PLA, good or bad?
Hi,
I’ve recently (between other things) been doing a bit of testing on different PLA based 3d printed plastics.
You may have heard of the conventional wisdom “PLA is rubbish for combat robots”. This was certainly the case a few years ago, and is still true in some cases, but it’s not as clear as that.
Strength vs impact resistance
You may think that stronger materials are better. But this is generally not the case. PLA is one of the strongest 3d printed materials, based on its yielding strength, but also one of the worst for impact resistance.
This is because impacts tend to shatter the material, cracks propagate and then it will catastrophically fail. This is usually not what you want.
Different grades
You might see a lot of materials branded as “PLA+” - these are all slightly different, but the principle is to add some modifiers to the PLA to make it softer and less likely to shatter. As with anything, it’s a trade-off, and the softened materials will make less accurate details and cause more printing artefacts. These often don’t matter for pieces which aren’t intended to be decorative.
The experiment
I tested 5 different PLA types with roughly the same method - printing a 50x20x2.5mm slab and sticking it in a vise, then hitting it with a carefully calibrated manual hammer blow to see what happened.
3DQF PLA
This is a really nice material, shown here in purple. It prints super nicely with no stringing, it’s supplied on a cardboard spool and made in the UK. However, this is a very “pure” not very modified PLA, it shattered with a fairly gentle tap.
Jayo PLA+
Shown here in light green, this was advertised as “PLA plus”, and is a super cheap brand. However, I was disappointed in general, I think it’s not very well made and again, it shattered with very little provocation. It could be slightly less brittle than the 3DQF but I might be imagining it.
123-3d PLA
This is “Jupiter PLA” from 123-3d, a popular NL/DE/UK supplier. It prints really nicely and the colours are great, very opaque. It did require noticably more encouragement to break but still shattered after a couple of hits. Shown here in the lighter red.
E-Sun PLA+
This is a very popular brand which generally prints very well and is available in lots of colours, shown here in the darker red. I have used the ESun PLA+ in robot parts before and it’s taken a bit of punishment. The ESun PLA+ required several hits of the hammer to break, then it still didn’t break fully cleanly, leaving a bit of material hanging on.
Overture Super PLA+
This is a new one for me, it’s really very good. Overture make it in lots of colours and the one here is darker green. It took several hammer blows like a champ, and still didn’t fully break, instead bending and turning white at the bend, similar to what ABS does.
E-Sun PLA-ST
Shown here in grey, this is the OG of tough PLA filaments. Much like the overture, it refused to break after multiple hits but did bend and go white. The disadvantage of the PLA-ST is that it’s only made in white, black and grey.
Conclusion
If you do decide to use PLA for a part of a robot which might get hit, use the PLA-ST or Overture Super PLA+. Anything else is much more likely to break. E-Sun PLA+ gets and “honourable mention” for being better than most of the rest
Super interesting breakdown, Mark.
Very useful. Thank you for your service!
Great stuff Mark! I really like the straightforward hybrid quantitative/qualitative assessment method. Gets to the meat of the question, namely, is PLA-ST loads better than normal old PLA, and the definitive yes is reassuring.
Hi Mark, this is really cool! Thanks for putting this together. In the last few weeks Bambu lab have released a new tough PLA that by the spec sheet at least should outperform the Esun ST and is available in more colours. It might be worth a look!
The Seal Avenger is PLA. I’m scared now :frowning:. At least it’s decently thick around the front.
This is awesome. I am pleased Overture’s Super PLA+ comes in lots of colours as PLA-ST typically doesn’t!
I’m lazy but I’d love to see the PLA-ST tested with various amounts of infills and walls to work out a good balance of strength to weight for antweight builders out there!
I’d also love to know how dense you’re printing your feather parts @MarkR as they do hold up well considering they’re on bits of the robot that bash into other robots, I’ve only used PLA for stuff like pulleys and spacers on my feathers… :slight_smile:
These are Overture Super PLA+ in green, my previous forks were printed in eSun PLA-ST, with near identical settings
  • Printer: Prusa XL, 0.4mm nozzle (Only single colour though, I could get several colours and do a more interesting version). I used the Prusa XL because these things are too big for a standard-sized printer
  • Layers: 0.2mm
  • Top and bottom: 5 and 4 layers respectively (why not the same? I don’t remember, or maybe I just made a mistake)
  • Perimeters: 6 (typically default is 2 or 3)
  • Infill: only 10%
  • Modifier: I created a modifier slab which added a few more solid layers in the centre of the part
They weigh about 140g each and it was about a 6 hour print (the XL is not the fastest on its default settings)
Hopefully these settings will make it strong enough, I did the same thing last time with grey ST and they suffered only minor dents and scratches (and some cosmetic abrasion from Sandy Cheeks) .
They are each bolted on using a pair of M6 bolts going into reverse mounted insert nuts in the HDPE arm. There is a cross-brace piece for extra rigidity with a machined nylon spacer (not 3d printed) just because I could.
Note to those new to 3d printing structural parts: infill is not very structural. You will get a lot more strength for the weight with perimeters (x/y surfaces) and top/bottom (z surfaces). Infill is basically a mish-mash of strings which supports the top layers, In some cases it’s possible to use 0% infill, I could probably have done that here and it would be almost the same.
Looks like Super PLA+ has been discontinued and they’re slowly running out of colours on amazon, which sucks as it actually came in more colours than just white / grey / black (looking at you PLA-ST)
Any alternatives out there? Wondering what the american PLANT scene has started using instead
Have heard good things about Bambu Tough PLA+, but I haven’t tried it yet.
Well darn. I’ve been using Overture’s Super PLA+ to prototype the new version of Sunday Drive and I was going to use it for the final version of her chassis. Now I’m wondering if I should go full panic and buy some more reels before they sell out forever or if I should go over to eSun considering the colour of her chassis is going to just be black… :confused:
I am using esun ePLA-ST. I am not sure about colour availability though.
I mostly buy black filament.
