I’m currently building new machines for FightFest so I desperately need to clear some space in the shed so have a few things up for grabs. Give me a shout here or via Facebook/ Discord if you are interested in anything. There will likely be more to follow as I clear out the shed over the next week.
Up first I have two antweights for sale. Both need a little work/ weight saving to be competition ready but there are some good parts.
3mm mild steel with removeable base plates which include mountings for 42mm planetary gearmotors
1x Flipper arm per chassis included
No components included
A set of hardox wedgelets included with each chassis.
These shells have been used at FightFest with some minor damage, nothing which would prevent them being used.
FoxAlien Masuter 4040 CNC router- £300
A great CNC router and fully operational- does not include the 24v Power Supply. Just too big to comfortably fit into my shed
Inertia XL- Featherweight spinner- Open to offers
Almost complete featherweight spinner- just add batteries and radio gear.
Includes;
Chassis made from a mix of 20 and 8mm HDPE- held together with M6 barrel nuts
2x Gimson 775 gearmotors with custom 120mm wheels.
2x 3s drive ESCs
300mm disc (slightly older than the pictured one) with a 5060 outrunner with a belt reduction.
200A redbrick ESC
It will need a little work to get spinning reliably- the correct sized belt should fix it.
Also if interested, there is a set of uprights to house an lifter module and a thicker set of front armour panels with some HDPE forks with hardox tips.
I haven’t used this robot in a while and have no plans to now that I have Inversion to run.
8mm HDPE chassis with TPU sides. This has been successful over the years coming second at the first Chichester event and winning the 2021 BBB Champs.
BBB Drive with 2.75" Fingertech wheels.
Standard Fingertech weapon setup- some damage to the beater fitted to the robot but still useable.
Also includes a spare set of lids and wheelguards and a damaged beater which would need a bolt extracting and replacing before use.
Another of my beetles which hasn’t been in the arena for a while- last ran at the BBB Brawl earlier this year.
It’s a 2WD vert with a megadestructo hardox disc. Chassis is 8mm HDPE with TPU front armour and lids.
Drive is the same BBB kit as Inferno.
Comes with a load of spare forks, wedges, front armour and lids. Just add a transmitter and lipo.
