Checkmate - Shuffling Hammersaw
To dispose of it safely you can connect a load to any un-damaged cells to drain them down to zero - a ~100 ohm resistor, or an old drive motor or similar. Once all the cells are close to 0V they won’t be anywhere near as much of a fire risk as when charged, and you can recycle what’s left of the battery safely.
You can use salt water in a pinch too but then you get a glass of lipo juice to deal with…
Flip. It’s like, 15g over weight limit. Might go back to old weapon setup for ORCS :frowning:
The weapon motor on the old weapon set up is broken as well… do have a spare but now if anything happens to the weapon I’m cooked :frowning: the can bit is like, loose on the bottom bit… :sob:
Could cut down on your armour, the standard ONI files have ridiculously heavy duty armour that isnt necessary
Not really time for that now, will think about that after ORCS. Old weapon assembly is on and I’m just waiting for the lids to finish then it’s done. Printer will be running long shift overnight as well for spares lol.
Good luck with it tomorrow! Looked pretty awesome at GROCS. Hoping to finish up on my robot tonight too so that i can finally catch some rest before tomorrow…
Fair enough, still think you could get a hell of alot of weight out of it with lighter print settings rather than a redesign
Gonna do quick event recap, ORCS was fantastic going 4-1 in groups, killing some lids, damaging electronics and getting millimetres away from piercing a Lipo! It won against jungle man in round of 16, but in doing so the motor came off the arm and must’ve pulled a wire loose inside the motor or something because the motor no longer worked after. This led to me being a bit of a sitting duck in my quarter finals match against stronghold.
Arcs was extremely disappointing, going 0-4 (I think) this is the event where I moved to an even larger disc and a bbb 1806 motor.In the first fight against baphomet, I just got absolutely destroyed, with my side armour getting ripped off, shuffler mechanism getting minor damage and all 3 forks getting totaled. In the second fight, the arm snapped in half after hitting the floor twice! This never happened before, so I think the super pla plus arm just couldn’t handle the bigger disc, and hitting the floor to much. I struggled to regain any sort of form, or confidence and I don’t think I managed to get any wins.
Upgrades are in the works though, the chassis is smaller and thinner, also with holes where chassis armour isn’t really needed, for example, behind the side armour. Will be swapping to a tpu weapon arm, still deciding whether to use 95a or 64d, forks will be printed with 64d tpu and higher walls as to not break, and forks will be redesigned to not get stuck pointing upwards.
So yeah. Thanks for reading. Will defo bring to next GROCS to test new upgrades, and probably ORCS, where it might run along side an exciting new robot I’m designing (Dylan, I know you know, don’t spoil it lol)
Shame about its performance at ARCS, especially with the problem for the forks… Was a fun fight though! Even if it was 0-3 at the time i was quite worried to fight it since like most bots, my top armour is always the most lacking…
Look forward to seeing your new bot at ORCS, sounds… ominous. I hope to bring Wipeout along for its debut event, hope all goes well with both!!
Where did you get the disc cut? Thinking of getting a custom bar for a future horizontal.
got it metal printed from jlc3dp. probably not the best choice but its sooo much cheaper, it was like £7 for a disc.
Might look into that ngl, PCB way is way too expensive… Wipeouts 3mm bar costed me over 100 quid!
They only do titanium, which isn’t good for thin weapons. Where can I find Hardox cut for cheap? Thinking of Fractory.
best bet would be to ask around for if anyone is doing a group order from lasered (3mm and up) or Pegasus profiles(2mm and up but more expensive). once you get over the ~£70 pound minimum order ant stuff is very cheap
Checkmate is famous :slight_smile:
OMG
At Grocs now. Just had crazy fight. A hair away from battery once again, that whole cut was one hit…
Hiiiii
Took technique from joes BW Birdemic and tried a new arm with 95a tpu and piano wire running through the arm. Worked brilliantly and didn’t show any signs of stress or breaking like the old super pla plus arm. I did run 1 rod as weight was close so it moved around when I spun up, more than I wanted, but it didn’t really cause any issues.
GRoCS was great, going, 3-1 in groups, then winning quarter finals against look what you’ve done to our breakfast by ko, then losing a pretty, I wanna say unfair, but I don’t think that’s the right word, fight against roomba where I just chased it around the walls for two minutes and then he won because the audience like the room a more. I don’t blame them, but still. then I unfortunately lost to caustic in the 3rd place match in what was a pretty close fight, but Phoenix definately deserved that 3rd place after his fights that day.
So 4th. I’m pretty happy with that, I had a couple entertaining fights, the shuffler system worked all day fine, somehow the drive motors are still alive, even though I’m running 3s. But I do have a broken weapon motor and loose weapon after my fight with caustic so I will need a new weapon motor :(.
1 issue I encountered quite frequently was the robot going mad when I swing the arm, see example below, which was really restricting me from getting consistent, crazy hits, because i know this robot is more than capable of that. I just need to find a way to control the arm. Ideally I don’t want to have to slow the arm down but i fear that might be necessary, at least a bit. I think having the forks pressed onto the ground a lot would help, but it could still lift up from the back. This is where magnets would be very helpful, but all events I go to don’t allow them. I guess most of the time I swung the arm the crap forks had already been hit off already so that dosent help lol. If anyone has any ideas, I would apreciate your feedback.
1 upgrade is coming for orcs, which is thickening the forks. I thought maybe switching to 64d tpu would be good enough but they are still way to flexible and fragile.
Here is a picture for people who don’t like reading (me)
I believe I can flyyyyyy
Oh yeah and Ben, *cough cough no more audience judging cough cough* pardon me :slight_smile:
Dare I say it, damage points from the sliced weapon motor wires would’ve still swung it my way :sweat_smile: You were super close to getting a hit in though - the combination of me not knowing how to drive the damn thing (the slippery floor didn’t help) and nobody else knowing how to fight it meant things were a bit chaotic (also the crowd egging me on to go full pinball mode), but I think if we fought again things would be a lot more even. I’m not telling anyone my death star cooling vent weakness yet, but if you watch the fights back carefully the opportunity is there and someone’s going to figure it out eventually.
Glad the TPU + piano wire combo worked out though! Big fan of the whole Stuff In TPU strat.
finding volunteers willing to sit and intently watch a whole day of fights for very little thanks is haaaaard, trust
100% this..
We’d avoided judges because it was just 2 of us running it all.. We’re a bit more established now so we’re looking at having judges in future but we’ll need a bunch of volunteers for it..
