Fs i6 AND/or Fs 2a Not binding issue?
OK, so when I tried to set Nugget up (my wedge bot) The Fs 2a rx in it just refused to bind with the fs i6. I mean, It entered bind mode all right, but as soon as I power on the tx It goes slow blinking like it just said ‘nyuk nyuk’ to the fs i6! This has happened every time i try with the fs 2a but I am unsure if It is the fs 2a’s problem or the fs I6.
Keep in mind I Haven’t updated the tx yet as it is still in chinese (and i need google translate every time i turn it on) and i quadrillioniple- checked that it is set to AFHDS 2A.
Any help would be a big thank you~
If you just power cycle the tx does it bind?
My i6 is over a decade old and sometimes it needs to be on/off’d in order to complete binding.
Thanks, I should try that. What do you mean by power cycling tho?
Just turning it on and off again
Where did the receiver come from? Did it used to work? Sometimes the cheap ones are DOA.
I am kinda stupid (on and off!!!) . Thanks though! I got the fs 2a off Aliexpress, It worked on my cardboard test lump quite well, but I don’t know if they are manufactured in the same place or quality of the other ones
