How thick is good for armour because being a begginer my first robot was very big and ended up only being able to be 1.5mm thick to stay in weight (it may or may not have actualy been about 0.6g over!) so yeah how thick should I aim for when making ants
Most pressing is what is 1.5mm thick? If it’s polycarbonate then that’s about right, if it’s steel or titanium that’s overkill and if it’s 1.5mm custard or lavatory paper then you may have much more urgent problems.
0.6g is not a lot to find, drilling holes or trimming wiring will easily get there. If you’re hitting 20g over then you’re probably making things physically too big etc.
If it’s 3D printed, remember 3D printed parts are mostly air. Most slicers will default to a 0.8mm wall thickness, so you’ve technically got 1.6mm of armour (assuming a three dimensional solid with inner and outer walls), but “air armour” is valid too - doesn’t matter if you get hit if there’s nothing there anyway.
Also, remember that (because physics) antweight spinners are like spiders - even the really big ones are just as scared of you as you are of them. You typically won’t take many big hits because one or both of you will end up OOTA within seconds!
Another question where does everyone get their filament?
I was looking at the bambu labs (the brand of the printer I’m getting) Pla tough+ has anyone used this before or has recommendations for other companies and types of plastic?
