ORCS was a blast yesterday, finally unpacked everything to take a look, here’s photos of all the damage (plus a cheeky souvenir from Optilift Prime). Thanks so much to the Event Organisers for a fun event!!!
howdy peeps! Got a question, no updates since im waiting for a lot of parts to arrive at the moment…
I’m planning on using 3s lipos on a few bots instead of 2s, would i need to change my components at all? i’m using a malenki hv with n10s and a repeat robotics brushless motor with the bbb brushless esc… I had a look on the bbb shop at the voltage and i should be fine? but i just wanted to ask to be 100% sure
Should be absolutely fine, aside from the motor it’s the same I use. Is there a specific reason you want 3s by the way? Aside from drive speed it ain’t to useful
I would generally recommend limiting the drive output on the transmitter (maybe to 70% so the malenki would be outputting similar to a fully charged 2S lipo)
As the N10s are rated for 6V, and a max charged 3S lipo is over 12V so there’s a risk of burning them out.
Where would i find those settings on the transmitter? i’ll have to have a look! would be pretty good to limit that for sure. I had a feeling the drive motors would be the biggest concern…
Mainly just for the extra power in general, but in particular i have some big shuffler spinners im working on that i’m hoping to make as scary as possible, even if its probably not really needed (and is quite extra), i just want to make something thats probably going to end up being pretty slow as intimidating as i possibly can, thought it’d be a fun change for myself since ive never made a big spinner before
plus it would be a fun little upgrade for Somatic Damage if i have the weight, just looking to experiment with it and see how they perform, if its no good i’ll probably just sell them on and stick to 2s
I’ve not limited my drive and the n&b n10’s in Vanquish have never shown any signs of slowing down, and the gearboxes havent exploded neither which is an achievement.
They’ll be worked a lot harder if they’re on a shuffle mech than wheels so limiting them may be a sensible move. Each robot is different and you’re welcome to run them at 3S at 100% at your own risk I just wouldn’t be shocked if the motor burns out.
Assuming you’re using an FS-i6 you’d just want to change the endpoints of your drive channels (usually ch1&2) to 70% or similar.
Section 5.3 in the manual
i’ll bear the issues with burning out in mind, ill try experiment at it in my own time and see how it works, just a shame i don’t have much space to drive such a fast robot around…
Thanks for the manual link! i’ll give it a look, you are correct sorry haha i was using the flysky, i forgot theres more than one transmitter available in the world…
What 3s Lipo are you going to use/already have? There are quite limited options here in the uk and I’m interested to see what others are going with. I use these: https://wheelspinmodels.co.uk/i/gens-ace-mini-car-lipo-3s-11.1v-200mah-30c-with-381447/ on my shuffling hammersaw with n10s for drive and bbb esc, malenki HV, high power n20 for arm and 1806 for weapon.
I’m using 180mah lipos from Palm Beach Robotics, linked below
I just got them in the post yesterday so i’m excited to try them out when all the parts for the new version of Somatic Damage arrive! (plus my other two spinners)
Yeah the shipping costs were high… i ended up buying a couple of safety clamps and a charger just so i could at least make it worth spending that much on shipping…
I’ll see how they perform when i use them in combat, im hoping they’ll be quite good!
To be fair i think you and Josh are the reason i went for it hahaha. Pretty sure i overheard at GROCS about Xray using 3s so i thought it’d be fun to invest. Hoping itll be a great upgrade if i have the weight for them!
yeah fairs. I mean for the two shufflers i am working on, the bite should be pretty good since they are asymmetrical bars with a sharp tooth on the end, id like to imagine it won’t struggle to get a bite as much because of the fact that its assymetrical so theres only one edge the opponent can catch on rather than two? Unsure if thats how it works…
But yeah drive speed is definitely super helpful, ill have to play around and experiment with it and see how it ends up working at ARCS, hoping to bring something deadly to the table then!
I forgot to make a post but over the weekend i took Nom 2: Nom Again and a new robot to CAT 6 at Leighton Buzzard!
Non 2: Nom Again is virtually unchanged after ORCS *still even sports the same battle scars!)
Psychic however is a new robot exclusively for Sportsman events! Its a robot i found on Ebay (presumably from Harry from Team Xcitement Park Robotics). The main difference being that i CAD designed a custom wedge that would allow for forks to be mounted to the front, quite happy with the result! Will write an event report as soon as the fights are released
