Hardox 450 cutting/sourcing?
Hi!
I attended my first ever event last weekend, the BBB Champs (trial by fire..). It was a great day, even if my blade didn’t quite survive it. It was my first build, “Mullet”, a beetleweight spinner with a 170mm asymmetric bar. Unfortunately, although it decided to identify more as a pinball than a combat robot, it held up great. The only downfall apart from driving into the pit (-_-) was that it bent a blade in each of my three matches.. self inflicted, all from wall strikes, so the blade material is clearly the weak point. The rest of the robot held up well.
I’m looking to replace it with Hardox 450, which is pre-hardened and should resist yielding much better than the 42CrMo4 I’ve been using. The trouble is getting it cut. I’ve tried a couple of UK profiling firms and most seem to want a trade account
So I’d really appreciate pointers on:
  • Where do people here get Hardox or wear plate cut, waterjet preferred?
  • Anyone who’s had a hobby or one-off job done at a sensible price?
  • Any sources for 5mm Hardox in small quantities, or places that will source it for you?
Happy to share the blade drawing and what I’ve learned about it if it helps anyone else. Thanks in advance!
Hi Stu!
Usually if you just want a couple of parts done it’s easiest to add some parts to someone’s group order, as it cuts down on postage/setup fees. The two orders I’ve joined have been from Lasered (Raex, roughly equivalent grades to Hardox) and Pegasus Profiles (Hardox).
If you keep an eye on the forum and facebook group (the Robodojo discord server is another good place to be for such things) you might find someone putting one in for Brawl in the new year, or if you’re feeling up to it you can start one yourself and put the word out.
If the order is big enough, laser cut Hardox parts are super cheap -I think I paid about £3 each for Birdemic’s forks and pecker beak. If you end up ordering small parts like forks, mounting brackets, wedgelets etc as well as your weapon discs, my top tip is to join two parts together back to back with a couple of small tabs holding them together, then grind them apart on arrival. That’ll save you money on any flat-rate per-part fees!
