I’ll bear that in mind, will try upgrade it to 3mm if i have the weight. Going through quite a big redesign with the bot atm so hoping to spare enough weight for that
Somatic Damage and Nom 2: Nom Again made it back from ARCS in one peace!
Somatic Damage went 4-1 in total, going undefeated in the first rounds and receiving a bye, before losing to Cat Flap, unfortunately the wheels i was running for the past 4 events now decided to finally give away…
Nom 2: Nom Again went 2:3, not doing too much of note other than getting a brilliant grab and pit on Expandabot!
Upgrades for next time shouldn’t be too much, Somatic Damage is very dialed in now and is a complete beast in the arena! I’ve learned a lot whilst driving it during ARCS so i know what to do to make this a genuinely scary robot in the arena.
Nom 2: Nom Again will be getting a redesign for the front plow to allow it to wedge under robots better, some silicone tyres as opposed to the rubber tyres its had previously, and a custom grabber to make it more unique in battle.
Both will be fighting next at GROCS, which is also where i’ll be showcasing the new version of wipeout…
Photos of the damage i inflicted below, more posts about robots and event reports soon ![]()
Howdy peeps!
I wanted to make a quick post to show off Elephant Wheels, since I’m not sure if I ever introduced them properly, so i’m doing that now! Plus I have some whiteboard Fights from ARCS to talk about that unfortunately didn’t go to swimmingly, and highling some issues that need addressing going forward ahead of AWS in November
Elephant Wheels is my attempt at a Starchild style overhead thwackbot, and is a very experimental bot for me, since I’ve never built anything like this before and wasn’t too sure how to approach it either, but I wanted to build something that doesn’t entirely go with the meta of Vertical Spinners and also a more unique approach than the standard hammersaw.
Here is a photo of Elephant Wheels ahead of ARCS, which was its first outing for whiteboards. Elephant Wheels features two big 140mm TPU Wheels that are 5mm thick at the rim and “tyre” and around 2mm thick at the spokes, which makes for quite an awkward and flexible robot to fight and handle.
I’m quite proud of the way the wheels mount to the hubs, since they’ve not had any issues slipping or coming loose yet, and i hope thats a trend that continues…
This is how the wheel fits together, with an ABS cover going over this to keep everything from.coming apart…
Unfortunately, with this rushed design came plenty of mistakes…
- The body was not tall enough to fit all of its electronics in a snug fashion, meaning the top plate was flexing as a result which isn’t ideal for something that’s going to spend so much time moving around and hitting things…
- The Motor Mount I designed did not hold the motor in a way that kept it still, mainly due to me stupidly putting an indent for the middle of the motor on the wrong side of the mount…
The Drive motors are mounted poorly, the mounts barely fit into the body and put it under a lot of stress, which shows later on…
I soldered the drive motors the wrong way in a rush to get this ready, meaning an already difficult robot to control (compared to the average one at least) is made nearly impossible to drive with…
There’s probably more issues, but these are the main ones…
I took it to ARCS and had two whiteboards, one was a rumble and the other was against Dill With It and CEF, I will be looking at the 3 way melee first…
3-way melee:
Starting this fight I spun the weapon up, and two fatal problems set in very quickly…
Number 1. The robot was quite literally impossible to drive, it was incredible difficult to figure out which way up I was, and then which way to drive…
Number 2. The weapon screws weren’t tightened, this is due to the previously mentioned issue of putting the indentation for the brushless motor on the wrong side, like a dumbass. Because of that, if I tighten the screws for it too much, it puts stress on the weapon arm and puts it at risk of snapping during impacts. To counteract that fact, I tried to put them on slightly loose to stop that from happening, but instead just made them very easy to unscrew on their own…
here you can see one of the acrews on the floor…
Thankfully, CEF was already dead (I guess thankfully, It did mean I wouldn’t find out how the wheels performed so… unfortunate really) but multiple screws for the weapon motor had come lose… and one for the weapon bar, meaning I couldn’t spin the weapon up without it hitting the floor, meaning I was left flailing around like the town drunk.
At one point, Elephant Wheels got stuck on its side, this would answer an important question about this bot, since I hadn’t tested it previously… Does this robot do the thing?
And the answer is, kind of? It managed to self right, but I’m not sure if that’s because of the fact that I got a slight push or not, I also don’t know if having the weapon on would’ve impacted that fact either…
After a long and painful struggle, I threw myself out of the arena. I’m not even going to mention the rumble, because I just threw myself out of the arena in 5 seconds and didn’t even do anything… so that’s boring.
Elephant Wheels went winless, and took minimal damage too, pics included:
You can see that the body and top plate took a few minor hits during the fight, nothing too Explosive… The wheels were completely unscaved for now…
The most concerning bit of damage is the fact that Elephant Wheels’ body was beginning to split from all the stress put onto it by its dodgy construction, which in an event would be a major problem…
Improvements:
With version 2 of Elephant Wheels, I’m going to spend more time actually thinking about the design and not changing stuff halfway through, I’ve got a better way of mounting the motors and I’ve made the chassis taller, but shorter lengthways to compensate, hopefully this won’t impact the weight much…
I also actually put the indentation on the right side of the bot, meaning I can actually screw the motor tightly to the mount. I don’t know how well the TPU Wheels perform unfortunately, since I don’t think they really got hit…
Main notes are better construction and a slightly different form factor that I hope will make it more difficult to attack, since Dill With It got a hit or two in during that fight on the chassis… I look forward to seeing how this bot performs at its debut event at AWS in November, but until then thats pretty much everything i can say about this bot until all the parts for Version 2 of this bit arrive!
The wheels on C.E.F performed marginally better than the 34mm ones, not by much though. This was after it had a great showing against Y Que (nearly throwing its opponent out, then Y Que hit the wheel and sent both out)
Yeah did quite nicely, shame it conked out in the rumble though, was looking forward to fighting a horizontal and seeing how my TPU wheels held up… Will have to bring it to GROCS when its more refined for some more whiteboards perhaps
Funnily enough, I am bringing a more refined version of it to GRoCS.
If you’re down for a whiteboard rematch at GROCS i’d be happy to do so.
Should have a version that doesn’t disassemble itself in ready, so would be lovely to give it a good test.
Same goes for Wipeout…
Halloooo
You might’ve seen this robot already if you went to ARCS (Thanks to Harry of Team Xcitement Park for the photo), if you did then i’m very sorry in advance for everything that you read after this sentence…
Wipeout is my attempt at a 225g big fuck off horizontal shuffler spinner. I wanted to make a horizontal, since they are my favourite spinner type (despite never making one thats competed). After seeing how Alex Shakespeare’s “Don’t Hug Me I’m Scared” fought at events i attended years ago
(Photo for reference),
i saw it and thought “thats very scary and i’d hate to have to fight it”
And in my theming of taking an idea i saw and making my own thing out of it, It was this mentality that lead me to design Wipeout. This robot has been in the works for YEARS, here is a photo of it from all the way back when we had the cube rule:
This robot had the same motor as the one at ARCS, but a much smaller, less impressive weapon.
Here (again) is how the bot looked during ARCS:
As you can see, its a lot bigger at ARCS due to rule changes that occures after i started designing it. This robot had a 2mm thick 63g Grade 5 Titanium bar spinner, powered by a 1700kv brushless motor and spinning at around 320mph, and testing it out in the arena was amazing, its such a loud robot and the spinner looks absolutely terrifying when it gets up to around 50% speed…
The real kicker is the fact that this bot only weighed 175g, this is a lifesaver for me since this robot is the definition of a glass cannon. The armour for the sides is 2mm thick ABS, and the mounting for the legs is incredibly questionable at best…
plus 320mph is a little on the slow side for what im after…
So, i did a redesign, a big one. I made the internal space of the robot smaller, and shrinked the body down aswell to make space for 3mm thick TPU panels that would surround the body. I also took a lot of material out of the sides, to save some weight that would be invested and protected by the TPU panels.
I’ve made the robot slightly taller, but angled the chassis forwards to make the blade hit lower. To also avoid any hindrance this could put on the shuffling legs, i’ve angled the legs so that they still sit completely flat even with this angled design like the old version did.
Other smaller changes include the weapon now being 3mm thick instead of 2mm thick, having a 3s lipo instead of 2s and a bearingless shuffler setup that I saw on YouTube which inspired me to give it a go, I’m a bit skeptical of the setup at the moment since I feel like it’s going to be quite difficult for the shuffler mechanism to move, however that’s something I’ll figure out when the bot is all soldered… Worst case I switch back to the bearings if I have the weight…
So, anyways, with all these improvements in mind… How does Wipeout look present day? Well…
This is how it looks. I went for a snazzier colour scheme of black and red, since I thought it’d look really cool (and it does IMO). You can also see what i mean about the legs being angled as such that despite the angled design, it doesn’t impede the legs ability to walk (in theory). But what about the functionality of the bot?
I haven’t currently soldered the thing up yet, but in theory here’s how everything weighs up compared to the robot seen at ARCS…
Version 1 had a big problem of being incredibly sluggish. Now, having a big weapon that attacks from all sides makes such a thing a non issue, however i’d still like this thing to get around or at least turn with some relative pace so I can keep the robot facing forwards as often as possible.
Version 2 now uses 1000rpm n10s just like my other antweights, unlike the 800rpm n20s that it was running before. This is good because not only does the robot walk faster (in theory), but the motors weigh less aswell, which allows me to invest weight in other aspects of this robot!
Version 2 of course has way more defence than version 1 had, rather than the 2mm thick ABS walls it now has 3mm TPU to help absorb hits too!
Version 2 features a 3mm thick blade as mentioned, which is to prevent it from being bent as easily as it could’ve been at 2mm thick, unfortunately this blade hasn’t arrived yet but once it does I’ll get it fitted ![]()
With so many changes to the robot’s design, thicker armour and all, you’d think that this robot would be way heavier now than it was before. Right?
Right???
Against all odds, this robot is somehow slightly lighter than its previous incarnation. This of course doesn’t include the weapon bar, but passing that into the equation puts the robot at 205g with the new bar, which is insane…
But what about the weapon itself?
Well, like I said previously, at ARCS this had a 63g blade spinning at a max speed of 320mph.
This new version has a 96g blade spinning at 560mph max speed…
This new version is only about 25-30g heavier than its previous incarnation, which was very unexpected.
I’m going to take a look at how the bearingless setup does at walking and see how it does fighting in whiteboards at GROCS, since this robot has its tournament debut at ORCS in November!
Worst case scenario is i switch back to the bearing setup, which wouldn’t be too bad… That’s pretty much all I have to say about this robot at the moment, since I haven’t soldered it up and I don’t have the weapon bar either.
I apologise in advance for everything this robot manages to do, thanks for reading ![]()
DON’T HAVE THE BAR SPINNING AT 560MPH! Do you even remember what we told you?!
im going to have the bar spinning at 560mph at events that allow it, midland mayhem doesnt and thats okay ![]()
What events even allow that?
any of them that have a 600mph spinner limit, which is all of them unless EOs say otherwise. If any EOs don’t want me running it thar fast i will happily put a 2s lipo in it on the day instead
I’d say if it has exposed polycarbonate walls then just put a 2S lipo in it.
I’ll leave it up to the EOs in advance, and just let them know the stats of the bot and let them decide for themselves, i know every EO will have their own opinion on it which is understandable as its absolutely massive, and its not something i’ll debate over either since i don’t want to put something in their arenas if they don’t think its a good idea. If they allow it then thats great and i’ll be excited to try it out, but if not thats fine too.
Howdy peeps!
Originally with Nom, i wanted to do an event report about every event thats happened for Nom and Nom 2: Nom Again. However, i now have about 5 events to write about so i’m just going to sum them all up here:
BBB June Meet didn’t pan out too well, we went pretty much winless so its a bit of a disaster event, but i still had a great time ![]()
I was meant to go to CAT 5 with Nom and Psychic however, Nom just straight up wouldn’t turn on, and i still have no idea why… meaning i had no choice but to pull out of the event, retire him and persue a version 2…
GROCS went better, picking up two wins but then falling in the rumbles. I did get a lovely grab on Randy though that i was quite proud of!
ORCS was quite average, i got some nice grabs and i managed to break Falcon’s drum spinner, which i’d say is pretty awesome
CAT 6 was mediocre as i kept throwing myself out of the arena because my driving was shit
ARCS was my best 2v2 tournament yet, unfortunately me and Harry didn’t make the top 8, but i think we put up a good fight. And also i managed to grab and pit expandabot which i’m very proud of, and is probably the best thing this robot will ever do.
After ARCS i was in a limbo between straight up retiring Nom 2: Nom Again and persuing a new idea, but i think ive decided to continue with this robot and try and improve it. Over the week i’ve done some work and have now got an upgraded version ahead of GROCS on my birthday! ![]()
Nom 2: Nom Again now features its signature head (to distinguish it from all the other kitbots), made out of thin TPU and reinforced with Foamboard (and all important googly eyes). Other changes include silicone tyres and a slightly redesigned wedge, which i might take another poke around at before GROCS, who knows…
I’m definitely much happier with this version, and i’m glad to see it finally have some aesthetic features to it that make it look actually interesting, look forward to fighting at GROCS soon enough!!!
Maybe consider adding forks to the wedge, just for certain opponents.
Been on my mind, Might design something to include forks tomorrow.
I mainly want to get the shape of the wedge right at the moment since 9/10 i can’t get far enough under robots to actually get a grab, hoping to fix that before GROCS
That might have been the wheels. The 34mm wheels offered on the base N&B kits have little to no traction.
Yeah i’ve been thinking that, not a fan of the rubber tyres at all, gonna see how it performs with the new sillicone tyres at GROCS, i don’t think the shape on the wedge is exactly ideal either way honestly, but maybe i’ll be wrong haha…
Either way as far as i’m concerned its mostly sorted now, just need to stick a new weapon motor on Somatic Damage and both bots are ready!
Howdy peeps!
Time for a small update, I’ve been spending this week getting Wipeout ready ahead of GROCS for some testing, which after a lot of pain and soldering (the pain comes from the soldering) I can safely say that Wipeout is ready for combat!
Weighing in at 208g, this robot is a completely different beast than the one seen at ARCS. To compile all the differences:
• The wrapon blade is now 3mm thick, and weighs 96g instead of 63g
• The robot is now powered by a 3s lipo, with a 2s lipo on the old version, it struggled at low speeds to get up to speed, this is no longer a problem at 3s.
• The weapon now has an (in theory) top speed of 560mph, as opposed to 320mph. Whether or not it will reach that with such a heavy bar is another question entirely, who knows…
• The robot is now armed with 3mm thick TPU at the rear and front, as opposed to 3mm thick ABS.
• The robot now features a bearingless shuffling mechanism, which has actually worked out really nicely so far.
Theres probably a few things i’ve missed, but these are the main things that come to mind. I’m honestly shocked this thing is under the weight limit, as when i was calculating it, it sounded as if i was going to be right at the limit, but apparently not… Other than being quite slow to move, this robot is definitely hoping to be a force to be reckoned with!
Next up will be me fixing Somatic Damage, as it needs a new body AND a replacement weapon motor, but after that i will be all ready for GROCS this weekend!
