Also, for those curious, this is how it compares with V1, which is a very dodge machine compared to what this is now…
How did you get a bearingless shuffler?
I’m just using a cam shaft which the legs mount onto directly, both made of ABS since i saw someone do it in another video and they had good success. I’m hoping the heat resistence that ABS has will allow it to work just fine, and it has so far!
Only issue is the legs fit on very loosely, but i have some parts coming this week to rectify that issue and stop the legs coming off the side
Oh no… that looks terrifying. Improvements sound really solid although that big a bar spinning at 500mph+ might, um, well you know
Yeahhh definitely, its extremely unlikely that i ever spin it up that fast and i’ll probably end up limiting it myself on the transmitter depending how well it performs… Might limit it to 80% max speed instead. Highest ive gone up to is around 50 percent for a few seconds but i have no idea how it performs whilst moving…
It is shaping up to be something scary though, super happy with it thus far. Will see how it gets on in the test box at GROCS, and then we will be competing officially at AWS and ORCS ![]()
Very relevant, I actually just today printed a shuffler mechanism entirely from PLA-ST because I didn’t have any bearings (and didn’t think it needed any). I started by tracing the ONI shufflers then modified the geometry to suit my bot better. The ONI shufflers use an endcap to stop the legs falling off, but I put them inside a housing instead, as well as supporting the end of the cam opposite the motor shaft with a bearing and an M3 screw:
I hooked it up to a bench top power supply and ran pretty fast (1500rpm or so) for an hour non-stop, and actually only got smoother with time. The secret seems to be really big gobs of silicone grease.
Yeah definitely grease can help! Mine seem to run just fine without from the looks of things. As long as the PLA-ST can handle the heat that comes from the friction it should be sound tbh. Im going to put some endcaps on both sides when they arrive tomorrow (hopefully), till then the legs are a little wonky…
Looks like a nice system though! I might invest in a 3 legged setup nyself with the rest of my weight since this robot can’t really walk at all when the motors are at high speeds, which is quite a bother at the moment. i’m wondering if thats because its only a 2 legged shuffler or if theres another factor thats causing it…
It’s absolutely terrible when it comes to heat, but the grease seems to keep things cool!
Three legs is a lot more efficient than two as there’s so much less vertical component to the movement. The Luggage uses two sets of feet and rather than actually going forwards most of the energy seems to go into making it bounce up and down…
As long as it stays intact you shouod be fine, worst case if it doesn’t i’d get one printed from ABS instead.
I’ll bare that in mind, might invest in a 3 legged system after GROCS, only issue ive got is making sure this thing fits within the size limit. I know more legs means smoother walking, so hopefully that allows it to act more as wheels rather than just jumping and jittering, which is what it does when i drive too fast…
Keep in mind that it’s titanium, and very thin at that. Any vert that comes across it will bend that bar faster than you can say “Wait for a good hit!”.
Keep in mind you have to hit the bar first to actually bend it ![]()
A looot of people at events say just hit the wires on the back of Somatic Damage because they are an easy target yet nobody has done it
some things are easier said than done
Ahem, someone has:
(I still lost though)
I forgot about that one whoops.
To be fair it was my first event in 3 years, and the wires are way more exposed now than they used to be… i guess what i should say is nobodys ever hit the wires and lived to win that fight (or something ominous idk) ![]()
My full fleet is now ready for GROCS tomorrow!!! Excited to compete at a competition that just so happens to be taking place on my birthday ![]()
Somatic Damage is back for full combat, with a brand new weapon motor.
Nom 2: Nom Again is back for PLANTS as always, with sillicone tyres and some aesthetic changes
Wipeout is there for testing and maybe a whiteboard or two, completely redesigned with a myriad of improvements. ![]()
I didn’t realise it was your birthday, we should have done something for it!
ahh its all good! A day of robot fighting is enough of a treat for me personally, thank you though!! ![]()
Howdy peeps!
Its been a while (two weeks) and i’ve been at work redesigning and working on redesigns for my full fleet of robots. I have a busy month ahead of me for robots as i have 4 events to go to, first up is Midland Mayhem which is this weekend!
First on the table is Elephant Wheels and uh… he’s not doing too hot. If you remember ARCS then you probably saw this fight twice. You probably also saw what a failure it was, as it was falling apart mid fight and also killed itself instantly in the rumble, this is because i rushed it and also the motors are soldered up wrong. So… Whats new?
Elephant Wheels has a new chassis that is shorter in length and slightly taller. This means that A) No verts will be able to hit the chassis and B) It can actually fit all its guts in without and pressure on the bot ![]()
Unfortunately, the situation with the weapon motor is dire… I thought it was no longer spinning because i used a screw that was too long, but actually i just discovered today that the weapon motor took a nice knock courtesy of Dill with it (thanks Hollis). A hit so bad it stopped the motor from spinning…
Alright, not good… But i have a backup motor right? Right???
So i guess we are kind of boned for Elephant Wheels then as i don’t really know if there is a way to get one of these motors in time for this weekend, so i amy have to improvise something in the meantime… I will do a better showcase of this bot once i’ve finished porting the electronics into the new chassis, just needed to share my pain and suffering with this robot
sorry about that, hopefully you can figure something out, also, how tall is the chassis, because it would have to be very tall to avoid verts like vanquish
haha its all good dw, i didn’t realise you even hit it honestly until this evening, you put a good dent into it for sure…
the chassis used to be 50mm long but is now just under 40mm, only real difference is that its about 3-5mm taller than before. Unsure how high off the ground it sits, but it should definitely be a noticable enough difference to at least stop smaller verts from reaching, which is progress ![]()
Using 145mm wheels on the thing since all my bots are built for AWS rules, so it should at least be a pain in the ass to hit the chassis even if not 100% impossible
Don’t reckon i can get a new motor in time so might have to turn it into a thwackbot hahaha
ULL’s 20mm forks are still in stock, try using those as the head of your thwackbot’s axe.
