassis sides (it’s basically a full teardown and rebuilt to replace them, and they were the last thing I expected to get critically damaged) I settled for drilling some holes and screwing them on however I could and hoping they’d survive the rest of the event as HDPE swiss cheese.
The second fight was vs Lilith, and I wished I’d had time/presence of mind to switch out for a new set of forks before this fight.
Lilith is a very wedgy lifter and very well driven. I had a hard time getting underneath, and Lilith managed to drive off of me the one time I managed to lift it.
Some time during the second round the arena’s pit had broken, and there was an attempt to get a consensus from a very crowd about whether the pit should be left up or down until it was fixed. The pit ended up being left halfway down with a 10 second countout for pitted robots to get out.
ForkHead ended up in the pit a few times, and its ability to climb out of things was finally put to good use. Unfortunately I never managed to push Lilith in there (despite a few close calls) so the match went to a judge’s decision in Lilith’s favour, which was entirely fair given the pit visits.
The final tournament fight of the day was against Schism, an overhead saw. Going in to this fight I was worried about hits to the top plate, so I tried to avoid the front of Schism.
This fight was a lot of dancing in circles with the forks tangled together, with Schism trying to get its front pointed at me, and me trying to get at the side of it for a lift or pin.
Neither of these things quite happened. I did get a fork stuck into the front of Schism’s hammer saw pivot one time, but couldn’t turn it into a pin. I did also end up driving over Schism a few times, and at some point one of my drive belts got cut, leaving me with 3 wheel drive.
After a quite long fight I found myself having lost the other drive side too, and stuck around the side of the pit. With only one drive wheel and either being counted out or the end of the match being counted down I decided to chance it and see if a fast blip of forwards on the one remaining wheel (back right) would help and I ended up in the (repaired at this point - unfortunately for me) pit. It’s possible that sending it backwards could have climbed the wall and gotten me out, but the wheels were down to foam at this point so unlikely.
Inspecting the robot after the fight there were a few bits of damage from the hammer, but the main issue was the latex had come off of both wheels and on the right side the hub had slipped away from the motor and both the latex and a very stretched drive belt had wrapped around the motor shaft, locking the wheel up.
Despite zero wins I’m glad to have had 3 great fights against tough competition, and I ended up replacing the drive belts and throwing ForkHead (The Splits) into a whiteboard against Huhnherfleisch (German Chicken) and Heratoss (Blue Pokemon).
Unfortunately with all the other maintenance needed I hadn’t spotted that the gears on ForkHead’s lifter motors had both wallowed out, leaving me with a very insipid lifter and limp drive prongs, so despite some extended grappling I didn’t really manage to do much in the fight and it ended in a bit of a 3 way stalemate.
Thanks to the BBB guys for putting on an event that was worth 5 hours of trains! ForkHead will hopefully be back with some minor improvements and a few more spare parts on the making/packing list.
Forkhead’s getting a bit of a rebuild for Champs 2024. Everything was looking tatty from various encounters with violent robots, and since Lawnmower tore the front off the chassis sides it needed to come apart anyway.
The lifter has been steadily getting there over the last year or so of improvements, but to give it more of a chance I picked up some Ranglebox RB180 brushed motors. After getting the pinions of my BBB 22mm motors with a blowtorch, a hammer, and a specialised robot gear puller (a bit of mild steel with some slots in) I was able to press them onto the RB180 motors and trim the shafts to fit the BBB gearboxes.
These motors have nearly double the stall current, but also double the RPM. I figured if they don’t work with the current 3 stage modded gearboxes I can add an extra stage (4:1) and I’m only halving rather than quartering the final speed of my lifter.
I also picked up some metal gears to replace the 3D printed ones, and tweaked the replacement chassis sides so the motors would sit further inboard. This was partly to make room for the section of the gears where the set screw would interfere with the mesh, and partly to remove the need to weaken the chassis sides by having a thinned out section.
A quick test of the lifter shows some promise. :muscle:
do_u_even_lift
I changed how the front armour interlocks with the chassis sides at the same time, the chassis sides now just have a peg that sits in a slot on the front armour, instead of a notch that drastically weakens the chassis sides.
The forks now mount to some blocks of TPU screwed to the front armour. Hopefully this puts the point of failure in the right place and next time the forks get ripped off it won’t need a complete rebuild. :joy:
The drive pods got a refresh (and some pockets). These were a total mess since they take the most hits in a fight.
Finally, and because I’m procrastinating from getting Time 400 Crab ready for RoboDojo sportsman feathers this weekend, I spent some time designing some new wheels. The liquid latex worked great at Summer Showdown for grip, but I lost a fight when it tore off and jammed up the drive.
The new wheels are printed in TPU and overmolded with shore 40A polyurethane rubber. They slip over a modified version of my hubs and screw to the hub’s integrated pulley with some M2 screws.
In a quick drive test they seem to work well, though I’ve a few issues to solve with how the front ones get locked to the hubs due to limited space.
Time for a long overdue update!
My first fight of Champs 2024 was against hammersaw Schism and chainsaw-wedge-bot Monterey Jack.
This fight got of to a slightly awkward start where I accidentally moved one of the drive pods out of place before the countdown then had to wait for the fight to start to sort it out. Fortunately Schism and Monterey Jack went for each other giving me time to get the bot sorted.
I managed a promising pin on schism and managed to lift it enough that my front wheels could make contact with the wall, helping Forkhead’s lifter flip it over for a nice throw.
After this the fight got a bit more chaotic and I got a bit heavy handed on the sticks with Forkhead wheelying all over and ending up on top of Schism quite a lot, which was not ideal for the safety of my drive or lifter belts.
After a bit of chaos Schism ended up on top of Monteray Jack and I was able to push them both towards the OOTA zone and some combination of Forkhead’s lifter and Schism’s saw arm carried Schism over the wall and out of the fight.
Once we were fighting 1:1 Forkhead seemed to have reasonable success getting under Monterey Jack and I eventually managed to trap them between the prongs.
Monterey Jack seemed to be struggling with traction a this point and I was able to push them into the pit for my (and Forkhead’s) first win at Beetle Champs.
Damage from this fight was fairly minimal and with this being an early fight it was a long wait for the remainder of the 1v1v1s and the redemptions before Forkhead’s next fight vs bar spinner Bad Daddy.
I started this fight with an attempt to box rush and get under Bad Daddy before they could get up to speed. Unfortunately their spin up was near instant and my aim was off. My left front wheel caught the spinner which flicked that drive pod upward leaving me to try and get them back in some sort of order before Bad Daddy could capitalise further.
Fortunately their next charge missed giving me the chance to get away and get a bit of breathing room, and to eventually get under and flip Bad Daddy. They spent a while trying to self right off of Forkhead during which I missed a chance to get under them while they were near the OOTA zone, before eventually ramming them and inadvertently helping them to self right.
After this I struggled to get under them and ended up taking multiple hits and needing to get my drive pods back on the ground while being seriously pressured by Bad Daddy’s attacks. During this time both of my lifting forks and one front wheel got mangled making the situation worse and jamming up one side of my drive.
After a bit of chaotic driving on the back two wheels with the drive pods raised up to avoid spending time and focus self driving Bad Daddy managed to snip one of my lifter belts. This left one drive pod flopping around and me unable to take advantage on the rare occasion I did manage to win the ground game.
After a few engagements where I just ended up wheeling I ended up with the front-wheel-less drive pod that I could control pointing backwards to try and keep the front down. Unfortunately I didn’t get that pod down far enough and got launched a few tumes until one of my lifter prongs ended up stuck in their beater bar.
Flapping the one still active drive pod didn’t do enough to try and break free and Forkhead was unceremoniously dumped in the pit and out of the competition.
This fight gave me some repair work to do for whiteboards with both drive pods chewed up and the base plate ripped off in places.
Once the robot was working again I signed up for a non-spinner whiteboard with Baba Yaga, Flick!, and Tsukikage.
Forkhead worked well as a ram bot in this fight, pushing Tsukikage and Baba Yaga into the corner early on. Unfortunately it was having a hard time lifting anything during this fight due to some mangled gears I missed among the other repairs from the previous fight.
I did manage a couple of wall assisted flips, but struggled to get anyone into the pit leaving this fight to a judge’s decision which eventually went to Forkhead.
As much as I’d have enjoyed a few more fights it was nice to finally win a single fight at Champs and not have any short fights. :slight_smile:
Just wanted to say it was awesome to see ForkHead do the thing multiple times on Saturday, you’ve really refined this bot :slight_smile:
Cheers Joe. It was really nice to see it achieve its design goal of picking up and carring other robots fairly reliably. :slight_smile:
Thanks for putting on a great event as always!
Keeping up the tradition of writing up the event before last…
ForkHead didn’t get a place in Beetle Brawl 2025, but I went along with team Mild Peril and immediately got called into the full competition.
I didn’t do a lot of prep for this event, but I finally decided to try some real belts and this made a huge difference to the lifter over the printed belts. Since I don’t have the space for a 15 or 20mm wide belt so I made a jig to cut some 5mm pitch HTD belts down to 5mm width.
The real belts were definitely more sensitive to getting the exact pulley profile right, and annoyingly the ‘accurately’ sized ones I printed in ABS on my Voron 0.2 were completely useless, but lucky for me some slightly overextruded PLA pulleys I’d printed on my ageing Ender 3 turned out to be just right!
Unfortunately for me the first fight was against the biggest vert and the lowest shell spinner - Everest and Wajoo.
I didn’t really have a plan for horizontals so my aim was to let them fight each other a bit. I also put some skinnier forks on, mostly to preserve the standard ones for a fight where they might do something. The plan immediately fell apart when Everest got tipped over and couldn’t self right. I spent most of the fight riding around on top of Wajoo and failing to get under it, eventually getting pitted.
My redemption fight was against fellow lifty grabby robot Abracagrabra.
This one was a good grapply fight and I saw glimpses of ForkHead doing the thing it was designed to do, getting under and lifting Abracagrabra a couple of times (though one of them scuppered by their minibot getting underneath). This went the full 2 minutes and went to ForkHead on a judge’s decision.
After this I was back in the competition, but now I had to try and find a way to deal with Stratus.
This is another robot I don’t really have a solution for, so I ended up screwing some M4 screws into the end of the prongs to try and see if I could hook into their large wheels.
Watching this back I managed to get a few good pushes from the side and one really good push towards the OOtA zone, but every contact with their spinner was fairly devastating and I was rapidly losing drive. After a few promising grabs and shunts, and a pause to determine if Stratus had OOtA’d at one point Forkhead was struggling with a single working wheel.
I decided to keep pushing it to see if I could force some kind of engagement that would send Stratus out of control, but no luck and the fight rightly went to Stratus.
Out of the competition and with a seriously damaged robot that seemed to be a crowd favourite I did what any sensible person would do and duct taped it back together for a whiteboard.
The lifter motors were very dead - both of them took direct hits from Stratus’ weapon - so I taped the drive pods to sit flat, and added back the one drive belt I had.
The whiteboard was a 1v1v1v1v1 with Fang, Overclocked, Bogmeister, and Cormoran & Cormelian.
This was great fun and ForkHead demonstrated that it works quite well as a ram bot. There was a great moment where it pushed 3 robots on a lap of the arena with 2 of them ending up in the pit, before driving up Fang and getting pitted itself a few seconds later.
This was definitely a surprising run given that I went in expecting to be reserve and get maybe a couple of whiteboards.
To top off a fun day of mild robot fixing panic I came away with a second Spirit of BBB beermat. :smiley:
And immediately breaking the tradition…Pub Beetles.
This required a mostly full rebuild after Brawl, resulting in a mostly shiny looking version of ForkHead. The only major change was ditching the removable link for a switch.
I ran out of machining time for replacing the bum armour so that stands as a trophy of previous drubbings.
First fight was against Grab Crab and Zephyrus in its sunflower form. Zephyrus immediately spewed petals across the arena while I spent a bunch of time trying to get Forkhead’s prongs back in line after not having driven it for a while.
Unfortunately while I was recovering Grab Crap managed to yeet me into the OOtA/ball pit. I’m a bit annoyed at myself for misunderstanding the Pub Beetles rules here (obviously they’re about fun) and not making an effort to escape. Once the fight was called ForkHead demonstrated that it had no problem leaving the ball pit.
Before the next fight I reversed the prong adjustment channel on my transmitter. There’s not really an intuitive direction for it, but whichever way it was set wasn’t working for me.
The second fight was vs Bop!
Bop! initially had me on the ropes, but once I got the forks settled I was able to get underneath and push Bop! around.
ForkHead’s lifter finally got an opportuntiy to demonstrate how it was designed to work and I was able to pin Bop! in a corner, lift it, and back up to dump them in the pit to great response from the crowd.
The final competition fight was against Flick2! who was looking for revenge.
I managed to get some good flips and lifts on Flick2!, eventually getting a lift which turned into them dangling by a drive belt from one of my forks. I couldn’t quite drag them into the OOtA though before an unstick was called for and they were able to use the time it took to get everything back inline to line ForkHead up for a pitting.
The final fight of the day was a whiteboard with Gunfinger and Tammy + minibot.
Lots of good lifts and flips in this fight, with a weird double suplex of Tammy when the forks got stuck in its side armour. I eventually managed to pit Gunfinger, then did my best to keep the fight going with Tammy which couldn’t run inverted and was stubbornly resisting my attempts to help it self right.
Despite the heat this was a fun day and a really good shakedown for ForkHead before it likely gets destroyed again at Rapture. :joy:
Ahead of Rapture, ForkHead got some minor drive system improvements.
I redesigned the front hubs to support dead shafts, using some possibly overengineered aluminium inserts that solidly mount a shoulder bolt to the front of the inside drive pods.
This completely isolates the drive system from the outer drive pod, which was a massive weakness on the previous setup.
I ran out of time to machine some aluminium front hubs, but the PLA ones I printed as a stop-gap are working so well that this was a good thing. They take a lot of hits so it’s better for them to be easily and cheaply replaced, and as a bonus the PLA ones are much lighter.
Since my stock of front wheels was dwindling it was also a good opportunity to switch from round to square bosses on the hubs for the wheels to sit over. The previous setup was m2 screws working in shear to drive the wheels which was all around terrible. For now the rear wheels are still using round bosses, but I’ll sort that out when it’s time to make more rear wheels.
