Frenzy - Embracing the Chaos
Part 1 - Taking out the trash
I’m not a superstitious person, but I truly believe that Ultra-Violence was a cursed robot. It never completed a single event without some sort of random failure, usually a new one that had never happened before. I spent 2 whole years trying to persevere with the design but early last year I finally had enough and decided to dispose of the thing finally. To be sure the curse was dealt with I burned it:
…and set about designing something new to replace it. In the meantime, Matt Smith convinced me to get back into antweights, and to be honest this probably single handedly saved me from taking an extended break from robots entirely. I had so much fun running an ant again it rekindled the love I had for this sport that Ultra-Violence had been slowly killing, but also helped me find the inspiration I was missing.
Antweights physics are weird; they’re tiny and have so little mass behind them that things like centre of mass and momentum etc don’t matter and they drive very precisely as a result, with no drifting or acceleration time. I wanted to see if I could translate this sort of feel up to the beetle class, using very powerful motors and a heap of magnets. Now I’d avoided brushless drive in all my bots for a very long time, I always had concerns about reliability and fine control, but with the introduction of AM32, and with how anemic the brushed drive on UV had been, it was finally time to make the jump.
I looked at all the options and decided on the Repeat Max, mainly because I wanted to run this bot on 6S for the extra power and the Max are rated to run that high, while the other options like MegaSparks only state 4S as their maximum voltage. Originally I planned to run a pair of Repeat AM32 ESCs, but while looking through the Palm Beach store for a group buy of ant batteries, I spotted the Repeat Dual ESC. The integrated BEC and onboard current limiting sold me, and I got one imported along with the batteries.
I liked Ultra-Violence’s weapon, when it worked, which wasn’t often, but was the part of that thing that had the least issues, so I kept the setup largely the same, although I changed the motor mounting since the aluminium angle bracket I had been using had issues with bending, now using aluminium standoffs into the side of the frame which was much more solid.
The weapon motor is a Propdrive 2836, which is only rated up to 4S, but I know has been run at 6S in some US beetles. I still wanted to be sure the motor didn’t die from too much current so I put out some feelers for an AM32 ESC with enough guts for a motor that size and current limiting. Ellis was testing out some ESCs that fit the bill, and I agreed to test a couple out.
Originally the design was heavily inspired by Manta from the US, with a much wider more drum like weapon, but it ended up so heavy I ended up redesigning it into more of an eggbeater. At 80mm across it’s still pretty wide for a beater, but the proportions of the bot ended up much more square, although a lot of the style of the Manta inspired design stayed the course:
The entire robot is 3D printed, much like Ultra-Violence before it, but rather than using TPU for everything I was looking at different materials for the chassis since the TPU was far too flexible and caused a ton of issues. I’d tried nylon on UV at its last couple of events, printing the chassis from a reel of Taulman 910, but even in the handful of fights it had the nylon chassis had already cracked. So I needed something more rigid than TPU, but more flexible than nylon. Gus turned me onto OBC, which has a shore hardness of 55D, still somewhat flexible but a lot more rigid than TPU, as well as having the added bonus of being a solid 35% lighter.
The catch here is that OBC is a polypropylene variant, which is infamous for being a total pain to print well due to its tendency to warp. Supposedly OBC is less prone to warping as it prints at a lower nozzle temp, and that is true, but it’s still a lot more warpy than even nylon and printing a part as large as Frenzy’s chassis still leads to warp around the corners:
I tried a ton of different things to help alleviate this issue but no dice, whatever, it’s not bad enough to render the chassis totally unusable so I just ended up accepting it was part of using this material. The chassis was printed with 6 walls and 15% infill and came out super light, about 90g all in.
All parts printed, wiring done (thanks to Dave) and all fixed together, Frenzy was ready for her first event:
Part 2: Trial and error
Not a bad result for a first event eh? A really solid performance and some big hits, but all I could think about was how it just wasn’t quite how I wanted it to be. The weapon had inconsistent engagement, it gyro’d like crazy, it stripped the teeth off the drive pulleys:
…and oh yeah, the weapon fell out:
What I think happened was the big hits against Propane had cracked the bulkhead around the weapon shaft, the fight with Chucky had worsened that crack and then when Gizmo flipped me over in the semi final and the weapon hit the floor, the bulkhead finally split. So obviously, some work to be done on the chassis strength. For the following event the bulkheads were redesigned to be a bit bulkier around the weapon shaft, and I added some stabilisers to the side armour to try and reduce the gyro:
While I can’t talk much about the event, the stabilisers worked, kinda, and helped a lot with the gyro. Unfortunately the bulkheads did not survive once again, and I had to rethink again. I’d also adjusted the pulley centre distances for the drive to try and tension the belts more, hoping it would stop them from skipping the pulley teeth and stripping them away under load. This also didn’t work, and I lost yet another couple of perfectly good tyres to stripped pulleys. The cost of 6S I guess!
BBB Summer Showdown now, and the only real change was to try and beef up the bulkheads yet again. This time, the frame bulks up to 15mm thick around the shaft, and more importantly I sliced the mesh at the front to bulk up the print around that area. While changing the wall count between sections when you slice a mesh in Bambu slicer causes the walls to no longer be continuous, they wrap around the seam and the parts just snap apart with no effort, what I did find you can do is set the infill to 100% with the concentric pattern, which essentially turns the infill into more walls while keeping the continuous walls between the parts:
Where the material was solid the bulkheads completely survived, but where they weren’t, they were crumpled by Sniper:
The TPU wedge didn’t help, he just cut clean through it. Back to the drawing board on that, I was really hoping to not have to buy titanium, get it fabricated etc.
Anyway so it turns out the Repeat Peter Bar Kit wedge fits the dimensions of Frenzy almost perfectly so I don’t have to do any of those things:
…and I now have a proper, proven in combat wedge setup! For the next event, Minibeasts in the East, I swapped the steel woodscrews I was using for the lid and base for stainless plastite screws, which are also holding the wedge to the printed TPU mounts. They have a much stronger hold than the wood screws and are more durable to boot, can’t complain (though there was an unseen negative effect to the switch that will come up later).
For this event I made more of the chassis solid infill, from where the back of the weapon reaches into the frame forward is now completely solid. That’s a fair bit of extra weight in the frame, and it had to come from somewhere, so here is where things get expensive! I swapped the drive shafts from steel shoulder bolts to grade 5 titanium shoulder bolts, and lowered the side armour infill from 15% to just 5%. This saved enough for the extra frame bulk, and everything was ready for MITE.
…oh no
In the first fight with Flick!, the chassis cracked along where the infill transitions from solid to 15%, which seemed to be due to leverage since that point was right along where the frame splits off adjacent to the bulkhead. That leverage would’ve made it easy to bend along that point and crack the two sections apart, annoyingly right along where the mount for the front left wheel is as well, leaving the shaft loose and dropping the frame down on that side.
Frenzy spent the whole event grinding along the arena floor, deafening the judges and destroying what was left of an already badly worn tooth:
Starting to think I maybe should’ve sprung for the heat treat… Nah that would be too expensive right?
So at this point I’m getting sick of going through a whole frame per event, so instead of printing another in OBC, a material you can’t actually get anymore, I switched to a regular polypropylene instead to try and perfect the design before using any more before BBB Champs. This time I went wild with the chassis, and moved the point where the frame transitions from solid to low infill further back until it was a solid 2 inches behind the point where it cracked before, and I sent it. I had some weight left over from the saving I’d done for MITE and burned through that here, but fingers crossed this frame doesn’t break
The frame did not break
In fact, it was flawless. It was so strong in fact that instead of the bulkheads breaking on big hits, the 8mm “grade 5” titanium weapon shaft was bending pretty aggressively:
Dave was able to get it bent back at the event thankfully, but it did happen again, to the spare and then again in the final.
A final I didn’t feel especially like I earned my place in, to be honest. Frenzy just wasn’t what I wanted it to be, still. But why? It won, shouldn’t I be ecstatic? But no, instead I’m wondering why it was struggling to engage properly, why the drive felt so much less than it had before and what I could do to really make it what it had been in my head before I built it
Oh that would do it
Part 3: Glorious evolution
BBB Champs was an alarm bell in my mind. Frenzy was just not the robot it was meant to be. I started to catalogue every issue and looked to find a solution them all, starting with the most pressing:
Poor engagement
There’s a number of factors contributing to this one, but the main one is the wear on the tooth edge. After one event using each side of the two sided tooth, both sides were so worn and rounded that there really was no more leading edge on the weapon, no huge surprise it couldn’t bite into anything properly. The other issue is how soft the weapon was. It was machined from 4140, but left unhardened, making it softer than any Hardox weapon blade and about the same as mild steel. At the time I thought a heat treat would be too expensive, but it turns out that Chinese machining companies will do a heat treat for $10 so really there was no reason not to! I also wanted to increase the weapons reach, so I started redesigning the weapon and settled on a more optimised US style S shaped beater, with a tooth on the counterweight, a more aggressive tooth and an even more single toothed design, with nearly 15mm of bite before the counterweight comes into play:
I’ve also dropped almost 50g from the weapon; 350g was excessive, and 300g is still on the heavy side for an eggbeater of this size.
The increased diameter means I can run the weapon at a lower rpm while still hitting a higher tip speed (increasing from 240 to the full 250mph), which should help increase bite as well. The new beater was machined from 4340 and heat treated to 48hrc, about the same as Hardox 450
Control and acceleration
When I first designed Frenzy, my thought process had been that speed was the key to bite. And it is, to an extent; a higher drive speed will mean more bite. But at 11.5mph, Frenzy was too fast to control well, and the gyro, despite being reduced by the stabilisers, was causing it to flip over when reversing and generally affecting stability quite badly. The first change to be made was reducing the drive speed, I changed the reduction on the drive belts to bring the drive speed down to a more manageable 8mph.
There was another issue with the drive being so fast: acceleration. Sure, at top speed the bite should be great, but Frenzy needed a fair run up to actually reach that top speed, and in the small arenas in frantic close quarters fights, it couldn’t reach that speed reliably enough to make the most of that speed. If Frenzy could reach it’s top speed instantly, it would always get maximum engagement, no matter how close quarters the fight became. The extra torque from the new reduction would help, but I wanted to go harder than that.
Frenzy always ran with magnets, about 1.5kg of downforce. Well, mostly. See when I made the switch from steel screws to the stainless plastite screws, the magnets became less powerful. As I understand it, having the ferrous steel screw through the countersunk hole was enhancing the magnetic force, and when switching it was lessened. So I wanted to run bigger magnets, especially since Frenzy had been running new Repeat Max Mk2s since MITE, with a larger 2006 brushless motor replacing the old 2004 motor, with more torque.
But was this enough? Frenzy had never truly lived up to my intention: to build a beetle that drove like an antweight. I needed to push the downforce more, and for that I needed even more magnetic force. I needed all the torque, and all the magnets. Instant acceleration, a robot absolutely glued to the floor. And honestly, to be rid of the tiny external gearbox screws of the Repeat Max that love to back out.
Enter the Repeat Pro; stronger gearbox design and a huge 2207.5 brushless motor. Unnecessary? Maybe. Maybe if I wasn’t stacking four massive 20mm diameter, 4mm thick N52 magnets onto the base of the robot, giving an effective downforce of 6.5kg, 5kg more than the previous Frenzy at its most magnetic
Stripping pulleys
This was an issue I couldn’t solve. No matter how I changed the tension on the belts, it kept happening. So instead, I’ve changed the way the hubs work so the pulleys can be consumables without throwing out a perfectly good tyre:
The two part wheel weighs the same as the single piece wheel, but means I can remove a damaged pulley and swap it to a spare. To prevent the wheel from slipping off there’s a small lip on the top edge, which compresses into the bore then springs back out on the other side, locking the pulley in place:
It can be removed pretty easily with some force, which isn’t ideal for a fast switch but it’s better than the wheels sliding off the pulleys in a fight!
Ground game
Frenzy’s forks worked pretty good for the most part; the hardox forks were hard mounted into the TPU side armour, about a half mm below the wheels so that they flex up, levelling to the floor and being pressed down with some force. This works great, until the TPU deforms slightly and the forks start to get stuck up a few mm above the floor from leverage when the bot hits stuff.
To solve this, the new forks are loose mounted, and spring loaded more traditionally using rubber bands:
There’s also now TPU feet on under the bulkheads to stop the beater from hitting the floor when the bot tilts forward, something that kept happening when the forks came off.
Bent shafts
The titanium shafts kept bending, so for this new version the weapon shaft is now a steel linear shaft, induction hardened to 60hrc on the surface so it won’t bend, while still being soft on the inside so it won’t crack. It’s also bored out to 4mm all the way through, making it only 9g heavier than the old titanium shaft. Most of the strength from a shaft is on the outer edges, so this shouldn’t affect its strength much.
The new build is coming along nicely, and I’m going to be giving it a good test run at Chichester in a couple of weeks!
brilliantly laid out build-log!
defiantly borrowing a few ideas from this.
Great write up, thanks for sharing all this!
Excellent build log, and a lot of good ideas here! The drive power on display is ludicrous, and I really like the new hubs you’ve got, definitely need to do some similar experiments myself!
I have similar drive goals for my bot (Fatal Deviation) - not exactly “drive like an antweight” because I’ve only ever built one and it wasn’t very good, but I having previous RC racing experience I knew I wanted a bot that was as fast as possible while still being predictable. After some early struggles it now drives great, and the biggest factor was implementing electronic stability control - it’s baked into my drive PCB, but essentially it’s the same thing as the gyro modules people install on RC drift cars. The difference between standard and stabilised drive is night and day, it’s a whole new bot. You can punch the throttle on any surface (even dusty polished concrete) and it’ll shoot off tracking dead straight, and it self corrects from all kinds of abuse; smashing the wedge into drain covers, bouncing off walls, getting kicked with steel toe boots…
I don’t yet have the arena time with the system to say how effective it is in combat, but I got to play a bit at champs and it felt fantastic. If you’re looking for a bot that feels super predictable and planted it’s worth experimenting with a similar setup. I might make a guide at some point, but I need to keep some of the sauce secret!
Antweight adventure was a good idea, even if you dominating London for 2 months now is getting a bit boring. 2 Shrimp 2 Fresh could use a build log simply because that time it won a fight by holding onto the side of the arena instead of getting pitted.
Cheers all! I’ve been wanting to pull a build diary together for Frenzy for ages and thought that finishing up the new version was probably the best time to do it!
Bots basically done ready for Chichester, just waiting on the lasercut forks to arrive and some final bits to print. Threw it in the test box all assembled to see how the new drive works out all in and I’m pretty pleased with the results!
Feels amazing to drive, exactly what I wanted with tons of power and a much more reasonable speed. Even breaks one of the PLA fork standins at the end :laughing:
The forks arrived yesterday, do you think I have enough?
Popped the steel forks on and got the last few bits printed off, still have to cut down the drive shafts but that’s an easy enough job
Don’t you just love it when your bot turns out way lighter than you expected? Spreadsheet said this setup, dual 6mm forks and the belt guard, would be overweight even with the extra ~5g saved from cutting down the shafts, turns out I had nothing to be worried about!
Really looking forward to putting her through her paces at Chichester!
No, you need more forks.
Finished the last few bits, checked off the last thing on the list and put the bot in the test box for one last function test before the weekend
oops :grimacing:
She gyroed pretty hard, flipped over and hit the steel plate floor, and propelled into the polycarb. Scared the crap out of me and now I don’t have a safe test box, but worst of all the solid chassis sheared which I’ve never had happen before, even when Frenzy was getting hit into the roof!
It split the layers at the top, but also sheared against the layers, which I’ve never seen happen before. This chassis print was mostly printed in PP which ran out near the end and I finished it in OBC, which I know bonds to PP but prints at a lower temp (250C Vs 180C) so maybe that’s why it cracked? If anyone has any ideas I’m open to them, I’d love to know why this print failed so catastrophically!
Since then I’ve redesigned the chassis to add some more meat around the part where it sheared and the side armour to be closer to the ground and reduce the gyro, but I can’t test the bot now so I’ll just have to hope it works out on Saturday :sweat:
POST CHICHESTER POST
Actually ended up going undefeated with 4 wins and a fair few pretty beastly hits!
First match was against Chilli Daddy
Less Than Ideal
He hit the underside of the frame rail and the polyprop chassis just shattered. I’ve done so many destructive tests on this material and had been only capable of bending or flexing it, but it seems unlike TPU it forms cracks when hit at high speed, rather than curling or deforming out of the way.
I’d printed an emergency spare chassis out of leftover eSun 95A TPU which I swapped everything over to, and apart from some extra flexing around the drive shafts allowing the belts to skip it actually held up completely fine, so I’m looking to try some harder TPU for the next chassis, maybe some Extrudr Flex Hard.
For the rest of the day I only fought other verts, so spent the whole day at max throttle giving the bot a proper shakedown. With the steering capped at a low rate and the magnetic downforce Frenzy actually doesn’t gyro at all when turning, which is a better result than I’d expected! I just need to get more confident driving it as aggressively as I should be :sweat_smile:
The new eggbeater held up pretty well, I was feeling down on it at the time but watching the videos back made me realise it survived some gargantuan impacts
The big gouge is actually from going weapon on weapon with another spinner who was inverted, so probably a 400+mph impact.
The main issue is that the shaft started to bend immediately, and by the end of the day it was so bent the weapon was dragging along the floor and I had to feather the throttle at the right spot to get it to spin up at all
Now I imagine the first instinct is to assume the reason it bent is because it was hollow, but that’s not the case. It actually bent because. Well. 8mm isn’t strong enough for this weapon! We can do a little math to figure out roughly how strong both the solid and hollow shafts would be:
1000015273
I won’t bore you with the formulas or whatever (unless you ask me to) but despite dropping 25% of the shaft weight the hollow shaft only loses around 6% of its strength, the equivalent of using a 7.8mm solid shaft, so in all likelihood if the shaft had been solid the same thing would’ve happened.
So for next time I’ll be stepping the shaft up to 10mm with a 6mm bore and hoping that does the trick. I did comparisons for some different options and it seems the best option for strength to weight:
The solid 10mm shaft would be more than twice the strength of the hollow 8mm, but also more than twice the weight, whereas the hollow 10mm shaft would only be 33% heavier while still being over 80% stronger. It also weighs exactly the same as the solid 8mm shaft while being 70% stronger!
There are some other factors at play here too, like the distance the pulley side bearing is from the frame rail, and the contact area the bearing has with the shaft which is very narrow with the 8mm roller bearings. With the 10mm shaft I’ll be switching to needle rollers to give a much wider contact area which will hopefully also spread the impact out and reduce the bending stress
Lots to do before the next event! Sadly I didn’t manage to snag a spot at BBB Brawl and there currently aren’t any more beetle events on the calendar for me right now so at least I’ve got some time to work on the changes! For now I’m heading back down the antweight mines and getting my two ants ready for ORCS on Saturday
Not me forgetting I have a build diary again
Since the last update I’ve built another beetle, Jumbo Shrimp, a scaled up version of my ant, using spares and other old parts from Frenzy:
It’s basically just old Frenzy’s drive in a tougher chassis without the weapon bit. It’s not very interesting but it’s super fun to drive since it’s using a smaller 6S pack I bought for Frenzy but decided was too low capacity.
I also built this vert using other parts I had lying around for my housemate:
This is Toadie From Neighbours and he’s also pretty fun to drive when the weapon works.
I took both of these bots to BBB New Blood and had a great time, Toadie was just a reserve and managed to shear off his own weapon motor output shaft in a whiteboard coz the chassis is all super flexy TPU. Will probably get some HDPE bulkheads made up for him to stop that happening again.
Jumbo Shrimp however was great all day and somehow walked away with 1st place, proud and surprised all at the same time.
But this topic is about Frenzy so back on topic. I had signed Frenzy up to Battle in the Burgh but unfortunately some of the parts I had made for it didn’t arrive in time so I had to substitute Jumbo Shrimp back in with barely a few days to prepare it, and it still somehow managed to reach the final and take 2nd after being pitted by Boom Zoom. Disappointing to not be able to run Frenzy but still elated at the result for Shrimpy boy.
Frenzy has gone through a pretty significant design change, and I’ve ditched the printed chassis for good in favour of CNC machined UHMW bulkheads and a carbon fiber base for rigidity.
Arriving the day after Burgh, which was very useful, the new bulkheads are 15mm and should be much more rugged compared to the printed chassis, which was pretty damn good until it took any direct impacts and then it would just crack.
The new layout is a lot simpler than the single piece printed chassis, tbh I should’ve done it like this from the start but I did really want to be able to make any parts of the chassis myself on the printer. Unfortunately if you want to compete with the best you gotta make some sacrifices!
Latest version of Frenzy is as close to where I want it to be as it’s ever been, and after Scouse Showdown where it scored 2nd place after an undefeated run to the final, there’s honestly nothing I would change about it. At Scouse the firewall between the weapon and electronics as well as the motor protectors inside the chassis were just PLA+ and from the impacts throughout the day those parts split along the layers so I’ve replaced them with polyprop, so they’re now lighter and tougher.
The biggest issue was one of the retaining bolts from the new 10mm hollow weapon shaft unscrewing during the final, which allowed the shaft to slide out and the weapon to eat its own chassis. I hadn’t used any threadlock on them but at the same time I had to take the shaft apart to swap belts during the day anyway so it probably wouldn’t have stopped it happening, I’ve bought some Vibratite which cures much quicker so next time if I do have to take the shaft out I can redo the threadlock in the time I between fights.
Other than those two things, I’m super happy with how it turned out and once the burned out ESC is replaced it’s ready to fight again at Rapture and then Capital Punishment in August!
I’m not all that surprised that Jumbo Shrimp did so well. The antweight version’s successor won Rock and Robots twice, including do-OOTAing itself.
Oh I sure did forget to update the build log again huh. My doctor had better start giving me amphetamines for my brain soon
I did also just move house and it was v stressful but that’s secondary to the brain thing honestly
I changed the robot again
So what’s new? And also why? That’s a good question honestly I think I have a problem
It’s no secret that I want to eventually take Frenzy overseas to compete in NHRL because I’m an over competitive insane person, but all the previous versions of Frenzy were built and optimised for the higher UK limit of 1.5kg, so in order to compete in the states I had to lose around 140g which. Is not a simple task.
First off the whole robot is smaller:
Around 15mm narrower, which takes a fair amount of mass out of the weapon and makes the top and bottom plates lighter. I’ve also ditched the titanium shoulder bolt drive shafts and swapped to Repeat axles, made from 7075 aluminium and sporting a flanged base which does wonders in keeping the shafts aligned properly where I often found the shoulder bolts flexing
I’m a big fan of these the only downside is that they’re imperial diameter and use imperial threads, and 1/4" plastic bushings are really not common over here and tend to be really expensive. I’ve just been running brass bushings for now since weight isn’t a concern anymore
The new weapon is also a larger diameter, 92mm up from 80mm, so it has more reach and can be spun slower for the same tip speed, meaning it has more bite:
The previous beater was 300g, the first version of Frenzy had a 350g beater, both overkill. Kinetic energy is a lie by Big Metal to sell you more steel
The main change to the weapon is the tooth profile; an issue I had before was the way the tooth aligned with the feeder forks:
You can see here that as the weapon comes up past the forks the radius on the tooth actually comes through first, meaning on any large bite the tooth isn’t getting proper engagement. For the new design I went through a lot of different designs for the beater until it looked like this:
Now as it passes through the feeder the tooth aligns properly and should get more consistent big engagements. I’ve also swapped the weapon over to XL belts with a larger pitch to combat the belts snapping; it wasn’t a super common problem but it happened enough times to warrant a fix
You might have also noticed the new ground game, Lynx style angled wedgelets:
The angle looks cool as hell but mainly widens the area of effectiveness; typically you won’t be engaging an opponent directly head on but from an angle, and angling the wedges outwards makes them more effective when your opponent is at one of those angles
These are 2mm Hardox and are hinged on a 6mm shoulder bolt so they always sit flush on the ground. For its first event they ran with small magnets under the leading edge to add extra pressure and keep them flush, but it also has the option to run the same elastic band springs as the forks. These are specifically to counter TPU ground game, which proved the most difficult to deal with for the last version of Frenzy, and I’m very happy with how it worked at Brawl. There was a design flaw with the wedgelets that I found out late in the competition, where they could hinge too far and get stuck underneath the front, which was a real pain. I knew it was possible going into the event but hadn’t had the time to figure out how to prevent it, as it turns out it was actually easy and I’m just a big dumb dumb idiot so it shouldn’t be able to happen again
Brawl went decently overall, 3rd place isn’t bad even if it was by default. Got some new ideas I want to try going forward to improve how she handles, as it is Frenzy’s very on rails and hard to control. I was signed up to compete at MITE earlier in the year but Frenzy needed a lot of repairs after it’s fight with End Boss and unfortunately some of the replacement parts weren’t done in time so I had to drop out. I will however be bringing her to Battle in the Burgh in a couple of weeks with all the new changes made! See you all then and I’ll probably update this diary again in like a year or something xoxo
Some monster upgrades there for NHRL. Seems like the internal separation sections are integral to the floor plate. You still running TPU for the floor or a nylon based 3D print?
They actually aren’t anymore they’re screwed on using plastite screws, the base is 1.5mm carbon fiber and has been since Scouse last year, the frame needs the base for rigidity now that the two frame rails aren’t connected
