Hardox/Aluminium Fabrication
Hi all,
Looking to get some spinner components fabricated, though it’ll be my first time doing so (for a beetleweight robot that’s finished otherwise).
Saw last year that some of you guys pooled together for a bulk order with Lasered - I’m pretty sure that I’ll be a little short on the minimum charge, so open to another joint order perhaps?
Ofc, open to any machinists who could work with the materials I’m looking to use - 4mm Hardox (or similar hardened steel) for the spinners, and Aluminium (6061/7075 grade if possible) for some 2mm thick hubs. Have parts in DXF/STEP/STL if it helps,
Cheers :slight_smile:
