Hello. I am back! I’ve been working on some new designs (Of which i accidentally deleted all except one of-whoops). I have plans for a horizontal spinner with two mounting plates and another long boy 2204 to slap on.
I’ll stop blabbering and give you some pics.
Right. The weird bit with holes at the backside of the bot is meant to be an impact absorbing type thing. If something hits it, it’ll just tear it a bit instead of ripping the main wall open and flinging the entire bot across the box. It’s basically a damper to take the sting out of a hit. If you know my wedge Nugget, he has one of those as well, but it’s less complicated and currently acting as a last resort (As it is being shielded by the 1mm polycarbonate.).
I will be putting my be1806 on this. I have also acquired a massive overlander 2822 (1200kv, 28g).
I have no idea what to put it on, if you have any ideas, please tell me!
I have designed a new single tooth spinner with 70mm diameter to slap onto the be1806 using blessed epoxy. It took me a while to get used to fusion controls (i have used it before but ages of shapr3d modeling rubbed the controls outta my head). any advice would be appricieated.
shaving all unnecessary areas and extra space off to give a tiny bot, only 71 by 85 by 48mm, excluding forks (to be added) and the weapon. Should be only around 30g!
Good question! Yes, i have measured the dimensions. The lipo goes on one side of the bot (behind the forks on the left) and the malenki on the right. It should be a squeeze but with some room for wires to wiggle around, as i am trying to make this chassis under 40g.
