Data Breach Beetleweight Build
The last bits of metalwork are done. 8 new long forks and 10 aluminium motor mounting plates for the Repeat Max V2s. Thanks to Jed Preist for organising the metal order.
I had the forks cleaned up and ready for action. The mounts had the centre hole enlarged to the correct size and then the bolt holes were countersunk 2 of the mounts got scuffed by the countersinking and had to be binned. I already fitted 4 of the mounts to Data Breach (no picture sorry) and the spare bulkheads.
The last thing to do is do some self-righting tests and maybe a tweaked anti-overhead/ axe armour setup.
The revised extra top armour was thicker to keep those overhead attacks at bay.
Popped on the scales with the heaviest forks. 1.478kg making this configuration the 2nd heaviest.
The heaviest setup goes to the anti-HS wedge paired with the extra top armour, hitting 1.484kg on the scales.
Should the British weather stay clear tomorrow I’ll be outside testing how well each setup handles self-righting.
The weather held up so I got testing the self-righting of Data Breach MK3.2 with the more unusual front setups. I can’t take chances when it comes to not checking if each setup can self-right.
Happily, Data Breach can self-right with ease.
Back home from Bristol and I’ve had some rest after a brutal BBB Beetle Brawl. It’s event report time Data Breach reached the top 16 once again, before losing to a podium-finishing bot Grey Area.
The first fight with Detonator and Wheeie Big Lad was a tough one, I had counters for both weapon types but neither were designed to be used together. I put on my extra TPU armour layer on top and swapped to my big wheeled bot lifter arm. After I added the heavy forks I popped this combo on the scales as I wasn’t sure how heavy this mixed-up setup would be and it turns out it was nowhere near the limit thankfully.
3 Very different bots not much else to say.
There wasn’t a real game plan it was to attack one bot while the other was in no position to attack me in the process hence the zipping around the arena trying to attack and evade getting some good lifts in. Luckily both Detonator and WBL had issues with their weapons that had them on the back foot. I opened the pit and Detonator knocked WBL into the pit taking them out of the fight. Detonator’s weapon died and I simply tried to get some good lifts in granted the lifter arm wasn’t really designed to lift normal bots as it has no forks attacked. But by more good luck Detonator high-centred itself on the oota zone wall. I saw my chance and I scored my first beetleweight oota earning me a place in the top 32.
https://www.youtube.com/live/cCd0SGRfj0c?si=5TcNbGY9pqaKDyVD&t=3084
The big-wheeled bot lifter arm was damaged but had done its job. Slight damage to the tyres which I either swapped out or gave a quick clean once I had given them a once over.
After a tense wait for the redemption fights to finish, I was up against Jackhammer. Keeping the tpu top on I switched to my slightly lighter 8mm forks and put the standard lifter arm back on.
The fight was a good back-and-forth the main aim was just to keep Jackhammer inverted as much as possible thankfully Jackhammer helped with that effort bouncing off my tpu top, lifter arm or the floor with their attacks I was in full control for the first minute of the fight but I went for a lift that ended up dropping Jackhammer and it’s already extended arm perfectly on the front right drive belt. That loss of the front right wheel meant the drive was struggling a tad (which I get to why a bit later) this gave Jackhammer a free shot that took out the back right belt leaving Data Breach on 4 wheels. I was crab-walking for the rest of the fight which thankfully so was Jackhammer after a pinion gear came off their drive motor on one side. Jackhammer managed to tip me onto my compromised side with the spinner and thought me dead but luckily extending the lifter tipped me over. Despite only having one back wheel running I was able to self-right and limp through the rest of the fight dealing with high-centring issues which was odd as Data Breach has a high ground clearance to prevent that. After limping around and Jackhammer trying to use its weapon to move the fight went to a JD with Data Breach declared the winner.
https://www.youtube.com/live/cCd0SGRfj0c?si=OyJPVfOJJdQwGO6g&t=15134
A big repair job followed I swapped out damaged wheels, added new belts, took off the tpu top, swapped the lifter arm, replaced the hair band that pulls the lifter back down as that was close to snapping and had to swap the HDPE lid as Jackhammer hit the only exposed area of the panel next to the link door.
I made the repairs and headed to the ready table only to run back to grab a hex key after discovering the high-centering issue was a loose bolt in the base plate so a quick tightening of all those bolts and it was ready to fight Grey Area. (Sorry for the blurry photo I was rather nervous and shaking from the intense repairs)
The fight was a driving match and sadly Scott is a far better driver who kept on top of me the whole fight. I lost the front right drive belt super quick and the drive struggled. I managed a few lifts when our forks locked but I could only steer Grey Area around so much before the offset weight and their weapon gyro were pulling Data Breach over. After a little back and forth Grey Area got a good pin and went to town of DB snipping the front left belt before chewing up the lid right above the lipo a little deeper and DB would have died a fiery death. With both front wheels no longer running the middle and back wheels couldn’t do anything. It turns out Data Breach MK3.2 is too front-heavy heavy so the middle and back wheels don’t have enough weight to push them into the ground to keep traction. I barely kept DB moving to get to the full 2 minutes but everybody knew Grey Area won that hands down.
https://www.youtube.com/live/cCd0SGRfj0c?si=FAgLbeUXIcMgDmR9&t=18969
With that DB was out at the top 16 with another repair job to finish off my day. The lid, base, wheels, wedges and chassis were damaged, and DB is now on my last four belts.
I was able to fix DB to a fighting state again so I can be proud that DB is a survivor.
I have a list of issues to resolve: protect belts better, fix the weight distribution issues, simplify the lifter linkage, consider converting to a switch and perhaps commit to running as a lifter fully from now on.
With the report done let’s focus on changes for Data Breach MK3.3
So with MK3.2, the main issues were:
  • The centre of weight being near the front means the middle and back wheels lack the weight to provide traction on the floor when the front wheels lose the belts.
  • The belts are more exposed and need extra protection to prevent sniping.
  • The lifter needs a little tweak to increase the range while simplifying how the hair band is attached to the servo and lifter arm.
  • While I have fixed the link popping out the huge link door and space needed to give it clearance to open leaves a big corner of the bot unprotected when using the TPU top armour layer.
To fix the belt snipping the wheels will be running with the pulleys the next size down. This does require moving the front and back out 1mm to match the required distance the new belts will need (will double-check that down the line.) This will make the belts and pulleys clear between the top and bottom plates which will be tweaked to provide some cover. The idea is the wheels and the covers reduce the chances of the overhead weapons getting deep enough to hit the belts. I’ve designed a variant of my bulkheads that have mounting holes for the FT switch. I’m also applying the changes to the link-supporting version as not all events will run switches.
As I don’t want to go mad with changing the shape and layout of parts inside I’m going to try magnets to help the middle and rear wheels get better traction. I’m not planning to run crazy powerful magnets just enough force to have all 6 wheels able to drive the bot. Here I’m going to pocket out 2mm deep circles in the 5mm base for the magnets and their holders closely based on what I’ve seen used on Frenzy. At the moment 20mm x 2mm N42 Neodymium magnets are what I’m designing around just to get the ballpark. Based on a calculator they should pull roughly 400g. Any magnet gurus feel free to offer advice.
The lifter has been running great I just want to give it minor improvements. One being range and overall high. The lifter unit has been lowered by 4.5mm and the lifter arm pivot point has been moved back 9mm. This should add 10-20 degrees of range on the arm which will hopefully make self-righting a little easier. I might swap out the 45kg servo for the 75kg servo I bought for Malware for a bit more power (will do some tests)
With some months focusing on other things, gave me enough of a break to return to Data Breach and well, things are taking a different direction. Realising that with all 6 wheels fitted meant the middle wheels are getting zero traction, which was a big issue when I lost the belts to the front and back wheels. So effectively DB has been running on 4 wheels this whole time so opting for the simple solution, it’s with a heavy heart I introduce Data Breach MK4.
The main changes besides the change to 4 wheels are:
  • Wrap-around armour.
  • Revised mounts for the wedges.
  • Smaller pulleys to provide clearance to add belt covers.
  • Single-piece chassis fully designed around the lifter.
  • Fully retired the axe.
Other than that, it’s still more or less MK3.2 underneath, and some of the planned changes I had planned for MK3.3 will still be in MK4, such as the tweaks to the lifter.
Well, it has been a while. :sweat_smile:
With most of 2025 hyper-fixated on Corruption, I didn’t get much done for Data Breach. Partly because I was not happy with the design and kept trying new ideas until I found a design I was happy with.
Here are the design rejects:
This is the design I was working on in the last post. I wasn’t happy with the side armour and theming, so I made tweaks which became reject number 2.
While the armour and theming were better and more in line with my desire to not be wasteful, hence splitting the wedge and side. But it quickly hit a brick wall, trying to just modify the MK3.2 design into 4WD was creating issues with clearance for parts. At this point, a fresh start was needed.
This design tried to copy elements from Corruption, but I wasn’t confident enough with this change, so I stopped there and tried a different idea.
Big wheels and small wheels. While I wasn’t able to get the design to fit everything inside, I was able to convert it to what I ended up using.
Taking elements from some of those designs, I settled on this: the wedge and side armour from the first design, the weapon from the fourth, mated to a brand new chassis. This screenshot was from 2 weeks ago; the design was tweaked after some test prints.
I managed to move the drive motors to the front wheels, move the weapon servo and the battery to the centre of the bot for better weight distribution. The wheels now run on smaller pulleys, so the belts can be protected by the side armour. The lifter arm now runs a diamond 70kg brushless servo for extra grunt. And I’ve swapped over to a power switch due to the compact inside of the bot. I also swapped out the 1000Mah batteries for the 850Mah ones I run in Corruption.
But enough talking about designs lets get to the building.
Here is the first version of the chassis. I found that it was not long enough to fit the battery. Thankfully, I was able to make the bot 7.5mm longer and printed a new version.
Test-fitting the first version of the weapon bulkheads with motors in place. I changed the angle of the weapon arm so the shaft of the arm can be removed without taking the whole unit out.
Here is the new wedge mounting solution, taking inspiration from Aero to use the front hex spacers to secure the wedges on.
Mapping out the electronics and wire loom. It’s a snug fit inside.
Even with the old wheels on as place holders, DB MK4 is looking great.
A quick weight check. The HDPE parts are just PLA prototypes, but I’m happy with the weight (with the heaviest forks on).
The MK4 wheels were printed and had what’s left of the 30A shore rubber cast onto them, just so I can burn through that and then get the 40A rubber.
Quick picture with the new wheels on, really happy with how the 4WD looks (I know, I still miss the 6WD too). The first version of the lifter arm was printed (before the revision to the weapon was made).
The wiring came together once the new power switch arrived. I then printed a new ESC cover for the Dual ESC and gave it a quick power up. All works. Here you can see the channels the belts feed through in the side armour.
The revised lifter was printed and assembled. It’s scary how fast this new build is coming together (after spending almost a year designing it). I set up the servo, and its range of rotation was pleasantly surprising. I didn’t need the servo extender. All I need to do is make the HDPE parts and the new Aluminium plate for under the lifter arm, and it would be arena-ready. (apart from needing the spares).
Little progress: I 3D-printed the non-spinner wedges with fun angry eyes.
With the shed cleared out, I was finally able to get some work done on the lifter support. I tapped the bolt holes so they can be bolted to the underside of the lifter arm so it doesn’t flex on lift.
I also got the Dremel out and cut down the old lifter shaft so it fits between the top panels.
I got out the 5mm HDPE and the router table and made the first set of top and base plates, bringing us closer to being fully built. I just need to make the uprights for the lifter, and it’ll be basically done.
