The chronicles of Luchador 1 through 3
As I’m currently returning to Luchador for BBB Champs, figured it about time to get a build log posted. :smiley:
So MK1:
So as some of you know I started building Ants in lockdown, then after my first event The Great British Bodge Off - I was hooked. The next BBB event was beetles so naturally I had to pull together a beetle for it!
I quickly decided to make my life harder than needed by pursuing the noble art of the suplex :mechanical_arm:
And thus Luchador mk1 was born. Inspired largely by the snappy build video it was built largely from 10/6mm HDPE - cut with a jigsaw, heat bent and wood screwed together.
I decided to use 3D printed gears to allow me to iterate a ton and powered the lifter with a 20kgcm continuous rotation servo (largely because I didnt know any better). This proved to be a mistake as the lifter simply lacked the torque to do proper grab and lifts/suplexes :frowning:
I did manage this little lift on RIP though :smiley:
mk1-lift
After this lack of lifting beans I switched over to a pololu 37D gear motor - which had ample torque and could lift up to about 4kg reliably! It performed well in this config at robonerd that year and my hopes where high going into Champs.
Then I drew Endboss rnd1 and well… this happened :joy:
Amazingly despite getting blown to pieces Luchador never lost mobility during that fight or the rest of that event! - but it did rapidly devolve into some sort of eldritch abomination as I frantically threw it back together after each fight
All said Luchador (or what was left of him) ended up - somehow - making the round of 16! Knocking out Saw Loser in the process - in a fight that ended in a moment entirely created by my excellent driving and design and that had absolutely nothing to do with blind luck at all…
At the end of this event Luchador was incredibly unwell and sadly had to be humanely euthanised and dumped into a box never to be looked at again.
After Champs I knew I had some work to do. Clearly I needed to build more tanky to stand up to the nastier spinners at Beetleweight scale. So having hidden the shame that was the mk1 remains in a box at the back of a dark cupboard - I started the ground up redesign work on my next beetle - naturally called: Luchador mk2. Going into the design process my goals were: to make something super robust, more compact with a lower CoM, ideally 4wd and that could still do the suplexy thing.
I had yet to get access to any CNC facilities so this was another gargage build using the same jigsaw, heatbending and woodscrew methodology as mk1 - using printed paper templates of my profiles and sticking them to the HDPE and cutting round the lines etc.
The process went ok, and I was a bit surprised at just how much smaller it was IRL
I was aiming for it debut being Brawl - however covid isolation forced me to drop out! :frowning:
So instead it ended up debuting at Scouse Showdown
Electronically though it was practically identical to Luchador mk1. The same Pololu 37D lifter motor, same pair of BBB 22mm brushed drive motors, same RX and Bec etc.
I was trying a lot of new things on this bot mechanically however. Custom cast PU wheels, 4WD with belts, switched to steel gears on the lifter etc.
Most of which seemed to work and Luchador mk2 proved to be a super reliable and robust bot. It took an absolute beating and kept coming back for more! Also got a couple of nice suplexes in - including this great moment against Angel Slice - where I learnt that suplexing spun up horizontals is a dangerous endeavour :stuck_out_tongue:
After the dust settled Luchador limped away from liverpool with many scars and a 4th place trophy!
My best result to date! - so naturally I did what any sane and rationale person would do…
I retired the bot after this single event and started work on Mk3! :joy:
So after the great success and the single event lifespan of mk2 I designed Luchador mk3. Well actually I started designing mk3 long before even running mk2 in an event. Such was my appetite for iteration at the time :sweat_smile:
I went into this design with a bunch of goals, including:
  • stronger drive,
  • the ability to reliably drive mid-lift,
  • better geometry for dealing with verts
  • outriggers/longer forks to counter lever my lifts and avoid faceplanting
The end result was this:
The chassis construction shifted to full CNC routed - thanks to now having access to such facilities.
The core chassis is held together with barrel nuts and the wheel guards are attached primarily via 6mm aluminium stand offs.
The U-shaped chassis and use of timing belts, let me get some small wheels (35mm diameter) right up front to help with lifting and driving. It also - in combination with my fork set up - made it easier to engage with verts without them getting engagement.
Unfortunately, it couldn’t self right with the double grabber arms, so I quickly revised it back to just the single grabber like on previous iterations.
The internals at this point were made up of 2 diy rotalink 1806 conversions and the same 37mm brushed motor from previous versions. It was a right squeeze internally and my initial build had too much slack on the drive belts so I used one of the stand offs as a temp/bodged belt tensioner:
I ran it in this basic configuration for a number of events - Rapture 2022, subterranean 2022 - then in the run up to Champs 2022 I made some further tweaks…
For a long time I’d been looking for a viable replacement to the Pololu 37D weapon motor - while having tones of torque and being relatively cheap they’re also slow and very heavy. Grab and Lift is a tricky beast and the torque requirements are significantly higher than on regular lifters. I had been eyeing up some of the hefty high torque (but incredibly expensive) 4S compatible servos from the world of RC crawlers for a long time - but was reluctant due to the cost and unproven (in combat) nature of these parts. However after a cheeky bonus at work and learning that Ratfish over in the NHRL was running one of the models I had been eyeing up - I took the plunge and converted Luchador’s weapon over to a SHV800 Servo - running directly off 4S and rated to 93kgcm the thing is a monster.
I did some testing with the SHV800 servo prior to designing the needed changes, and oh boy was I impressed. It’ll easily lift and hold a 1.5kg mass on the end of a 20cm lever no problems. During these initial tests of slamming a 1.5kg weight around - I did have a brief scare when it seemed like I killed it - however on closer inspection the servo had stripped out the teeth in the aluminium servo horn! Discovering that the servo horn was a known weak link was a huge relief - having a cheap disposable point of failure could/should serve as a great way to protect that expensive servo.
When it came to implementing the new servo I decided to drop the gears and instead move to a linkage system similar to my antweight Luchador jnr. And this was the result:
Luchador mk3 had a tough draw at Champs 2022 and was drawn against End boss round 1! - a rematch of the previous year’s rnd 1 murdering of mk1!
Mk3 faired much better - lasting the full length of the match and miraculously even managed a lucky clutch win in the final seconds. Just going the full length of the match felt cathartic and really gave a sense of closure to the evolution of Luchador and it becoming a far more robust and capable machine compared to mk1!
Luchador’s next match was against Fang. I tried out a wedge anti-horizontal config for this but fang was running some serious forks either side of their spinner and I simply didn’t have an answer to that set up combination. I did my best to stay on top of Fang, but eventually they got a hit in that managed to sheer one of my motor shafts. Crab walking and with no way to win the ground game - fang eventually pitted Luchador with ease.
So whats next for Luchador? - I’m making very few changes for Champs 2023. I’m making a batch of fresh wheels and I’m going to be running slightly longer tips on the lifter in the hope that will let me use my weapon a bit more frequently. Thats it really.
So Luchador went to BBB Beetle Champs recently and… it went rather well!
Like 1st place well! :open_mouth:
With the major spoiler out the way lets talk about the beetle for a bit.
I’m not going to do a full play-by-play description of my fights - because frankly what is the point!? - video will do that a million times better than any waffly words could, so if you want to see my run/fights checkout my event edit on my team page here: https://fb.watch/otsZw6abmc/
Instead of describing the fights I’ll concentrate on talking about the robot itself, my intentions and insights that watching them might not give!
Overview
Luchador last competed at Champs 2022 and it remained largely unchanged going into this event- it was the same fundamental design and the same actual chassis from last year. This lack of major overhaul did allow me to focus on smaller quality of life tweaks - I revised the mounting for the forks to be easier to change, added a nice link door, made a new horizontal set up, new internal motor guards - those sort of things.
This was a strange experience for me - I’ve never really returned to an old bot before - always iterating pretty intensively and fielding a new version most events. During the event prep I lost count of the times I found myself muttering “what idiot designed this!?” :joy:
As the event approached I went in feeling reasonably confident that the bot would perform well - this version of Luchador was the best its ever been - I had no doubt about that.
I had a bunch of tough fights - some against scary spinners and some we’re just great driving matches - but the bot performed great through out. My TX less so - but we’ll get to that.
Rnd1 3 way: Luchador v Home Improvement v Brugh Deluxe
This was an interesting match up - I knew Home Improvement would be one to watch - Jon-Luke consistently builds really interesting and tough bots. I knew I would have the ground game advantage - so my tactic would be to use that and try and keep them off balance as best I could. This worked initially, however eventually Home Improvement got a hit on me while I was inverted - peeling up a corner of my baseplate which intermittently caused high centering and drive problems - the final nail in this coffin came from me reversing over a seam which caught the peeled baseplate and made it peel further enough that I just had no drive what so ever.
A loss for Luchador and into redemptions we go
Redemption: Luchador v Blast Furnace.
I’m a big fan of Blast Furnace - anyone who double weapons is a king imho. Going into this fight - the lack of destructive weapons in the arena mean I knew it would be a simple driving match - the ideal scenario for Luchador really. This proved to be true and it was great fun and thankfully Luchador came out on top
Round of 32: Luchador vs Sniper
Oh boi what can I say about this fight. I pushed this fight back twice due to what I thought was mystery RX gremlins - Luchador was behaving very strangely during arm up - ignoring stick commands, moving on its own - very strange. Later on after this fight, I found out it was my TX and got Luchador set up on a mates Zorro for the rest of the comp ( Big :heart: to Jed for this), but on the third attempt at starting the fight I decided to just send it - thankfully I regained control partway into the fight and didnt loose it again until I placed my TX on the arena post fight! - could easily have gone differently!
I was trying out my new anti-horizontal TPU booties/pontoons for this match up, a bit of a unknown and against Dylan’s very scary Sniper (side note: I love this build so much Dylan!). They performed great, tanking hits, flexing to dissipate KE and ablating nicely. This allowed me to tank those first hits and perform quick follow ups - for control and dictate the pace of the fight. Eventually getting a super solid grab and lift on Sniper and suplex-ing him OOTA!
Round of 16: Luchador V Abracagrabra
For the round of 16 I faced Becca and Kat with Abra and the mini bot. I love Abra so much - its such a solid control bot and Becca drives it spectacularly!
Another great driving match with us both getting lifts, pins and shunts on each other. Big shout out to Kat on the mini bot tho - interrupting my only solid Grab N Lift, repeatedly high centering me and generally causing me so much nuisance that I caught myself focusing on the mini bot far more than I should have been!
Eventually I managed to get Abra into the pit and marched on to the rnd of 8.
Round of 8: Luchador v Jackhammer
The fight with Jackhammer was a strong match up for Luchador. Despite only having 3mm HDPE lids, Luchador has its whole lifter protecting anything important- leaving only its link in the drive pods as a vulnerable target for hammersaws really.
They had some long forks that I knew I would need to get around the side of - which I managed to do reasonably regularly. Even got a great moment where I threw my lifter up to parry their hammer saw blow!
Eventually they got inverted and couldnt self right - on to the round of 4! - at this point I dont think I really knew wtf was going on.
Round of 4: Luchador vs EVA02
Into the round of 4 I drew EVA02. As with jackhammer, I wasnt too concerned about the weapon due to Luchador’s design. We also had similarly aggressive front end fork game - so I new this would be a real driving match and hoped that my lifter would make the difference.
Eva managed to get pretty close to my link with one of their shots - If I hadnt added the link door would they have gotten it? :thinking:
Eventually I got EVA into the pit and secured my place in the final! - wtf I was fully in shell shocked mode by this point.
Also BIG UP the builder here - second beetle, second event and they’re running this deep into the comp - crazy good!
FINALS: Luchador vs Gizmo
So in the run up to this fight I think my internal monologue was roughly:
“AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHH”
My goal here was to keep my front towards Ellis as much as possible and hope/trust my front end to do its job. To try and get Ellis inverted and keep him there if possible - which didnt really happen.
Toward the tail end of the fight I lost a drive side - post event tear down showed this to be the motor coming off the gearbox. I had serviced the gearboxes a couple of weeks prior to the event and neglected to Loctite them. In the few days running up to an event I usually do a full strip down and rebuild with loctite - The Great Loctitening I call it. I didnt loctite during servicing because of this - then come event week I decided to not do it because “the only thing that really needs it is the drive and of course I would have loctited during servicing” - WHOOPS :sweat_smile:
I did get a few flips and a suplex in there and held out long enough to get the perfect flip that made Ellis land on his weapon and bounce into the OOTA and take the win! - a super lucky shot/flip!
So what is next for Luchador
I do have some design tweaks to the drive I’d like to do. I would also like to revise the baseplate so it is inset away from the edges of the robot to avoid a repeat of the rnd1 peeling - but I do also have an entire spare chassis’ worth of plastics so will probably hold off on actioning those changes.
instead Luchador will get rebuilt “as-is” with the parts I already have and then take some time off while I focus on TCD and a new thing for a little bit.
As always a big thanks to Joe and Craig at BBB for hosting a great event, David for his tireless efforts running and maintaining the arena and all the volunteer crew for helping make the day happen! And another big thank you for all my opponents and fellow roboteers for attending and being a generally great community!
I have loved seeing Luchador evolve and it has been a big inspiration for things I’ve done with Déjà Two. Seeing its performance at Champs was great to see, and getting the grab-and-lift’s holy grail of a suplex out of the arena was awesome to boot!
Thanks Thomas! - that means a lot coming from you, all your bots are wonderful technical marvels. :purple_heart:
Congratulations to you on a fantastic victory! Showing the spinners a thing or two :grin:
Your driving was fantastic, and your weapon broke the spinner meta (especially in the final!)
It certainly wasn’t an easy matchup for Home Improvement early on, you turned it over multiple times (a real test of the spinner’s durability, I’m very lucky it stayed in one piece)
Good luck with the repairs and your future plans :slight_smile:
Home Improvement’s ability to take being flipped repeatedly and the ensuing bouncing and still self right and recover without loosing a belt or weapon functionality some other was really impressive! - especially for a new bot!
And the damage you did to Stratus was really impressive too!
Big fan of all your bots :grin:
