Fatal Deviation, my over-engineered beetleweight
Huge respect for posting your development method and process in such detail. I wish I was smart enough to understand it.
I’m going to bookmark this, take a long run up and decrumb my own neckbeard in an attempt to chisel away and appreciate it on the technical level it deserves.
Beautiful content!
Thank you! I used to spend a lot of time reading big in depth custom RC build threads (when I was supposed to be studying), so like a lot of things in my robot journey I’m doing it for younger me and carrying on the build thread tradition. When I started working on the robot I couldn’t find many other people that were putting DIY electronics in their bot and also talking about it online, especially for beetles. Everyone has their own way of doing things so, hopefully with my way out here in the open to look at, other people can learn and build and do their own things.
When you do dive in, if spot anything that you thinks needs more clarification, just reply/PM/discord DM and I can explain or add it to the post. I mostly wrote it in one big stream of consciousness download, so there’s absolutely some stuff to go back and tidy up. I’m also half way through a PCB for a new antweight. I’ve been thinking about turning that build into a more considered how-to post that goes into more depth on how to design a custom robot board. We’ll see - I just moved and getting my electronics kit set up again is pretty low on the priority list (below “my tools are in a pile that smells of rat pee” and “it wasn’t supposed to rain and I left my welders outside and now it’s rained inside my welders”?)
With regards to de-crumbing the neckbeard, I can recommend training a small bird or rodent to attend to it, like those tiny fish that feed on algae that grows on sharks.
For the three of you still awake and reading this, welcome back! It’s time for electronics deep dive part 2: firmware boogaloo. In this thread we stan Dennis Ritchie. Unlike Fatal Deviation’s PCB, I’ve been actively developing the code the whole time I’ve been competing with the bot, so I’m in a much better place to go into detail.
After the last big post the question of “why” is probably clear, but even in a robot with space for standard electronics I’d probably still build it this way. I like the flexibility and control of writing my own code, and it lets me do stuff that I simply can’t with off the shelf kit. I’m not a control freak I just have very specific requirements, I swear!
Background again: Beyond some basic university courses that I barely scraped through (and hated every minute of), I’m mostly self taught as a programmer. Mainly through google, (reading stackoverflow, API documentation etc) and reading and understanding Arduino examples and libraries as I learned the things I needed to solve problems I had (which is how I learn best). It didn’t come easy, as I didn’t have any more experienced colleagues to learn from, so I spent a lot of time banging my head against a wall or taking a frustration coffee break. In the puruit of learning to programme I wrote a lot of code that controls automated test equipment, and in those cases you really need to be sure there’s no bugs, because it’s really, really embarrassing if your test equipment glitches and blows up a very rare and expensive early prototype. Or if you burn the building down. I’ve done a little bit of one but never the other!
I’ve also written example code and libraries used by undergraduates and other junior engineers, so I had to ensure they could read and understand what was going on. I don’t claim to be an embedded software expert by any means, but as a result of this experience I’ve developed a programming style that’s somewhat akin to megablocks (I could never, ever claim to be as good as lego); modular but somewhat clunky and plodding. Feedback from my undergrads was good, but I had some influence on their grades, so they would say that…
TL;DR, I absolutely understand the struggle that is the jump from haphazard self taught programmer to more organised development. If this is something you’re actively interested in for your own robot but the complexity of the problem is overwhelming, hopefully there’s some tips and tricks here that can help demystify things a bit. I actually never thought I could do it either.
For this post I’m going to assume the reader has some existing programming knowledge - if you can mash together two Arduino sketches, or you’ve done an intro to Python course, that’s probably enough if you keep a tab open to google some stuff. I won’t be going into every single line of code; just going over the general layout and structure, and following the general data flow from pulling the trigger on the transmitter to seeing the robot move. All the code here (except library dependencies) is available to view in full on my github here if anyone wants to follow along at home in more detail.
The main programme is called bot_software.ino. If you’ve ever opened an Arduino sketch (or C/C++ project) it’ll all look fairly familiar. Headers and Libraries included at the top, then some objects declared to speak to various bits of hardware. Lower down are a few global data structures, and then the usual setup and (eventually) loop functions. There’s two of each though - the RP2040 has two cores, so you can run two things at once. It’s not really important in this context, even one core is more than fast enough.
You’ll probably notice three things. Firstly, virtually no comments. I’m of the school of thought that if your code needs comments, there’s almost certainly a more clear and readable way to write it. Screens aren’t 80 characters wide any more, so we can use descriptiveVariableNames in camelCase to make functions readable. I’m also heavily biased against nesting, so I get itchy whenever there’s more than three curly brackets open. This pays off when debugging because many small functions with clear inputs and outputs are easier to debug than one big one full of nested loops and logic. I don’t always claim to write good code, but I always try to write readable, maintainable code, and that’s almost the same thing.
The second is how short the main sketch is - under 300 lines. I try to keep the top level sketch as minimal as possible and handle as much of the clunky, bulky, hardware and platform specific stuff as possible in header files and classes. That way if I design a new revision of the board with different hardware I can simply change the internals of the class and leave the rest of the code the same. No more find and replace chaos, or chasing down function calls all throughout your code, just change a couple of lines in the class and the interface to the rest of the code stays the same.
The last thing is that all the standard Arduino loop does is a ts.execute() function. “ts” stands for Task Scheduler. A task scheduler is sort of like a really stripped down operating system that can only handle timing. A common trap for beginner programmers is the Arduino delay() function, which works great for a programme that only does one thing at a time, but is a real problem when you’re trying to do a bunch of stuff at once, since during the delay the processor does absolutely nothing. With a task scheduler you can break all your functions and routines up into small, easily interruptible chunks, and the task scheduler effortlessly juggles them like a jester with a bowl of fruit. If your function needs to pause for 300ms you break it into two functions and tell the scheduler to come back 300ms later. It’ll go away and use the time productively before coming back 300ms later to finish the job.
Getting an understanding of code written for a scheduler like this can be challenging, because there’s often no obvious starting point for the logic. In this case, the loop starts by checking for new data packets from the radio. This is done every single time the task scheduler loops for the shortest possible latency. While your typical FS2A receiver only updates the output signals every 44hz (I believe, it’s been a while since I used one), the FS-A8S ibus receiver I’m using has a 144hz update rate, so a new packet is received every 7ms.
void readRadioCB() {
  static uint32_t lastRadioTime;
  uint16_t chanData[IBUS_CHANNELS];
  iBus.loop();
  if (iBus.readChannels(chanData)) {
    lastRadioTime = millis();
    radioState = RADIO_OK;
    rxFrame = parseChannels(chanData);
    mainTask.restart();
  if (millis() > (lastRadioTime + 100)) {
    radioState = RADIO_DC;
    rxFrame = { 0 };
    mainTask.restart();
iBus.loop() is a function inside a class I wrote* which will populate the chanData array if a new packet is received. If we’re all good, it tells the scheduler to queue the main task. If it’s been more than 100ms since the last packet then we go into failsafe, and all control inputs are zeroed before queuing the main task.
*I found some functions to decode the ibus packet on the internet, then wrote a class that lets you interface it with a standard Arduino serial interface and access it with a couple of non-blocking functions.
void mainTaskCB() {
  if (radioState == RADIO_DC) {
    rxFrame = { 0 };
    drive.setInputs(rxFrame);
    drive.doMaths();
    writePWM.restart();
  } else {
    inputHandler.restart();
    drive.setIMU(imuData);
    drive.doMaths();
    writePWM.restart();
  Msg_t msg;
  sprintf(msg.txt, "S:%d T:%d FL:%d FR:%d GY:", rxFrame.steering, rxFrame.throttle, driveVals.FL.duty, driveVals.FR.duty);
  Serial.println(imuData.g.z);
  serialBuf.pushMsg(msg);
The main task then performs the drive mixing maths, either with actual IMU and input data if the radio is connected, or with zeroes if not, then queues the function that writes the drive values to the PWM controller/IO expander. If the radio is connected, the “input handler” is also queued, which actually just handles moving the weapon according to the toggle+button on the transmitter. Finally, some debug data is printed to the USB serial port. The serialBuf class I wrote is an extra serial buffer to keep messages ordered, because if you try to Serial.print() from two cores on the RP2040 at the same time all kinds of fun happens.
The drive maths and mixing is handled in src/drive.h. This contains another class I used to abstract the drive maths away from all the logic that makes the robot work. If you’ve ever been inside an Arduino library, drive.h will probably make some sense. There’s an initialiser, a begin function etc. There’s a lot of boilerplate maths or get/set methods, but there’s some interesting stuff too.
void BotDrive::setInputs(Radio_t inputs) {
  static uint32_t lastActiveTime;
  _steering = _deadZoneInput(inputs.steering, _deadZoneSteer);
  _throttle = _deadZoneInput(inputs.throttle, _deadZoneThrot);
  if ((_steering != 0) || (_throttle != 0)) {
    lastActiveTime = millis();
    _deadZoneSteer = _deadZoneMov;
    _driveState = MOVING;
  if ((_steering == 0) && (_throttle == 0)) {
    _driveState = STATIONARY;
  if (millis() > lastActiveTime + 2000) {
    _deadZoneSteer = _deadZoneStat;
    _driveState = IDLE;
When the inputs from the radio are passed into the class, I’m able to perform dynamic deadzoning. That means I can have a large deadzone when the bot is stationary and avoid it making angry PWM noises or creeping, but almost zero deadzone while driving to avoid the notchy feel around the centre that a fat deadzone can cause.
uint32_t BotDrive::doMaths() {
  uint32_t startTime = micros();
  int16_t t = _throttle;
  int16_t s = _steering;
  if (_enableExpThrot) t = _expFunction(t, 2);
  if (_driveState == IDLE) {
    _driveData.FL.coast = true;
    _driveData.FR.coast = true;
    _driveData.RL.coast = true;
    _driveData.RR.coast = true;
  } else {
    float pidOutRads;
    switch (_driveMode) {
      case TANK_OPENLOOP:
        _driveData = _tankDrive(t, s);
        break;
      case TANK_CLOSEDLOOP:
        pidOutRads = _runPID(_steerToRads(s));
        if (_enablePID && (_driveState == MOVING)) s = _radsToSteer(pidOutRads);
        break;
      case COMPUTE:
        _driveData = _tankDrive(t, s);  //bronk
        break;
  return startTime - micros();
This is the main maths function called from the main task in the top level of the sketch. It performs an exponential adjustment on the throttle (I could do this in the transmitter too, and I do use 30% expo on the steering channel, but I like the feel of the plain X^2 curve on the throttle), then checks the state of the drive. If it’s idle (>2s since the last control input) it disables the motor drivers (called “coast” here because when they’re enabled but idle they’re braking by default). Otherwise it selects a drive algorithm. The default is basic arithmetic tank drive mixing with gyro assist. Because the steering input is mapped to +/-4095 (4095 == 100% for the PWM controller) there’s some juggling back and forth between PWM and rad/s at times. I decided that 100% on the steering input is 30rad/s, which I measured by plugging the robot in with a really long USB cable and doing skids while watching a laptop screen and trying not to let the robot eat the cable.
The gyro assist is performed via PID controller. There are better explanations out there for the maths behind PID loops than I could ever manage, but the TL;DR for a PID controller is that it will take an input measurement, then perform some calculations according to the P, I (and sometimes) D parameters to vary an output to try meet a requested target. Usually you have to tune those parameters (sometimes a lot) to balance the responsiveness of the system against oscillation or overshoot, but once it’s properly tuned it’s an extremely useful system. As well as other electromechanical systems like hoverboards and segways you’ll find them on ovens, allowing stable-ish temperature control with an element that only switches on and off only every few minutes, and on lifts - ever notice the lift slow down to a crawl when it reaches your floor and creeps until it’s level with the doors? That’s the PID loop kicking in to line the floors up properly. Fun fact, apparently lift systems are some of the only ones where you’ll find a considerable amount of D. Quiet in the cheap seats.
The way I use the PID controller here is by taking the angular momentum (rotational speed around the Z axis) measured from the IMU as an input and the angular momentum requested from the steering input as a target. The PID controller will do some maths in the background and return an output value that tries to return the measured value to the target value. If an external force like a slipping wheel, or a fork hanging up on a floor seam applies a rotational force to the robot in one direction, the PID will automatically compensate in the opposite direction. This can be best seen when driving on a really low traction surface like dusty polished concrete. Whether stationary and turning on the spot or going full speed, the robot will rotate around its Z axis at exactly the same rate. The moment you centre the wheel, the robot will attempt to continue on in the direction it’s currently facing with an angular momentum of zero (i.e. a dead straight line).
I’ve played with the tuning parameters a fair amount but P = 1 just seems about right. This means the PID controller isn’t actually necessary - since all I do is run it with a P value and no I or D I could just use a far simpler proportional only controller, but it works and maybe one day I’ll want to add some integral for tuning purposes.
Drive_t BotDrive::_tankDrive(int16_t t, int16_t s) {
  Drive_t out;
  if (t > 0) {
    out.FL.duty = -s + t;
    out.FR.duty = s + t;
    out.FL.duty = constrain(out.FL.duty, -MAX_PWM, MAX_PWM);
    out.FR.duty = constrain(out.FR.duty, -MAX_PWM, MAX_PWM);
    if (out.FL.duty < 0) out.FL.duty = 0;
    else if (out.FL.duty <= (MAX_PWM / 8) && (out.FR.duty > MAX_PWM / 2)) {
      out.RL.duty = out.FR.duty / 8;
    } else {
      out.RL = out.FL;
    if (out.FR.duty < 0) out.FR.duty = 0;
    else if (out.FR.duty <= (MAX_PWM / 8) && (out.FL.duty > MAX_PWM / 2)) {
      out.RR.duty = out.RL.duty / 8;
    } else {
      out.RR = out.FR;
  } else {
    out = _notForward(t, s);
  return out;
I split the control mixing that actually decides how much power each wheel receives into two parts - forward, and notForward. This lets me mess with weird control schemes only in the forward direction and just reuse the same basic mix in reverse. Turns out the ideal forward mix so far is pretty basic - I just add the steering and throttle together as you might on a transmitter mix. There’s a bit of conditional stuff where I clamp negative values to zero, and give the inside rear tyre a little bit of power on tight turns to reduce the wheel scrubbing that causes the rear of the robot to noisily wheel hop sometimes. The finished output values for each wheel are stored and then retrieved by the PWM controller task in the main sketch, which tickles the relevant motor controller pins as appropriate.
I have done a lot of experimentation with things like wheel path calculation and tracking but it always seems to work less well than some variant of just adding the steering and throttle values together arithmetically. I think I need more sensors for more complicated drive maths - a laser gaming mouse sensor for ground speed sensing and wheel encoders for wheel slip sensing would unlock full active torque vectoring, traction control, and ABS…
Believe it or not, that’s actually all the main, interesting functionality in the robot. I thought I’d be writing more than that, but while there’s a lot of lines of code total, the majority of it is just wrapping up an Adafruit library, or is the kind of thing I’ve pulled from example code, or is general routine stuff; doing things like reading the battery voltage from an analogue pin, or controlling the RGB, or grabbing data from the IMU via i2c all just becomes background noise after a while, which is why abstracting it away into a class is so helpful when you need to focus on writing code that isn’t spaghetti.
While I’ll be the first to admit my solution is pretty extra, I think there’s a lot of utility in something simpler like an Arduino Nano wrapped in heatshrink; used for advanced control mixing your transmitter might not be able to handle, or to trigger canned movements on multiple servo channels with a single transmitter switch, or deadbug an IMU module to the back to detect which way up the robot is driving and invert the controls.
You’ve probably already seen the big honking downside to building a robot like this - with designing PCBs and writing code on top of all the usual electrical and mechanical design stuff it’s essentially three times the effort involved. I can at least re-use the boards and/or software in other robots. That’s what I tell myself anyway.
I actually trimmed my beard (the source of my power) the other day so now I’m a bit lost and not sure how to end this post, but if you got to the end, congratulations. Like the previous big post, I hope that by putting this out there the scope of the whole “robot with an Arduino in it” thing is a bit better understood. As with before, feel free to reply or PM if you have any questions or think something needs clarification.
Is it that time again? I had to move house a week after Pub Beetles, so I put beetleweight events on the back burner for a while to focus on antweights, but now it’s Champs time and I’ve got a spot as a reserve*. As promised, I upgraded to BBB gearboxes (keeping the existing Nerf motors). If you thought it was cramped inside before, it’s even worse now:
One thing about my robots that I’m really proud of is that, after about ten events (beetle and ant), at every single one I’ve heard variations on “Wow, it’s so fast!”. This trend will probably continue, as with the upgrade to BBB gearboxes I’ve gone from 22:1 to 16:1 gear reduction and now have 35% more top speed than before! With the more robust gearboxes I’ve changed the mixing algorithm, and the inside wheels are now allowed to run in reverse on tight turns. I also noticed that the tyres were only wearing in the centre third, so I changed the wheel geometry for a larger contact patch.
The result of these changes is that it changes direction much faster than before, and feels a little more aligned with the way I’ve gotten used to Fatal Deviant driving. The downside is that for the first time I’m having heat issues, and if I’m too greedy with the reverse element of the control mix the motor drivers start to thermal throttle. I’ve offset this somewhat by putting some thermal interface material between the PCB and the armour tub, and if worst comes to worst I can control how aggressive the mix is from a transmitter knob.
With the gearbox upgrade and the heat issues I think I’m starting to reach the limits of how much robot I can fit inside this robot. While I’m really pleased with the drive, and although I could probably fix the heat issues with a new PCB revision, I’m still held back by the size and power of the lifter servo - it’s only really capable of slow lifts rather than aggressive flips and that’s not really enough for a robot that only seems to spend half a second at a time underneath other robots and isn’t big enough to pin them. What next? I have no idea. (That’s not true, I have endless ideas, most of them are just too silly). One thing’s for sure though, I’ve been practicing my box rushes…
Also, if you like how this robot drives and think the gyro life is right for you, BBB did me dirty a fantastic job and rolled gyro stabilisation into their latest dual ESC, so you too can experience closed loop drive!
*If you’re coming to champs and need some really awkward soldering done, or your opponent has brought one of those annoying door-stop wedge minibots and need a minibot to deal with it (get Birdemic stuck inside it), hit me up.
I still see some daylight - you can pack it harder next time.
Fingers crossed you get a full spot, or at the very least a zesty whiteboard. Looking forward to seeing it in the flesh/metal.
Don’t, I already have to use tweezers to work on it; it’s half ship in a bottle, half pretentious chef plating individual leaves…
I don’t mind either way to be honest, current 1v1 record is I think 3-11 so it’s a bit of a Beautiful Disaster and if I do compete I’ll be lucky to make it to the round of 32, but I’m still desperate to hear the noise it makes when it bounces off the roof. I think Ari is bringing Frenzy as a reserve too so fingers crossed this is the event it happens? Regardless, there’s a prize on the line for the first roof shot and/or explosive disassembly (but not a very good one).
Sometimes people ask me if I’m precious about my robots and struggle with seeing them damaged, but there’s nothing better than seeing it take an absolute pounding as inspiration for the next iteration. Sometimes that’s the entire goal. Can you tell I used to be a test engineer?
Wasn’t intending to post an update after champs, since as a reserve I only had the three whiteboards, but hot damn that’s how it’s supposed to work! Despite ending up in the pit during every single fight, the bot was absolutely on point for all of them (even if my driving wasn’t always). The BBB gearboxes did their job, and for the first time ever I didn’t turn a gearbox to glitter. The extra top speed came in clutch with some great box rushes too, and finally I had enough power and traction to push other bots around. The heat issues from testing turned out to be a non-issue (probably because I wasn’t heat soaking the board and chassis tub with back to back tests), and in fact it came out of the arena cooler than previous events due to the extra efficiency of the planetary gearboxes.
It’s a real shame we didn’t get to see John’s Autonomouse running, while my steel chassis tub is a hard counter to most heat based weapons, it would have done a number on my wheels and lifter arm, and I don’t think any of us know what to expect from an autonomous robot. Abracagrabra, Buttercar and Doombot were all great opponents in the first two control bot whiteboards, and there was some fantastic back and forth action with robots going everywhere - I’ve watched the fights back and I still can’t really tell what was happening. The final whiteboard was a spinner one, and I finally got to see a glimmer of what Fatal Deviation is meant to - slam into a big spinner the second the fight starts, stay on top of (underneath?) them, and keep them bouncing around unable to regain control, without really caring if they land on the bot weapon-first. Despite some big hits from both Icebreaker and Wishbone (we need to have words Luca, you promised to help us gang up on Icebreaker!) the only damage sustained was a wonky armour panel over the lifter, a missing tyre, and a slightly bent axle. Very confidence inspiring for future events!
Also, shoutout to my three minibot drivers, two of whom won their whiteboard (the third ending up in the pit, apparently out of pure self preservation) - Angus the spectator (who I’d met 20 minutes before the first whiteboard and handed the controller to despite him never having driven a robot before), Sam the commentator (who was extremely complimentary about how the minibot drove, thank you!), and one of the Doombot team members whose name I didn’t catch or remember - sorry! Despite getting smashed against the arena wall by Wishbone and having a lifter arm, wheel and gearbox totally sublimated, crowd favourite Fatal Deviant carried on working and still lives to fight another day.
Finally, thanks again to the BBB crew for putting on another top tier event, as always a great day out and I really appreciate the perfect balance of silly and competitive. Well done to all the real competitors too, putting on some absolute banger fights.
I’m booked in for a day of testing down at Chichester Uni next month. I’m hoping to run telemetry for some fights, so I can finally fulfil my promise of cool graphs that I made way back at the beginning of this monster thread. Otherwise, what next for Fatal Deviation? More titanium (sparks go brrr), more magnets (drive really go brrrr), more guest minibot drivers.
The Hobbyweight champs at Chichester uni were a tonne of fun, really relaxed vibes and it was great to spread out into the workshop a bit (I really needed the bench space with a laptop along for the ride). Gareth has put together a really impressive facility and having two hobbyweight arenas within van-sasquatching range is giving me ideas.
Anyway, the cool graphs all three of you were waiting for - OP finally delivers. I managed to get full telemetry for four fights, and possibly a fifth (I forgot to press record but I think I copied it from the scrollback). Unfortunately due to arena camera issues and me not having enough hands to set up my tripod, only two of my fights made it to video.
The most exciting was my whiteboard against Frenzy. Being the final fight of the day I was in full robo-masochist mode and I asked Ari to send it. They delivered the goods, immediately going in with 100% weapon power and delivering multiple roof shots, even in the taller hobbyweight arena (out of frame from my camera but confirmed on the arena camera). The roof shots earned them the promised (not very good) prize, an unpopulated PCB with the words “I roofed Fatal Deviation and all I got was this shitty PCB” written on it.
The arena camera also captured the non-spinner beetleweight rumble, which was three minutes of insanity. The telemetry from this fight is really useful for future PID loop tuning, but unfortunately it goes quite considerably out of sync with the video and right now I don’t have the time to figure out why or synchronise it manually. When I do I’ll upload the video, but for now here’s a gif of me Tokyo Drifting a minibot into the wall:
boop
Some things I learned from the telemetry:
The bot rebooted twice during the fight with Frenzy, however it rebooted cleanly without triggering the watchdog timer, taking only 300ms to reboot it was good to go by the time it hit the ground. I don’t think it’s power - I trust my wiring, the LEDs don’t flicker on the video footage, and there’s no evidence of shorting on the inside of the armour tub. I suspect the reboots are actually due to really big hits in just the right direction literally stalling out the crystal oscillator that clocks the CPU, causing it to reset. I’ve heard about this as an issue in meltybrains, but it’s interesting to see big hits from a vertical spinner cause the same issues.
I couldn’t truly calculate the highest G force experienced, because it exceeded 24G - that’s the absolute vector when two of the 16G accelerometer axes are fully saturated. If this were Mythbusters all the little shock stickers would be broken.
I think I can be more aggressive with the PID tune. With the worn out Lego tyres I was running (and still no magnets) the robot didn’t have a huge amount of traction on the arena floor, and when the robot felt lazy to turn I blamed it on that. However, looking back at the telemetry data I can look closer at the PID response. The following screenshot is from the beginning of the rumble, when I did a quick 360 spin on the spot just before the fight:
The graph X axis is viewed as “time since” - the beginning of the movement is the right side of the graph and it’s read right to left. It makes more sense when viewed alongside the live video! The drive maths uses 10 bit PWM, so all the values are scaled to this (the steering is a little higher due to the way it’s mapped from the receiver values but anything >4096 is clamped). Blue is steering input from the receiver (target angular velocity), red is the Z axis gyro measurement from the IMU, and green is the PID output value. All are scaled so that 4096 = 35rads/s (2000deg/s), which is the maximum rate the gyro can measure and also conveniently a little faster than the robot could spin on the spot on the slippery kitchen floor of my last flat. This is a good sample to use as it’s (almost) a square edge step change input, which is the most difficult input to tune a PID loop for. Looking at this graph, I see:
  • The PID output rises quickly to match the target (good), but also drops off as the robot begins to rotate (bad).
  • The PID output stabilises at around 2000. If this was the maximum speed the bot was capable of rotating on the spot I’d expect the PID output to be higher than the gyro reading.
  • If I check the telemetry log, I can confirm this by looking at the duty cycle of the motor drivers. As suspected, they’ve been backed off to around 85% at this point and while the wheel on the controller is at the endstop the bot could go faster. This is what’s known as “undershoot”.
There are mathematical models for calculating the ideal* PID tuning values (and this is a good idea for a system that responds very, very slowly or could go very wrong, like a lift or an oven), but once you’ve tuned enough PID loops you learn to read the graphs and with a step by step process and a sprinkle of vibes you can get much the same result. This blog post covers both approaches better than I could!
*there is no “ideal”, just good enough. I am happy to trade some stability for faster response.
The result of this discovery is that I probably need to implement a PID auto-tune routine if I want to fully optimise the drive. I’m sure that each arena is going to have different tuning values, and manual tuning simply isn’t practical. Thankfully I have a couple of antweights running very similar drive software that I can use for testing without sending a beetleweight through a wall.
I have so much telemetry data that I have no idea what to do with. It will eventually end up on github, but if anyone has any requests for graphs or data let me know. There’s not many robots out there running telemetry, and even less making their data public, so I will clean things up a bit and put them on github when I get a chance.
Finally, the post-Frenzy gore everyone was really here for. It looks worse than it is - a couple of wheels, a couple of forks, a bent axle, and an absolutely enormous dent in the back side. Nothing a few minutes with a big hammer can’t fix. Ari got the axle (that I had to hacksaw in half to remove from the robot) as a trophy and will get the Softox Hardox fork eventually - I had to cut the TPU wedge in half to remove it and the mounting bolt is almost too bent to remove.
Dojo in a few weeks. Probably won’t have PID auto-tune, probably will have magnets.
Magnets were a disaster. Spent the whole day getting stuck to the floor, struggling to turn, overheating the motor drivers, and doing unspeakable things to a weak cell in one of my battery packs. Somehow went 3:0 and came 2nd on points, but it doesn’t really feel earned when my robot barely worked and two of my opponents came into the arena with mechanical issues from previous events/fights. I did remove the magnets and score a real win against Baby Dead Bod, but only because the battery came unplugged after two massive hits.
Turns out when you build a long robot that relies on drifting around under the influence of the stability control to turn quickly, adding a bunch of traction and eliminating wheel slip causes big issues…
I’m off to Brawl on Saturday, and I’m excited to see if months of antweight grind has helped improve my driving. Unfortunately this may also be the last serious tournament run for Fatal Deviation, as after receiving a beatdown at pretty much every event (and then being pounded back into shape with a big hammer) the welds on the chassis tub are starting to split. I’m hoping it survives the day so I can keep the robot going, but if anyone is finally able to make the insides of the robot become the outsides of the robot, that would be pretty cool also.
To illustrate the absolute pasting the robot’s taken in the past couple of years, I annotated the battle scars patina with my best guesses for who did what. I think Frenzy wins through combination of quantity and size of hits, but Icebreaker also did extremely well considering we only had about 30 seconds of rumble together. Bulbaroar wins “most aesthetic damage” with a really nice scoop taken out of both the stainless chassis and the titanium top plate.
Just because the armour tub is bent, twisted, and cracked, doesn’t mean I’m not still making improvements, however. I’m fitting a plate over the gap in the back of the armour tub (that used to be clearance for the lifter in the first version of the bot) to hopefully tie it together and stiffen it up, as this portion of the tub is the weakest and is where most of the bends happen. I’m also stiffening the servo and weapon assembly in the hopes of more decisive lifts.
Additionally, one of the things I learned from my antweights is that a shear line in the wheel encourages wheels to leave the chat cleanly on big hits, rather than sticking around jammed up and causing mobility issues. Since the TPU wheels on Fatal Deviation won’t shear the same way as the PLA-ST antweight wheels, I took some of the old machined silver steel axles I made and hardened them instead.
This involves getting them cherry red on the gas stove, then quenching them in a jar of water. This causes the grain structure of the steel to crystallise (becoming martensite), and if you’ve ever dropped a file or snapped a drill bit you’ll know the texture. While this makes the steel extremely hard, it also makes it extremely fragile, so I tempered them in the air fryer at about 200c for 30-40 minutes. This is about where I temper knife blades when I make them, and I’m yet to bend or snap one!
This causes some of the non-martensite crystals in the steel to loosen up and join together and form austenite, which increases toughness at the expense of hardness. Hopefully these axles will take some smaller hits without bending, but shear along one of the cross-drills or the vestigial circlip groove on really big hits, allowing the robot to drive around on three wheels without a tyre dragging.
Finally, I thought it would be fun to take the robot to the skate park, so I made a silly little video edit of the trip. It’s a little harder to drive around the park than an actual RC vehicle with real suspension and steering, but I do kinda wish my RC trucks from back in the day had the ability to self-right!
Dude I love the logic behind the hardened axles. Really cool to see you going to such extremes to try stuff most people wouldn’t have thought of.
Well it only worked? Despite going out in the round of 32 yet again I feel that was definitely my best performance with this robot ever, winning my three way against an eggbeater and a drum, not getting flipped too many times by Flick2, and coming out on top again in a rumble versus two spinners (as much as coming out on top is a rumble is a thing you can do). The stiffer new axles seemed to work great, and despite taking some direct hits that would certainly have banana’d the old stainless axles they’re still running straight and true. All that antweight practice paid off too, and I managed to avoid the pit in every fight (just), although the curse seemed to have passed on to poor Speeny who ended both our fights in the pit.
“I didn’t hear no bell!”. I actually only had to replace a fork, a couple of wheels and a stripped bevel gear (my first since switching to 0.8M, and my own fault for not shimming it correctly) all day. You can see the piano wire reinforcement in the lifter in this shot, which is what gives me the confidence to repeatedly open the lifter into an opponent’s weapon and see what happens.
With all that said, I think this is as far as I can take this archetype. Any improvements I’d make - more traction, more fork game, and a weapon that’s more than just a spicy self righter and aggressive tapper would require a bigger robot, and I’m both too attached to this silly little guy and too nerdsniped by new ideas to commit to a full, version 3 redesign. It will live on as a backup bot/chew toy for Dojo spinners/(literally) bulletproof loaner for friends who want to have a go, and also in spirit with Fatal Deviant, which has had a redesign and is now a cromulent flipper in its own right (after I managed to shoehorn in the same standard size servo I use in Birdemic), regularly sending opponents almost a foot in the air and far more successful than the beetle version ever has been. That probably deserves its own post at some point - maybe I should condense all my antweight threads into one?
In terms of new beetleweights, I have mentioned a few ideas previously, but they’re still on the back burner until I get the hefty side of my workshop back up and running. Instead I picked something that I can construct in my tiny box room office. Still early days but all the bits look like they’ll fit together, even if I have to buy a bigger 3D printer to print normal-sized beetleweight parts with.
Two words: Big Birdemic.
But first, a very ill advised BEV collaboration with my dad - 100% genuine sapient pearwood, straight from the counterweight continent.
