Please tell me the top left bot is not wipeout, that is mad scary and I certainly dont want to draw that at Midlands Mayhem
uhhhhhh, would you like to hear the bad news?
As a competitor I dont think I do, however as a builder I would love to know the specs of that weapon
it’s a 63 Gram bar, 228mm spinning diameter, spins at around 320mph? atm, but once i fit a 3s lipo itll be 560mph
Bot weighs about 175 right now but i’m looking to invest in TPU at the rear and a better shuffling mechanism ![]()
560mph is where polycarb stops being able to deform plastically, and with a 63g bar with that much inertia I dont think it would be safe to put the 3s lipo in. Would be best if you dropped kv on your motor or kept the 2s lipo
Yeah i’ll have to bare that in mind, I can always limit the speed on the transmitter too right? If needs be i can limit the speed on it so that its not fast enough to do such a thing. Would be nice to at least get the drive speed up since at the moment this robot is pretty sluggish…
Got a lot of upgrades planned for it atm, gonna redesign the thing and give it more armour around the sides and a better mounting for the motors and top plate, lots to work on! Don’t reckon i can get things ready in time for Midland Mayhem though ![]()
TX limiting specifically isnt allowed at bigger weight classes, so I assume it applies to ants. You’d need to drop your motor KV significantly, which by the way does dramatically improve efficiency, or you need to keep the 2s and increase the rpm of your drive motors. With that current theoretical on 3s I dont think I would allow it at midlands
Interesting, fair enough. what sort of RPM would you say is acceptable at max? On 2s its around 320mph which i assume is fine? I can always keep a 2s lipo handy anyways for events that aren’t okay with me running it at such a high power.
As for the TX thing, i’m surprised thats something thats not allowed, but also i can see why as theres nothing technically stopping someone from just turning it up whenever they like, so i get it
320 is still fast af while not being a safety hazard, Vanquish runs at this range and its assaulted the polycarb plenty without breach. If I’m honest I think it should be a 400mph limit on ant tip speed, there is little functional reason to go greater and it just causes a hazard.
You could also use a smaller bar for less tipspeed, and spend the rest of the weight on making it survive other robots.
Yeah thats fair, I’m surprised the limit is as high as if its that big of a stress on polycarbonate then why allow them to go that fast, it is an interesting one indeed. I’ll bear that in mind, will use a 2s lipo at Midland Mayhem as per your request and will be sure other EOs are fine with me running it at such speed when i enter other events, just to be sure ![]()
Appreciate the advice!
I could never do such a thing, bigger = better
Besides, the bot weighs 175g atm so i have around 50(?) grams to play with, which i do plan on investing into TPU armour on the sides ![]()
Coward, invest into MOAR WEAPON
Problem isnt 100% tip speed, but also that your a horizontal and specifically an over cutter with a very large and exposed blade. If a small vert were somehow to attain such speeds I would think much less of it safety wise
It will never get smaller, this weapon looks too awesome to ever change it.
And yeah i get what you mean, the idea of it just coming off the motor (which i assume is the problem with it being an overhead weapon) would be quite scary…
Will be interesting to see this finished though, and have it compete. Whether its 320 or 560 this thing will be quite terrifying haha, Hoping to get it done in time for Midland Mayhem but unsure if i’ll be able to get it ready in time ![]()
Relevant photo from ChonkIV vs Colossal Avian at NHRL on Saturday:
ChonkIV sent Colossal Avian into the polycarbonate weapon-first - ChonkIV has more spinning mass than any other robot there, and the announcers said Avian has one of the fastest weapons in terms of tip speed.
You can see the gash in the plastic where Avian’s blade dug in and flexed the polycarbonate out in a bubble shape around the impact area, whereupon the stress got too much, the plastic deformation turned into brittle deformation and it shattered!
What’d break first though, the polycarbonate or the little tiny bearings in that 1806 motor? ![]()
I feel like my weapon motor and my poor soldering technique are going to be given a run for their money with this bot, its honestly hard to tell…
That is an insane hit though holy shit. and also conveniently i got this as a short in my recommended shortly after seeing this post haha
That’s doubting the spinner won’t take flight or get irreprably bent the second a somewhat competent vert gets a hit on it. (see Hazard v Vanquish, ORCS 13)
Result of said battle
They have to hit me first ![]()
Depending on how much weight i’m left with after upgrades i may bulk it up to 3mm thick titanium anyways, But i’d like to assume bending the weapon like that is somethint much easier said than done, even in such a vertically dominated field
Oh your weapon is 2mm TI? If something hits the underside, with that big a lever arm its folding in half from even a small vert. As you said they gotta catch the underside first
