Hi all
I thought it was about time I started a thread listing the beetles I’ve built throughout the years, to give me something easy to update when I’m working on them and save me making loads of individual build diaries. Beetles are probably the most popular class in the UK at the moment, as such I’ve made a few since 2019. So, I’ll start at the beginning…
Igor
Igor was built as a rush job for 2019 Robonerd, to give me something to take up and fight with. A very simple 4 wheel bot with an HDPE body, 3mm aluminium front panel, and Panic Attack style servo lifting forks (made from an old DVD player steel lid!)
Not the best, but I had a lot of fun with this version at the time, very inexperienced with beetles so lots of reliability issues, mainly with the grub screws coming loose on the drive (a common issue with stock banebots hubs).
After Robonerd, this version had new aluminium forks made and some other minor changes, fighting in Bristol and Chatham in 2020, with mixed results. Probably the best performance was against Pain Per View, a scary undercutter that I managed to remove the receiver out of. Today, this version has been repaired and is waiting to return to Robonerd for old times sake.
Igor 1.5
Version 2 of Igor is a massive change internally, now brushless drive with belts between the wheels. I kept the name as Igor rather than Igor 1.5 or 2, as I didn’t consider the design changes enough to warrant a name change.The whole robot is smaller and more compact, hardox forks and titanium front. This is the version currently in use, its best placing so far is top 16 at Chatham, and winning the content creator rumble at Robonerd.
Igor 2
Igor 2 is currently in cad progress, and will be a significant departure from the Panic Attack design. This version should be able to self-right, unlike previous versions, and lift more effectively. Unsure what kind of mechanism I’ll be using for the lifter yet, I had planned to use a servo like before but seeing the success of Grab Crab, things may change! Stay tuned to this thread for news about this build.
Cybotron
What is there to say about this thing? It’s a Cybot… With an undercutter where the caster should be! Built purely for whiteboards, he’s been destroyed before and rebuilt, always coming back for more. Hopefully he’ll tag along for another event in 2024, as I didn’t get a chance to use him this year.
Fang
Fang is the most successful bot I’ve built to date, getting 4th place and the best design award in the champs 2022. It’s an HDPE bat-shaped horizontal that surprised even me when it had its deep tournament run, but since then everything went downhill for it, with lots of gremlins and catastrophic damage being inflicted to it this year and poor performance in Liverpool and Chatham, I was considering retiring it for good, as it’s not an easy robot to maintain or replace parts for (It’s a bat! Lots of complex shapes).
However, due to its popularity both within the team and outside it (shoutout to Amy and Team Bee!) and the fact that I don’t like to be beaten by gremlins, Fang is currently in bits being repaired and upgraded where I can, for another go next year. Stay tuned for progress on that!
Home Improvement
(Cue Tim Allen grunt)
The latest bot in the family is, once again, a novelty shaped bot, this time a vertical spinner in the shape of a hand saw. Why did I do this? I honestly don’t know, but I’m glad that I did, as lots of people loved the design at the champs this year. Top 32 is where we placed, but being the first bot to hit Stratus on the body gives me hope for the future with this machine. The main improvements to be made are to the 3D printed parts, as they failed a few times on me. This will probably be the main bot for the team next year while I work on other projects.
And that’s it for now! I’ll try to keep this updated reasonably frequently, trying to get in the habit of posting online more again. Thanks for reading this far if you did!
Cheers,
Jon
