Good hdpe stores?
Hey I was just wandering if anyone knows any good place to get 5 and 10 mm hdpe for beetles thanks
Direct plastics is great if you need full sheets:
However I normally go by getting scraps on eBay from somewhere like GFG
Also wondering what would be the best dimensions to get for a beetle
The person who can answer that best would be yourself!
From the looks of things you had a robot designed. You can work out what panel sizes you need to cut from that, then you can try and buy sheets around them. No magic right answer.
Also good to know it’s known often as “PE500” or at least thats the grade I like in lots of colours. (Usually from both places Harry’s linked)
I believe Trent plastics was the one to avoid with brittle black HDPE?
Thanks that really helps
