Guide: How to solder robots good
Hello everyone! In my time at various events round the country I have seen many many robots, and while everyone is super cool and so are your robots, good lord I have seen some crimes against electronics. Not only can bad soldering look nasty and really stand out against an otherwise top tier build, it really sucks to short a couple of pads and blow up a speed controller, or lose a fight due to a broken solder joint. A little while ago I decided to put this guide together as a quick reference on how to solder some of the common joints and connectors you’ll find inside a robot, which is not really something that most generic soldering guides (like the excellent Adafruit guide) explicitly cover.
First, some background on myself and my experience with soldering. When I was about 10 my Hornby train set broke, and rather than fixing it himself, my dad (who himself started his career with a brief stint as an R&D tech for an aerospace company) thrust a soldering iron into my hand and taught me the basics. I’m 33 now, so I’ve been inhaling lead fumes for over 20 years at this point. I also persuaded my previous employer to send me on an IPC-7711 course, which is the industry standard soldering/assembly/rework course, and between myself and a colleague we ended up teaching the basics of through hole and surface mount soldering to many of the undergraduate/intern/junior engineers that came through our lab. Many of them insisted that for various reasons they were terrible at soldering and would always be terrible, but as a rule we’d have them sticking down millimetre scale components under a microscope within a couple of hours.
The result of all this is that I’d like to think I have a pretty good understanding of the things that beginners need to know, and how to explain it in terms that make sense to the person actually holding the soldering iron. Soldering is still one of these skills that is mostly passed on in person, usually in the workplace between technicians and production operatives and engineers, and as a result many people learning it for the first time at home with no outside influence develop their own (often esoteric and weird) techniques, and subsequently struggle. I have found that once you teach someone the “correct way” it all suddenly gets a lot easier and makes a lot more sense, and that’s what I’m hoping to do with this guide. If you’re interested in going deeper, picking up a copy of IPC7711 is a good move - the more recent versions are paywalled (although if you work in the industry or industry-adjacent, ask around!), but thankfully the internet archive has a vintage 2001 copy available to download, and much of what I’m about to go over hasn’t really changed since then (or even since 1970, really).
Things I am going to cover:
  • Equipment and consumables
  • Safety
  • General tips and tricks
  • XT60/XT30/MR30 connectors
  • Wire splicing
  • Surface mount wire pads (ESCs etc)
  • Through hole wire pads (Receivers, Malenkis etc)
  • Solder tags (Brushed motors, switches etc)
I believe that covers the majority of your everyday robot soldering, but if I have missed anything please let me know - I will be taking requests!
I will also apologise in advance if any of the photos or video clips are out of focus, badly lit, or obscured slightly by my hands. I had to do all of this with a camera on a tripod between me and the work, and at times it was more than a little awkward!
Equipment and Consumables
Soldering Irons
IMO one of the most pervasive and detrimental myths in soldering is that for vaguely small stuff you need a really tiny iron. Unless you are doing really, really tiny surface mount stuff under a microscope, this is simply not true. Below is a photo of the two iron tips I use most, for everything from surface mount (down to 0603 passives and 0.5mm pin pitch ICs) and tiny 26AWG antweight wires all the way up to 14AWG featherweight wires.
Left is a USB-C powered TS80 I use at events, right is a benchtop generic ebay jobber I use at home. The large tip size provides a bunch of thermal mass, so even the tiny 18W USB-C iron can punch far above its weight, as when you dump a bunch of solder into a joint, the iron stays hot. If you use a tiny tip, just touching it to the joint is sometimes enough to bring the temperature down below the melting temperature of the solder. This means you have to keep the iron on the joint for far longer than a big tip, which increases how much heat is pumped into the board, and can cause blobby ugly joints, melted insulation, and lifted pads - remember PCB pads are only held to the fibreglass substrate with glue!. The important thing here is that both tips have sharp edges, so you can still get a corner of the iron into a small joint while preserving thermal mass.
When it comes to choosing a soldering iron, something with real temperature control is a huge benefit. An iron with a screen and buttons, or numbered temperature dial, usually means it has a feedback loop inside, which means that it’ll sit at a constant temperature when in the stand, but when you start soldering the feedback loop will crank up the output power as much as it can to preserve the temperature at the tip of the iron. This is much easier to deal with than an unregulated iron, which will fluctuate wildly and can leave you with cold joints and a cooked tip at the same time. You should avoid this style unless it’s literally all you can afford and someone gave it to you for free:
Slightly more usable but still not ideal are power-adjustable irons. While they do have a dial, it’s just a volume knob - the iron might change temperature in the stand, but it does it by lowering the total power, so there’s no way to have a cool iron that can still solder big connectors without it slowly cooking itself in the stand. They can be identified by their vague, un-numbered dials:
Thankfully you no longer have to spend £300 on a lab-spec Weller to get good temperature control, as China makes a whole range of pretty decent adjustable irons for cheap. Ideally you want to pick something of at least 60W, assuming it’s a standard interchangeable sleeve tip and not something more fancy. My TS80 has the heating element baked right into the tip, which is how it gets away with only being 18W, but the downside is that new tips are expensive and have to be treated with some care. The OG TS80 is discontinued now, but the manufacturer Miniware has a range of similar irons (USB and barrel jack powered) for not crazy money. There’s also the Pinecil and a few other options of its ilk, but I’m not massively familiar with those as I’m still happy with my TS-80. TL;DR if you can change the temperature and it wasn’t £12 on Temu it’s probably fine.
You will notice the Parkside iron photo contains a sponge. This is for keeping the tip clean, which is vital to good joints. Sponges aren’t great, because putting a hot iron into a wet sponge will cause some amount of thermal shock and eventually damage the plating. I prefer these brass pube-style tip cleaners:
Finally, after getting tired of people’s “my iron is too big for X or Y” excuses on the internet, I decided I needed to make a point that it’s more about heat management and tip geometry than overall tip size, so here’s a video of me soldering an 0805 (2x1.25mm) surface mount resistor with a ~20x30x50mm roofer’s soldering iron that I heated up on a gas stove:
Consumables
There are two main choices for solder composition: 60/40 (or 63/37) tin/lead, and lead-free. RoHS (regulation of hazardous substances) rules mean that manufacturers are no longer allowed to use lead for production stuff, which has made it harder and harder to buy in recent years, but IMHO it’s still the optimal choice for home gamers. While lead free solder is finally good, the real good name brand stuff can be expensive, and the cheap stuff (think the little coil in a tube that might have come free with your iron, or you bought at the high street hardware shop for a fiver) is pretty nasty and makes everything that much more difficult. Yes, the lead stuff contains lead, but it’s not as bad as it sounds - I’ll cover that in the safety bit.
It’s really best to pick a flavour of solder and stick to it. Switching between solder types regularly isn’t really advisable, as the solder bonds with the tip plating and you’ll never really get rid of all the old solder - this can cause bad joints, or damage the plating. If you spend a lot of time working with things that have previously been soldered with lead-free, it’s best to stick with lead-free solder for everything, or at least keep separate irons/tips. Most generic Chinese-manufactured use the same four-pin GX16 “aviation” connector, and new irons aren’t too expensive, so keeping a couple on the rack with tips dedicated to different jobs isn’t the worst thing.
Flux is really, really useful. If you’ve ever watched Louis Rossman repair Macbooks on youtube you’ll know that there’s no such thing as too much flux (until it comes to cleaning time). While solder does (or should, unless you accidentally bought plumbing solder) have a flux core, supplemental flux is a good idea. It’s a high temperature fluid or gel that coats the surface of the joint and prevents air getting to the molten metal and oxidising it. An oxidised solder joint won’t flow right, and will cool in a weird crystalline lumpy mass, but the good news is that if this happens you can just blob some flux on top and re-flow it with your iron and it will reform nicely. Any oxide will be pushed to the surface and stick to the flux residue, ready to be cleaned off later.
I like flux pens, as you can just scribble and squish some out into the board without having to scoop it out of a tub. I like Chemtronics or RS Pro, and would recommend avoiding generic cheap options as it’s a bit of a gamble whether it’s any good or not. Look for no-clean flux rather than anything else, I once bought “water soluble” flux by accident and even when I thought I had washed it off, after a couple of weeks all the numbers coming out of my prototype looked funky. When I opened the lid of the box the flux residue was turning all the copper on the board into green fur.
If you find yourself cleaning up after yourself a lot, solder wick is really useful. It’s a woven copper strip coated in flux, and if you bring a cleanly cut end (with a bit of extra flux soaked into it) into a molten pool of solder it’ll suck it up into the wick and save you a bunch of time.
A selection of heatshrink in different sizes is crucial. I like to have some glue-lined stuff in larger sizes for strain relief. Do not use electrical tape - it’s not heat-resistant, so if your bot gets hot it will melt and expose solder joints. It will turn to goop if you leave the robot on a shelf for a couple of months between events. Everything will be sticky. Don’t do it. If you really must use tape, use kapton tape. It’s a little pricey for a roll, but it’s extremely thin so a small reel is miles of tape. It’s heat resistant up to about 350-400c. It’s used on spaceships and is a cool gold colour. Do not use electrical tape.
Strain relieving goop is also really useful. Some folks use hot glue, but I don’t like it for a couple of reasons. The first is that it’s actually pretty hard once set (especially if you’re somewhere cold, like Robodojo in December), so it just shifts the strain to a different part of the wire. The second is that it doesn’t stick very well, and it’ll often peel off PCBs and cease to relieve any strain at all, sometimes even making the problem worse as it pulls the insulation back up the wire. Instead I prefer to use neutral cure/electronics grade silicone. This is basically the same consistency as clear bathroom silicone sealant, except it doesn’t release acetic acid when it cures, so it’s safe to use on electronics. My go-to brand is Chipquik, although it’s only worth buying as an add-on to an existing order from Rapid/Farnell etc, as it’s about £4 a tube there (where the free postage threshold is about £30) and about £12 a tube anywhere with free postage.
While I haven’t demonstrated it at all in this thread (due to my tendency to get any goopy chemical absolutely everywhere and also me leaving the lid off the tube and it turning into a solid lump of rubber), do keep it in mind, as for any of the joints in this post there’s probably a way you can goop it up with silicone and add some extra strain relief.
Other Tools
You will need some other tools. Side cutters for cutting and stripping, and something for heatshrink at a minimum. Above is what I keep in my tool kit - the Knipex stuff is a little bougie for hobby stuff (but top notch when you’re upside down under a test rig, yelling expletives at whoever worked on it last), but since I now work freelance I have to provide my own tools that I know I can depend on, and I really like the Knipex stuff. The big cutters/strippers/pliers/ferrule crimpers are probably a hard sell for home gamers, but I do really recommend the side cutters, and they’re not too expensive compared to a generic set. I have always found that the generic cutters you find in in the workbench doom pile at hackspaces to be uncomfortable and fragile, and more than once I’ve tried cutting a wire and had a tip fly off in the opposite direction.
While I use a battery powered hot air gun for heatshrink at home, I keep the jet lighter in my toolkit to use at events and when working in the field. It’s better than a regular lighter as it works in any orientation without burning your fingers, and you can keep the heatshrink well away from the flame and shrink it without charring it.
The grey jobber on the right is a solder sucker. These are amazing for quickly removing large amounts of solder from pads, and from clearing through-holes of solder. I really recommend a genuine Engineer brand sucker like mine - they’re reasonably priced, compact, and have more suck than any other sucker I’ve ever used. There is a knack to using these - some fresh solder on the joint helps a lot, and so does waiting a couple of seconds longer than you think you need to.
Finally, YMMV but I really appreciate tweezers for working on my obnoxiously compact robots without burning my fingers, even if they make me feel like a pretentious chef plating micro-greens while I use them.
Safety
Lead solder sounds scary, but metallic lead on its own is actually not particularly dangerous. It’s so unreactive that your body doesn’t really absorb it very well, so any damage is usually done through A. cumulative exposure to high levels, or B. more bioavailable lead-containing compounds. The Romans all had lead poisoning from lead acetate, caused by heating vinegar and acidic wine in lead pots. Lead in general is pretty low on my list of “ways you can die doing robots”, far below “testing a spinner outside of a safety box while standing next to it” and “breathing lipo smoke”.
As I mentioned above, I’ve been soldering for over 20 years, mainly with lead-based solder as I’ve mostly been soldering at home for hobby purposes or at work with lead for non-production R&D purposes. A couple of years back I volunteered for a blood test for lead at work, as we had a colleague in another team who was worried about sharing a lab with people soldering with lead while trying for a baby, and I wanted to reassure them that they didn’t need to take any special precautions aside from not doing the soldering themselves if they felt uncomfortable with the idea. The results came back as below the detection threshold for the test, meaning that to the surprise of people who know me I do not in fact have lead poisoning. The lady on the phone who gave me the results was actually surprised that we’d bothered with the test, as the company “usually only works with people who are moving powdered lead around with shovels”.
This doesn’t mean you shouldn’t take precautions though - don’t chew the solder, don’t lick your solder joints to clean them, and wash your hands before eating or drinking. Don’t put your coffee next to your tip cleaner, as little bits can fly off the tip of the iron and land in your coffee.
A bigger danger than the lead is the flux, as it’s usually some kind of organic compound (often derived from pine rosin) and you’re likely to inhale it. This is actually slightly worse for lead-free solder as it requires slightly nastier, higher temperature flux. Fume extraction is ideal, but it’s not always practical at home, so I will open a window and my office door to get some airflow through the house while soldering, even when it’s cold outside - you don’t want it sitting around in the air while you work. Sometimes you’ll get a face full of flux vapour, don’t huff this. You can blow on it gently instead to get it out of your face.
Also, it shouldn’t need to be said, but I’ll say it anyway. Hot things are hot. Don’t touch the iron. If you drop the iron, don’t try catch it (ask me how I know), just let it fall and pick it up by the cord. If you do accidentally touch the iron (it’s a minor hazard of the process), you’ll probably be fine, as you get a half second or so to escape while it boils all the moisture and oils off your hand. If you do smell bacon and hear sizzling, get it under a cold tap and run cold water over it for a few minutes.
Finally, if there’s any kids or pets around, try keep them away while you’re soldering. They might try eat the solder, or huff the fumes, or yank on the iron cable and have it land on them. I don’t have kids or pets but I did have undergrads and there’s not much difference between a grumpy toddler and a hungover undergrad but YMMV.
General Tips and Tricks
There’s a few things you should always be doing, regardless of the operation you’re performing. The order of operations is as follows:
  1. If you’ve just switched your iron on, wait for the iron to get to temperature. Some take longer than others, and if you’re impatient the first few joints won’t flow right. Don’t believe the temperature display - often there’s some delay between the sensor and the tip coming up to temperature.
  2. Clean the iron tip by sticking it in your brass tip cleaner a few times, or wiping it on your sponge. You don’t want claggy old solder making it onto your joints.
  3. Give it a dab of fresh solder. A little pool of solder on the tip makes all the difference for thermal transfer, as it will flow to provide way more contact with the joint than a clean, bare tip.
  4. Solder the thing. Solder flows towards heat, so if the solder isn’t flowing the part is either not hot enough, or dirty - sometimes a little sandpaper action helps, especially if a board has been sat out exposed to humid air for a while.
  5. Don’t push down with the iron! You shouldn’t need any more force than the bare minimum that is required to keep the iron held down to the joint. Sometimes you’ll see people leaning on their iron with all their might - this generally means the tip is too dry and they’re relying on sheer force to get the iron to make contact and transfer heat.
  6. Let the surface tension of the solder do the work. If you’ve used enough heat and enough flux, and the goldilocks amount of solder, the geometry of the joint alone should provide a nice clean fillet.
  7. If there’s a little too much solder, a clean iron with a tiny dab of fresh solder usually fixes it.
  8. Once the joint looks good and you’ve removed the iron, don’t move it! Any movement during cooling will cause the joint to crystallise and weaken. With lead solder this is obvious as it looks milky and lumpy. This is a downside of lead-free solder, as most types always looks a bit lumpy and milky, and you just have to trust that you did it right. If it does crystallise, some flux and a re-flow will fix it.
  9. Clean the tip again! You don’t have to do it after every single joint, but depending on the size of the joint, sooner or later you will start to get a smooth blob or rough lumps of solder building up on the tip, and that’ll make subsequent joints more and more difficult.
  10. Reapply a little solder, even if you’re putting it back in the stand. You don’t want any of the tip plating exposed to the air if you can help it, and some solder helps protect and preserve it. This is especially important for irons like my TS80, where a new tip might be £20+ (:sob:)
I will also cover temperature settings here. Another pervasive myth is that “hotter is better”, especially for big joints. While it might be a way to struggle through a joint that’s too big for your iron and is sucking heat out faster than the element can put it back in, in general it’s a bad idea, as it just cooks the flux off faster. For lead solder you’ll likely not need any more than 330-350c, and for lead-free solder maybe 380c. IPC7711 actually lists temperatures in the 260-280c range for a lot of operations, but that is only 80-100c above the melting temperature of lead solder and likely intended for big >100W production/rework lab irons which don’t cool down much when you apply them to the joint. A little boost in temperature helps give you and your light duty consumer iron some headroom.
Workholding
Often we’re working with small, loose connectors, and they don’t have enough mass to stay put on the bench while soldering, and you’re unlikely to get a solid joint on a connector that’s sliding around on your bench. Usually I just improvise - I have used everything from my reel of solder, to power tool batteries, to masking tape, to blu tac, but if you want something a little more dedicated, there’s a range of clampy things on arms that help - the keyword to search for is “helping hands”.
Apparently there’s a 32000 character limit here and I’m way over, so this is part one of two.
Typical Soldering Operations
XT60, XT30, and MR30 connectors
Probably the most common connectors in combat robotics are the XT60, XT30, and MR30 - XT30s and MR30s use the same pins, but the MR30s have three of them. They’re pretty great, and far easier to solder than the old Deans plugs from RC car racing back in the day (OGs will remember, and probably still have T shaped burns on their fingers, also and lots of slightly melted connectors that don’t quite fit together in a box somewhere). They all use the same solder-bucket style pins, but since XT60s are a lot larger and easier to see I’ll start with them.
I’ll also add that a lot of this is stream of consciousness, so it’s best to read through the whole thing before focusing on specific sections, as later sections may assume that you’ve read previous ones!
XT60
Your first step is to find a mating half for the connector you want to solder. While they’re pretty heat resistant they are thermoplastic, so you can melt them, and the brass connector pins will wander off, leaving you with a connector that doesn’t plug into anything. A mating half keeps it all indexed if things get a bit melty.
Next, strip the wire. For an XT60 and with wire sizes up to AWG14 or so you want the exposed copper strands to be about 6mm long, which is roughly the depth of the solder bucket. You can make AWG12 work, but it might not fit all the way inside the solder bucket - if this is the case you’ll want to only strip about 3-4mm so that it sits inside only the open section of the solder bucket. Twist the strands together a few times with your fingers so they stay together. It should look like this:
Next you’ll want to tin the wires. Don’t forget the general steps of cleaning and tinning the iron.
tinningd
(Animated clip, open in new tab if it doesn’t move for you)
You can see how easily the fresh solder flows from the iron into the wire. The fumes coming off the iron is the flux - this is good, and an indicator that there’s flux on the iron. If the smoke stops, the iron needs more solder (and the flux that comes with it). You’ll also notice I’m trying to feed the solder into the wire, rather than onto the iron. Solder flows towards heat, and will wick onto copper wires and connectors if they’re hot enough, so you’re trying to get it to soak into the wire with all the flux it contains, in preference to sitting on the iron burning off the flux as you try in vain to get a blob to soak in.
When tinning wires you ideally want to keep the solder to the exposed portion of the wire. If it enters under the insulation you can end up with a hard section of wire that produces a single point of strain. You’re also trying to do it quickly enough not to melt any insulation, but thankfully we mostly use silicone insulated wires for combat robotics, and these don’t melt like PVC insulated wire does.
Next you want to tin the solder bucket on the XT60. Ideally you want the solder coating the whole inside surface, with the surface tension holding it in a nice dished convex meniscus. For whatever reason this isn’t always possible with XT60s, as it doesn’t quite like to stick to the top surface of the solder bucket, but you can usually get pretty close:
tinning-xt60d
Now that both sides are tinned, you can easily reflow the two sides together in one operation. You’ll want to do this quickly while there’s still flux on the iron, but if it’s a little crusty afterwards (like my joint, as I took my time trying not to knock the camera over) then a little dab of fresh solder once the joint is soldered will work wonders.
Also, unless the other ends of the wires are still bare, this is the time to slide heatshrink over them, but you will forget occasionally. I’ve been doing this kind of thing for years and I still forget every now and again and have to desolder and wait for everything to cool before starting again…
solder-xt60d
You should now have some relatively neat solder joints, and once they’re cool you can slide the heatshrink over. If you’re impatient (like I sometimes am) and don’t wait the heatshrink will shrink onto the wire before it’s all the way over the pins, and you’ll be forced to desolder and fit a fresh piece. If you’re worried about the wires being tugged around, a second layer of heatshrink that holds both wires together is a good idea. I like the glue lined stuff for this use, as it has more structure and doesn’t slide around.
XT30/MR30
The process for an XT30 or MR30 is much the same, just smaller. You’ll want maybe 4-5mm of tinned wire up to AWG18, and 3-4mm for AWG16.
While MR30s come with a little plastic cover for the pins, it doesn’t fit over heatshrink on larger wire sizes, so I prefer to use heatshrink as the plastic cover can come off and expose the bare solder joints. Like the XT60 you can use glue-lined heatshrink for some extra strain relief on the wires, but for the smaller connectors you’re able to slide it over the connector body as well as the wires and pins:
Wire Splicing
Whether it be an “oops too short” moment, or a broken wire during a fight, or you need somewhere to connect a power LED, you’ll probably need to join two wires together. You’ll often see people just stick two tinned wires next to each other and melting the solder together (lap joint), sometimes with some tape to hold them together, or those crocodile clip “Helping hands” stands, or sometimes a friend with asbestos fingers. This works if you’re in a rush but it kind of sucks. Solder is a really bad mechanical connection, and often the two lap jointed wires don’t sit parallel, meaning the entire joint is held together with a little tiny connecting blob of solder. There are better options!
*Lap joints are covered in IPC7711, but crucially they require a piece of very thin single core wire to be wound round the joint before soldering. Not really practical at a pit table.
Hook Splice
Also known as the Western Union splice from back when Western Union ran telegraph wires across the US. Crucially for this splice, the wires themselves provide the mechanical connection, and the solder exists just to stop any minor movement and to provide good electrical conductivity.
While it works better for single core wires, and can end up a little messy with stranded wires, this is the best option if you’re doing wiring at home before an event. It’s absolutely the strongest, as the resulting joint will be stronger than the wire itself. The downside is you need to strip a lot of insulation for it to work correctly, so it’s not so great for emergency repairs where you might not have much wire length.
First, you want to strip about 20mm of wire from each end, and twist it together tightly. Then, put a 90 degree bend in each and interlock them:
Then, take each wire and wrap it around itself. The spec says three times, which is achievable for something like a 24awg receiver or power light wire, but for this 20AWG wire a single wrap is good enough. You’ll want to make sure the loose wire ends are all tucked away neatly, as they become tiny little heatshrink-slicing knife blades when soldered otherwise:
Then, solder it. It will take more solder than you expect, so check both sides of the joint to make sure the solder has wicked all the way through.
Finally, heatshrink it - you should make the heathshrink about three times longer than the joint so it has a decent overlap with the joint on either side. You did slide heatshrink over the wire first, right? Right?
Mesh Splice
This is my preferred option for emergency repairs. It needs less spare length than a hook splice, and fewer hands than a caveman-style lap splice (the average number of hands required for this is about three and a half), while also being far stronger than the lap splice due to the sheer surface area contact that the solder has to grab.
First, strip about 5-10mm of wire. Don’t twist it! Instead, push the ends together so the strands are interlocked, and carefully roll it back and forth between your fingers. The friction between strands will keep it together:
Then solder as below and heatshrink, following the same 3x joint length heatshrink rule as the Hook splice.
Three Way Splice
Sometimes you need to split a wire two ways. This works best with a smaller wire (ideal for a power light) as the third, but if you’re careful and don’t mind a lumpy splice then you can do it with equal-sized wires.
You’ll want to follow the same process as the hook splice, but before soldering you take the third wire and wrap it around, ideally 3-4 times for a smaller wire, but do your best with a larger wire - it can help to have some extra insulation on one end in these cases, as you can wrap round that rather than the main splice:
(RIP my ruler)
>3 Way Splices
You might be able to get a four way splice going if you mirror the three way. For any more than four wires, may I introduce you to our lord and saviour the Wago Connector? They are the only thing preventing The Luggage (and a few other bots - I know Forkhead uses Wagos) becoming total spaghetti inside.
If you’re feeling extra you can use bootlace ferrules to hold the wire strands together and provide strain relief, but wagos work pretty well without them.
PCB Solder pads
SMD (surface mount) and TH (through hole) pads are probably the highest risk connections in a robot. There’s no easy way to strain relieve them like there is with an XT series connector, so they’re liable to flex and crack where the insulation ends, and especially for SMD pads you risk pulling a pad off a board entirely. Thankfully there are a few solutions!
SMD Pads
You’ll usually find these on ESCs. For this example I’m using an Emax Bullet 12A as found in Ultimate Ninja and Birdemic, but the process is the same for beetleweight and larger ESCs with the same pads. This technique also works if you want to run wires off a TH pad parallel to the board for packaging reasons - just ignore the hole and treat the top or bottom of the TH pad as an SMD pad.
First you want to tin the pads. If the ESC came pre-soldered it likely came with lead-free solder. If you’re using leaded solder you’ll want to remove as much of the old solder as possible with a solder sucker or solder flux, add fresh solder, and maybe repeat the process a few times until the solder on the pads cools to a smooth shiny blob. Lead/lead-free solder alloys do weird stuff, but thankfully they let you know what’s going on by looking like absolute trash.
To get a consistent amount of solder on each pad you can lean on the surface tension of a good, well fluxed solder blob, and the tendency of solder to move to areas of lower concentration. If there’s not enough solder on the pads or they look blobby and crusty, put more iron on the solder (and maybe some flux on the board) and drag it around a bit. If there’s too much, clean the iron and dab it at the pads and it’ll suck any excess back onto the iron, where you can wipe it off in your tip cleaner.
You’ll notice I remove the iron away from the pads very quickly. If you linger on the pads too long you can burn the flux off, and when you remove the iron slowly it leaves a little point or tail behind. Moving quickly lets the solder flow back into a nice smooth blob before it cools. Don’t stay on the pads too long or you’ll risk lifting them off the board.
tinning-padsd
Next you’ll want to strip your wire to about the same length as the pad, and then tin it. You stick them together the same way you stick a wire into an XT - by melting the solder on the pad and jabbing the wire into it, giving it a second for the temperature to equalise, and removing it.
If some of the joints look a little crusty that’s fine, what can help there is to get all the wires stuck down in the correct position, then tape them/weight them down to your workbench to keep them stationary. It’s then a lot easier to come in with the iron and some fresh solder and/or flux and reflow them to be prettier and more secure.
solder-padsd
To aid in strain relief it can be helpful to angle the wires (rather than have them all exit parallel) so that they converge and run away from the board closer together. This lets you slide some heatshrink around them to bind them all together.
You can then overlap the heatshrink that covers the ESC with the heatshrink that covers the wires, so that any flex is induced in the floppy silicone wires rather than near the solder joints. Again, this is glue-lined, but the glue lined stuff can be too bulky or heavy for compact, min-maxed antweights so YMMV here - kapton tape works too.
TH Pads
For soldering wires to TH pads you’ll want to strip your wires to about 5mm length, twist them tightly, and tin them. Then, pass them through the board, and give them a little dab of solder - less is more. If you couldn’t tell, I’ve just been reaching for the closest suitable parts to demo these processes, so this random Adafruit ADC board that is totally unrelated to robots was just the first thing I found in my box of dev boards.
solder-thd
Ideally you should have a nice little Mount Fuji shaped joint on the bottom side of the board:
If it’s gone a little Mr Blobby, just clean your iron and come in with some flux or fresh solder. The joint will flow itself back into shape without much drama:
cleanup-thd
While TH pads are much less likely to rip off the board than SMD pads, you don’t get the benefit of being able to wrap the whole board in heatshrink to constrain the wires. You can however bundle wires together in twos or threes, which moves the majority of flex away from the board and into where the wires diverge:
Solder Tags
Brushed motors and switches often have little solder tag connections. They sometimes have holes, but not always, so here we just have to do our best. Otherwise, the process is very similar to soldering to SMD or TH pads, depending on if your solder tags have holes in or not. Strip your wires to about the seme length as the pads and tin them. If the tags don’t have holes, or if the holes are too small, tin them too. Note that after I took this photo I noticed the tags were bent outwards, and bent them a little straighter to help with wire routing.
Solder the joints. If you’re not using the tag holes, reflow the two sides together, otherwise you’re applying solder to the tag like it’s a TH pad:
solder-motord
You should have some nice smooth joints, with wires that exit in line to the tag. These joints are a little crunchy and needed a dab more of fresh solder:
Apply the heatshrink you thoughtfully applied before soldering the wires.
The End
I think that’s all the basics I wanted to cover! The real TL;DR here is that if you keep your iron clean, use flux, let the heat and the flux and the solder do their thing, and (this was the big one for me personally when learning) are OK with telling yourself “no that’s fugly, I need to do it again and do it right” you can go a long way towards reducing solder joints as a point of failure in your robot. I’m not going to say you’ll never lose a fight due to bad soldering, because robots are chaos, but you can remove as much risk as possible. I can confidently say I’ve never had an issue with robot wiring inside the arena, only while being a doofus at the pit table and yanking on stuff.
I photographed, videos, and wrote this all in one day, so I should probably go do literally anything else right now. Thank you for reading what has become an unexpected epic. As I think I’ve said already, please let me know if you think I should cover anything else and I’ll do my best to accommodate!
This is brilliant. Thank you for taking the time and the many words and diagrams I’m sure it will be useful to many, I have just ordered some bronze pubes, been on the soggy sponge too long.
I wanted to emphasise pre-tin wires and pads before soldering together.. it took me far too long to learn this and somehow I like to forget that regularly.
Re: soldering more than 3 wires together eg - power rails in bots:
Shameless but hopefully useful plug - will have xt30 & xt60 breakout cables (that’s one connector going to four red and four black cables of appropriate sizes) in the shop again from next week - I too hate soldering more than 3 cables together.
Alternatively Dave also has a technique that’s in our beetle guide using a cable tie:
Incredible, thank you so much for this.
I’d describe my soldering as “existing” and there’s so much in here I didn’t know. Maybe now I’ll stop killing irons (an iron per robot is… not normal).
Super 11/10 for good info in this post.
Obviously it’s a matter of opinion, but I generally avoid leaded solder, I use the really good lead-free stuff, typically Weller branded SAC (containing silver). It’s fairly expensive but works incredibly well, plus also, even doing quite a lot of projects solder gets used up very slowly, I think I have only finished one reel of solder, ever.
Great post.
I am a big time mesh splice enjoyer.
One small addition/tip id add although not strictly soldering (my soldering while robust is messy and bad).
On escs etc I like to tape the small delicate signal wires to the nearest (and much larger and more study) power line. This really helps prevent them from snapping at the board due to any tugging or tension on the wires.
Thank you for all the good feedback! There really is no community like combat robotics when it comes to combining competitiveness with the open sharing of knowledge, so it’s good to know I can give a little something back after learning so much from everyone.
Welcome to the pube side! TBH even if sponges didn’t slowly eat the tips, the fact that mine (I still use them sometimes, they’re still useful in addition to the pubes for getting a really, really clean iron for tiny tiny SMD stuff) are always dry, and I end up trying to carefully decant water from a pint glass and end up spilling it everywhere, is enough to make me not want to use them.
The zip tie is a good tip, too. This is a good application for smaller glue-lined heatshrink, as it’ll give the joint some extra mechanical structure and strain relief and prevent the solder from cracking.
See this is another one of those crimes against electronics I was talking about :joy: Whether it’s misuse, crappy irons, or a combination of both, hopefully you can pick up some tips and tricks and blow up fewer soldering irons. A good iron is really worthwhile, but it can be a little daunting to purchase one if you’re worried about it failing the same way.
Yes, part of the reason I don’t recommend lead-free is that picking the right formulation is a bit of a minefield. When I left my previous job the electronics department was working on getting all of us non-production folks to transition over to lead-free, as having a mix of lead and lead-free solder on site was causing issues when boards changed hands between departments. The problem was that while they did find some combinations of solder and flux that worked, there were a lot that didn’t, and they had a shelf of stuff that just didn’t hit the spot. The silver containing ones are much better, but some of the cheap stuff is almost pure tin and there’s no way to avoid it soldering like ass.
When it comes to leaded solder I don’t think I’ve ever found a truly bad reel, even the crusty old spider-covered shed reels that people find while clearing out their deceased grandpa’s workshop and leave in piles at hackspaces. For someone like yourself, working with your lead-free manufactured boards, it’s really a good idea to find a good brand and stick to it - I’ll go back and add a section about switching between them later.
Great tip! That combines nicely with my suggestion to heatshrink multiple wires together, and the fact that the power and signal wires are on opposite sides of the board helps a lot with strain relief too, as it provides another axis of support and stops all the wires flexing back and forth together. Some boards have pads on both sides, so I’ll add a note about this this to the pad soldering section.
Thank you, thank you, thank you, THANK YOU!!! I am literally on the cusp of soldering the guts of Sunday Drive and this guide could not have been posted at a better time! The Malenki stuff is especially helpful because that’s the part I’m nervous about soldering the most.
This is fantastic Joe, thank you so much! Also +1 to brass tip cleaners, I bought one recently and it’s a gamechanger!
That’s a phenomenal guide.
I’m also still on the soggy sponge, maybe I need to re-think that..
I’m a big fan of tidy wiring.. and yet I still occasionally have things fall off. (particularly motor wires)
One thing I have used is little rings of heat shrink to tidy pairs of otherwise loose wires.
All right so I’m here to report back on following some of the advice set out in this thread because I feel like it.
I’m going to make it very clear that I am a soldering noob. The most I’ve done when it comes to soldering and electronics prior to entering the world of combat robots is replacing the batteries in my copies of Pokemon Ruby and Sapphire so I can keep shiny hunting on them. And I can say now without a shadow of a doubt is that if you are new like me: FOLLOW. THIS. GUIDE.
By following this guide I’ve learned an awful lot about putting together the “guts” of a robot and ended up with something that actually turned on and worked. I need more soldering practice but the point is by following instructions I was able to put something together that didn’t short circuit or damage components when it was switched on.
I am also going to back up Joe’s advice on getting a Knipex or a similar brand. It will save you a lot of frustration trying to pull insulation off without damaging the wires!
In conclusion kudos are in order for you @IrregularJoe for making a guide that has granted me the chance to cross a threshold into actually understanding a little bit about what electrical engineering actually is. I know it’s cheesy but this is a huge deal for someone like me who failed both maths and physics in school.
Thank you so much and I hope one day we meet at an actual event and face each other in the arena so you may see for yourself the results of posting this wonderful guide!
How am I supposed to solder a brushless motor to the BBB brushless esc?
Like I show in the “SMD pads” section: Guide: How to solder robots good - #2 by IrregularJoe
The BBB ESC pads stick out from the main PCB a little, so once you have the wires soldered down you can slide heatshrink over the join and the little PCB tab. This should protect and reinforce it better than on the ESC I used in my example.
If you’re struggling to get the pads tinned:
  • Hit them with a little bit of sandpaper and lightly scuff them.
  • If you have flux, blob some onto the pads too.
  • Clean your iron and apply a small amount of solder to it, which will form a little ball on the end of the iron.
  • Apply the iron to the pad, making sure the little ball of molten solder is touching the pad.
  • Feed some fresh solder into the gap between the iron and the pad and wait for it to flow across to the pad.
  • If there’s a huge messy blob left on the pad then you want to clean the iron, then come back to the pad with it and melt the solder there while applying the tiniest bit of fresh solder.
  • The excess will flow back onto the iron and should leave you with a nice little dome of solder on the pad like in my pictures and GIFs.
Found this extremely helpful made me realise I had the complete wrong equipment at the start. I’ve now got a better iron and found it much easier the second go round.
